Some problems with my Bot after installation
DevHugo
Hey, I have two problems :
The frist :
<blockquote>2015/07/05 13:34:45 d2e0d534 3296677b WARN Could not send config
2015/07/05 13:35:09 d2e0d534 3296677b DEBUG Storing configuration.
</blockquote>
So my pannel don't work.
And the second :
0f8XsdvsK45qFEOUsy8JH02wMvIy4k
Can you help me pleas ?
Thanks
Ps: Sorry for my bad english :/
DevHugo
<blockquote>TS3Path = "/opt/ts3soundboard/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64"
SecretKey = [18, 250, 241, 58, 73, 151, 108, 158, 97, 169, 37, 40, 46, 23, 238, 96, 64, 172, 224, 230, 195, 101, 183, 230, 74, 250, 13, 79, 47, 116, 151, 73]
MTU = 1500
SampleInterval = 100
[StreamRewrites]</blockquote>
seschi98
Try to change ListenHost to whatever your server ip is, in most cases this should be localhost or '127.0.0.1'. Also try to specify the userid and groupid of yout bot user (you can find this information in /etc/passwd) and set your hostname.
Raphraph
Do NOT change the ListenHost !! Keep it on "0.0.0.0" !
And the entry "Hostname" is useless, if you do not use SSL :)
And specifiying the User and Group is not really helpful I think... I never had to do this... Please check your configuration file for some "tab" or other invalid characters...
It seems like there's an issue with the plugin, either not copied like it says in the documentation or some system libraries are too old. Unless there's more information on the system and some log output with a higher log level available, we cannot help further.
RunAsUser / RunAsGroup should generally not be touched.
Have you copied the Plugin?
Yeah, that helped. Your system uses libraries that are too old. Which OS are you using?
Yeah, sadly that's too old. I just checked if there's an easy workaround - there isn't :/
