Version: 0.9.12-58b509d
2016/05/06 12:37:40 Updating database to v4... 3
2016/05/06 12:37:40 Updating database to v5... 4
2016/05/06 12:37:40 Error on database operations: duplicate column name: url
2016/05/06 12:37:40 This usually happens, if the bot user does not own the database files (e.g. when you first ran the bot as user root but now moved to another user). To fix this, please make sure that the bot user owns the entire data directory.
2016/05/06 13:05:59 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin advertising.js
2016/05/06 13:05:59 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin aloneMode.js
2016/05/06 13:05:59 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin badchan.js
2016/05/06 13:05:59 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin bookmark.js
2016/05/06 13:05:59 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin covatar.js
2016/05/06 13:05:59 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin dev.js
2016/05/06 13:05:59 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin followme.js
2016/05/06 13:05:59 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin idle.js
2016/05/06 13:05:59 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin metadata.js
2016/05/06 13:05:59 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin norecording.js
2016/05/06 13:05:59 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin rememberChannel.js
2016/05/06 13:05:59 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin showcase.js
2016/05/06 13:05:59 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin sound.js
2016/05/06 13:05:59 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin welcometext.js
2016/05/06 13:05:59 Updating database to v5... 4
2016/05/06 13:05:59 Error on database operations: duplicate column name: url
2016/05/06 13:05:59 This usually happens, if the bot user does not own the database files (e.g. when you first ran the bot as user root but now moved to another user). To fix this, please make sure that the bot user owns the entire data directory.
- Operating System: Debian GNU/Linux 7.10 (wheezy) (OpenVZ)
- Kernel: Linux 2.6.32-042stab113.11 x86_64
- Load Average: 0.26 0.38 0.46
- Uptime: 3 days, 20 hours, 11 minutes, 25 seconds
- OS Updates: 10 (updates available!)
- OS APT Last Update: 02.06.2016 10:11:58 CEST +02:00:00
CPU(s): 32
CPU MHz: 2400.072
Virtualization: VT-x
- RAM: B/1.00 GB in use (%)
- SWAP: B/ B in use (%)
- DISK: 2.00 GB/16.55 GB in use (12%)
> libglib: 2.33.12+really2.32.4-5
- Binary: /opt/sinusbot/sinusbot (Hash: 8b94daaaf3ffd829669e70a3c6a5843d)
- Version: 0.9.12-58b509d
- Bot Plugin: 2c207af25e3000543d85b5f4275ef053
- TS3 Client: 2c207af25e3000543d85b5f4275ef053
- TS3Path = /opt/sinusbot/teamspeak3-client/ts3client_linux_amd64 (Version 3.0.18.2)
- YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2016.05.30.2)
- Report date: 04.06.2016 10:02:42 CEST +02:00:00 (timezone: Europe/Berlin)
- youtube-dl Version: 2016.05.30.2
- DiagScript version: 0.4.5
Er muss ja auch gestartet seinnot running
