Solved Sinusbot Start Error
LegoCraftNW
Hi I am using Windows Server 2012 R2 Build 9600 VDS server. I open the SinusBot program and it does not open. it was working on my previous VDS server. Please Help me.
Kir-à
1522584237417-png.2100
Logs?
Everlike
By default there should be a .txt file called "logs" in your Sinusbot folder, if there is no file, edit your config.ini (not "config.ini.dist") (also in your Sinusbot folder) there you should be a line called "LogFile = " just put the path to your sinusbot folder here. for me it is "LogFile = "/opt/sinusbot/logs""
LegoCraftNW
this is my logs
2018/07/28 13:41:54 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin advertising.js
2018/07/28 13:41:54 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin alonemode.js
2018/07/28 13:41:54 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin bookmark.js
2018/07/28 13:41:54 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin followme.js
2018/07/28 13:41:54 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin norecording.js
2018/07/28 13:41:54 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin rememberChannel.js
2018/07/28 13:41:54 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin welcome.js
2018/07/28 13:42:19 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin advertising.js
2018/07/28 13:42:19 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin alonemode.js
2018/07/28 13:42:19 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin bookmark.js
2018/07/28 13:42:19 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin followme.js
2018/07/28 13:42:19 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin norecording.js
2018/07/28 13:42:19 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin rememberChannel.js
2018/07/28 13:42:19 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin welcome.js
Kir-à
We can't help you at all with this.
What was your installation method?
Installer or Manual?
