Solved Sinusbot startet nicht mehr!
inception76
Betriebssystem: Windows / Linux
SinusBot Version: 0.9.x
TS3 Version: 3.x.x
Habe meinen Server neu aufgesetzt, Sinusbot neu installiert und seitdem funktionert es nicht mehr.
2017-07-27T02:50:27+02:00 BOT-CONFIG [admin] HOST CHAN CHANPW ANNOUNCE DESCRIPTION ANNOUNCESTR TTSURL CC OK
2017-07-27T02:47:36+02:00 TSClient quit.
2017-07-27T02:47:35+02:00 New connection status 0; Error 1797
2017-07-27T02:47:35+02:00 The bot could not connect. This might have several reasons: the server doesn't exist at that address, the server password is wrong, the default channel doesn't exist, the bot has been banned, the server is an illegal installation or the password is wrong , the security level of your identity is too low or the server does not allow the version of the client you are using. See our Wiki / Forums for more help.
2017-07-27T02:47:35+02:00 TS |INFO |ClientUI |1 |Failed to connect to server, want autoreconnect = 0
2017-07-27T02:47:35+02:00 TS |INFO |ClientUI |1 |Connect status: Disconnected
2017-07-27T02:47:30+02:00 TS |INFO | | |Statistics report: Not yet, next report on Sat Aug 5 00:13:19 2017
2017-07-27T02:47:30+02:00 TS |INFO |ClientUI | |Last update check was: Tue Jan 1 00:00:01 2019
2017-07-27T02:47:30+02:00 New connection status 1; Error 0
2017-07-27T02:47:30+02:00 TS |INFO |ClientUI |1 |Connect status: Connecting
2017-07-27T02:47:30+02:00 TS |INFO |PreProSpeex |1 |Speex version: 1.2rc1
2017-07-27T02:47:30+02:00 TS |INFO |ClientUI |1 |Initiating connection: 80.252.107.221:9989 80.252.107.221
2017-07-27T02:47:30+02:00 TS |INFO |ClientUI |1 |Blacklist check ok
2017-07-27T02:47:30+02:00 TS |INFO |ClientUI |1 |Connect to server: 80.252.107.221
2017-07-27T02:47:30+02:00 TS |INFO |ClientUI | |ts3server: 80.252.107.221?port=9989&nickname=Musikknecht%E2%99%A5&password=&channel=&channelpassword=
2017-07-27T02:47:30+02:00 TS |INFO |ClientUI | |Using configuration location: /opt/sinusbot/data/ts3/ddd7053c-c2d8-4d0e-bdbd-756d1e9d0b85/97a0b365-45d0-4719-9996-1115e4236b6a/settings.db
2017-07-27T02:47:30+02:00 TS |INFO |ClientUI | |Qt version: 5.5.0
2017-07-27T02:47:30+02:00 TS |INFO |ClientUI | |Failed to init text to speech engine
2017-07-27T02:47:30+02:00 TS |INFO |Query | |listening on 127.0.0.1:25639
2017-07-27T02:47:30+02:00 TS |INFO | | |Loading plugin: libtest_plugin
2017-07-27T02:47:30+02:00 TS |INFO | | |Loading plugin: libsoundbot_plugin
2017-07-27T02:47:30+02:00 TS |INFO | | |Loading plugin: liblua_plugin
2017-07-27T02:47:30+02:00 TS |INFO | | |Loading plugin: libclientquery_plugin
2017-07-27T02:47:30+02:00 TS |DEBUG |PulseAudio | |connected to pulse audio server
2017-07-27T02:47:30+02:00 TS |INFO | | |Using hardware aes
2017-07-27T02:47:30+02:00 TS |INFO | | |SystemInformation: Linux 4.4.44-1-pve #1 SMP PVE 4.4.44-84 (Thu, 9 Mar 2017 12:06:34 +0100) x86_64 Binary: 64bit
2017-07-27T02:47:30+02:00 TS |INFO | | |TeamSpeak 3 Client 3.0.18.2 (2015-10-22 11:14:48)
2017-07-27T02:47:30+02:00 Starting instance ts3server://80.252.107.221?port=9989&nickname=Musikknecht%E2%99%A5&password=&channel=&channelpassword=
2017-07-27T02:47:29+02:00 Could not create Notifications-Tabletable Notifications already exists
2017-07-27T02:47:29+02:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
2017-07-27T02:47:29+02:00 Could not create Chat-Tabletable Chat already exists
2017-07-27T02:47:28+02:00 BOT-CONFIG [admin] HOST PORT CHAN CHANPW ANNOUNCE DESCRIPTION ANNOUNCESTR TTSURL CC OK
Mfg,
Daniel
Krauti
Alle Punkte in der Liste mal prüfen.
inception76
Habe das problem. Der Musicbot läuft seit neustem nichtmehr auf dem selben Server deswegen hat es mit 127.0.0.1 bzw der ip vom localen server nicht geklappt. Noch ungewohnt das Teamspeak auf einem naderen Root läuft :D Naja trotzdem danke:)
