Solved SSL not working after update
Domekologe
Hello all,
at first my english is not so good, but I prefer this forum instead of the german part (this part is more active).
I had the problem yesterday, the bot says "You are running on an outdated version", so I make an update with the installer script.
After that, the bot works, but I can't access to it via SSL (https) only with an non secure connection (http).
I also tried to change the hostname, but under another hostname it is unable to login to the webinterface (and SSL is not available).
Here is the debugpart:
 - Operating System: Ubuntu 16.04.3 LTS
 - Kernel: Linux 3.13.0-123-generic x86_64
 - Load Average: 6.77 6.64 6.61
 - Uptime: 21 days, 17 hours, 18 minutes, 25 seconds
 - OS Updates: 21 (updates available!)
 - OS APT Last Update: 05.10.2017 04:13:33 CEST +02:00:00
  Architecture:  x86_64
  CPU(s):  10
  Thread(s) per core:  1
  Core(s) per socket:  10
  Socket(s):  1
  Model name:  Intel(R) Xeon(R) CPU E5-2630 v4 @ 2.20GHz
  CPU MHz:  2199.998
  Hypervisor vendor:  KVM
  Virtualization type:  full
 - RAM:  B/49.13 GB in use (%)
 - SWAP:  B/ B in use (%)
 - DISK: 414.81 GB/706.20 GB in use (58%)
  > libglib: 2.48.2-0ubuntu1
 - Status: running (PIDs: 23960 23959, User: sinusbot)
 - Binary: /opt/sinusbot/sinusbot (MD5 Hash: 12d8c32c3e122463bc11bcefd5af39e2)
 - Version: 0.10.6-6b6bd3a
  - YoutubeDLPath = /opt/sinusbot/youtube-dl (does exist, version: 2017.08.27.1)
 - Installed scripts: Advanced_Display_Playback_Information.js; advertising.js; alonemode.js; aloneMode.js; badchan.js; bookmark.js; covatar.js; dev.js; followme.js; idle.js; metadata.js; norecording.js; Online_Users_Record.js; rememberChannel.js; showcase.js; ShowPlaylists.js; sound.js; Sticky_Channel.js; welcome.js; welcometext.js; Youtube_Search.js; YT-search.js; ZTSupport_-_SupportChannel_With_ServerGroup_Support.js
 - Report date: 05.10.2017 07:51:48 CEST +02:00:00 (timezone: Europe/Berlin)
 - youtube-dl Version: 2017.08.27.1
 - DiagScript version: 0.5.1
And here is my actual config:
ListenHost = "*** VALID IP ADDRESS STANDS HERE ***"
MaxBulkOperations = 800
LogLevel = 3
YoutubeDLPath = "/opt/sinusbot/youtube-dl"
UseSSL = true
SSLKeyFile = "/opt/sinusbot/cert/privkey1.pem"
SSLCertFile = "/opt/sinusbot/cert/cert1.pem"
Hostname = "***VALID HOSTNAME STANDS HERE***"
LogFile = "botlog.log"
LicenseKey = "***VALID LICENSE STANDS HERE***"
  BufferSize = 9003024288
  MaxDownloadSize = 400019430400
  MaxDownloadRate = 10004857600
  CacheStreamed = true
  AllowGIF = true
  UserAgent = "Mozilla/5.0 (Windows NT 6.3; rv:36.0) Gecko/20100101 Firefox/36.0"
  Enable = true
And for your information:
I can't use an reverse proxy to do this, because another application (an special API) use port 80.
And before I've done the update everything works (And the only way to start the bot was an update).
I am hopefully looking forward to find help, to solve it.
Kind Regards
Domekologe
Can confirm that, sorry. Hotfix with support for ssl + let's encrypt will be out later today.
