Solved Stale decoder detected - bot stops responding to anything.
olokos
- Operating System: Ubuntu 18.04.2 LTS
- Kernel: Linux 5.1.9-050109-generic x86_64
- Load Average: 0.59 0.88 0.88
- Uptime: 2 days, 23 hours, 40 minutes, 55 seconds
- OS APT Last Update: 19.06.2019 15:32:55 CEST +02:00:00
- Shell Locale: pl_PL.UTF-8
- Bot Start Script: found at /etc/systemd/system/sinusbot.service [perms: 755]
    Architecture:        x86_64
    CPU(s):              cens
    Thread(s) per core:  cens
    Core(s) per socket:  cens
    Socket(s):           cens
    Model name:          QEMU Virtual CPU version 2.5+
    CPU MHz:             cens
    Hypervisor vendor:   KVM
    Virtualization type: full
- RAM: censored/censored GB in use (58%)
- SWAP: censored MB/censored GB in use (10%)
- DISK: censored GB/censored GB in use (62%)
   - libglib: 2.56.4-0ubuntu0.18.04.3
- Status: running (PIDs: 18681 18680, User: sinusbot)
- Binary Info: MD5 Hash: 2472b206ad5fa41d71e2ce3923c8be80, Perms: 755, User: sinusbot
- Version: 1.0.0-beta.2-63286de
   - TS3Path = /opt/sinusbot/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64 (Version 3.2.5)
   - YoutubeDLPath = /opt/sinusbot/youtube-dl (does exist, version: 2019.06.08)
- Installed scripts: advertising.js; alonemode.js; AntiProxy.js; autoCodec.js; avatarbanner.js; badnickname.js; bookmark.js; come.js; command.js; followme.js; norecording.js; rememberChannel.js; saveCPU.js; theSimpliestSupport.js; unusedchanneldeleter.js; volumeKeeper.js; welcome.js; youtube.js; youtube-web.js
    linux-vdso.so.1 (0x00007ffe585aa000)
    libswresample.so.2 => /opt/sinusbot/libswresample.so.2 (0x00007f560903c000)
    libavfilter.so.6 => /opt/sinusbot/libavfilter.so.6 (0x00007f5608ce4000)
    libavformat.so.57 => /opt/sinusbot/libavformat.so.57 (0x00007f56088e3000)
    libavcodec.so.57 => /opt/sinusbot/libavcodec.so.57 (0x00007f5607f7e000)
    libavutil.so.55 => /opt/sinusbot/libavutil.so.55 (0x00007f5607d0a000)
    libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f5607b06000)
    libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f5607768000)
    libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f5607549000)
    libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f56071c0000)
    libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f5606fa8000)
    libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f5606bb7000)
    libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f560699a000)
    librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f5606792000)
    /lib64/ld-linux-x86-64.so.2 (0x00007f5609256000)
- Time (local): 20.06.2019 01:26:02 CEST +02:00:00
- Time (remote): 20.06.2019 01:26:02 CEST +02:00:00
- Timezone: Europe/Warsaw
- TeamSpeak3 Version: 3.2.5
- youtube-dl Version: 2019.06.08
2019-06-20T01:20:16+02:00 TS |ERROR |Decode | |Stale Decoder detected, terminating it. Was ever active = 0
Console is basically filled with this error and bots are not responding to commands at all.
Running beta2 of sinusbot on ubuntu server 18.04 LTS x64
After restarting sinusbot it works good, but it will most likely come up again after a while.
