Teamspeak 5
D
Deleted member 62173
Guest
Hallo! Da ich vor kurzem nen Teamspeak 5 Beta Code erhalten habe wollte ich mal nachfragen ob Interesse besteht sich ein wenig hier oder in ner Gruppe direkt im neuen Client auszutauschen.
Gerade was die Konfiguration der Channel betrifft scheint es ja jetzt schon mehr Möglichkeiten (Individual Channel Banner) zu geben und vielleicht kommt der ein oder andere Tipp, Hinweis oder Aha-Effekt dazu.
Gruß aus Berlin,
Dave
Username spieler5_dave
Changelog
  • Dashboard is more dynamic and prepared to support custom widgets
  • Closing private chats on TeamSpeak Servers will end the conversation
  • Fixed a bug where multi-line BBCode was not parsed correctly
  • Minor fixes and improvements
Known issues
  • Support for user-defined custom widgets is not available yet
  • Connection quality widget shows ping and packet loss information
  • Client context menu contains option to show connection info
  • Channel overlay appears in sidebar when the active server is not visible
  • Tooltips for links shared in chat show full URL targets
  • Animated content (GIF, APNG, WebP) is paused until mouse over
  • Global chats are visually distinct from TeamSpeak Server chats
  • Fixed a bug where custom contact names were not used for chat mentions
  • Fixed a bug where chat histories were not loaded correctly
  • Fixed a bug where restored activities were loading forever
  • Fixed a bug where badges were not shown after redeeming codes
  • Fixed a bug where identities were shown twice in settings
  • Fixed a possible crash when ts3image:// requests were aborted
  • Multiple performance improvements for reduced CPU and memory usage
Known issues
  • Emoji picker can be cut off on smaller screens
  • Playback automatic gain control is reconfigured to be less aggressive
  • Fixed a bug where push-to-talk could be treated as continuous transmission
  • Chats can be muted individually for incoming messages/mentions
  • Channel banners can be configured and are shown in the server tree
  • Emoji picker provides access to animated GIFs powered by GIPHY
  • Disconnect status icon is shown after being kicked/banned from a server
  • Fixed a bug where the client did not reconnect to the previous channel
  • Fixed a bug where the client UI could freeze when rendering BBCode
  • Fixed a bug where server/channel settings were not applied correctly
  • Fixed a bug where some legacy channel spacers were not rendered correctly
  • Fixed a possible crash when changing codecs from Opus Voice to Opus Music
Known issues
  • Animated content (GIF, APNG, WebP) can cause increased CPU usage
  • Capture settings allow enabling tapping noise attenuation
  • Fixed a bug where key binding settings were not applied correctly
  • Fixed a bug where the initial privilege key dialog was shown multiple times
  • Fixed a bug where childs of [COLOR] BBCode tags were not parsed correctly
  • Multiple fixes and improvements to performance and stablity
This update is required to use TeamSpeak Messenger services
  • Appearance settings show side-by-side preview of server tree modes
  • Multiple fixes and improvements to global messaging system
  • Desktop notifications provide improved functionality and layout
  • Settings directory is split up into cache, logs and preferences
  • Fixed a bug where automatic gain control could cause high memory usage
  • Fixed invalid behavior of modal dialogs when switching servers
  • Insufficient talk power notifications are more compact and less intrusive
  • Bans are handled properly including a countdown for remaining time
  • List of recent server events provides more information
  • Validation of server addresses in search bar is more reliable
  • Identity security level can be improved when establishing a new connection
  • Connection is closed automatically when host message mode is MODALQUIT
  • Sidebar width is no longer limited to 300 pixels
  • Echo cancellation and noise reduction deilver better results
  • Adding new contacts is possible right within the search bar
  • Users from mutual group chats will be suggested when adding new contacts
  • Search bar contextually resolves server nicknames
  • Server host message is shown when establishing a new connection
  • VAD works better with echo cancellation and noise reduction enabled
  • Fixed a bug where the client failed to initialize its settings database
  • Fixed a bug where server group properties were not updated for some users
  • Channel moderation queue displays user status icon and request time
  • Group names are shown next to user nicknames when display mode is configured
  • Fixed a bug where group icons were sorted incorrectly
  • Away icon uses alternate color when users also have their speakers muted
  • Sound notifications for talking while mute events are disabled by default
  • Fixed a bug where sending pokes from the chat input did not require a message
  • Fixed a bug where the mute status of individual users wa not shown correctly
Known issues
  • Some file types can not be attached to mesages using drag & drop
  • Support for APNG avatars is temporary disabled
  • Global chats provide drag & drop support for file attachments
  • Client context menu contains option to move user to current channel
  • Double-clicking user avatars will scale them up to fill the preview area
  • Ban reason is shown when trying to connect to server fails
  • Position of window splitters will be remembered
  • Server header bar provides quick-access to server settings in slim mode
  • Fixed a bug where clients were unable to edit their own description
  • Fixed a possible crash when changing the mute status or volume of other clients
  • Fixed a possible crash when using the fallback account recovery feature
  • Server header bar provides quick-access to current channel chat
  • Client context menu contains options to add/remove contacts
  • Mute status of other clients will be remembered
  • Incoming contact requests will show desktop notifications
  • Create channel dialog respects server permissions
Older changelog entries have been omitted
  • Initial closed beta release
