CuzImPhilipp
My Little Sinus bot won't connect to the teamspeak It print out this:
___ ___ _ _ _ _ ___ ___ ___ _____
Version: 1.0.0-beta.10-202ee4d
2020/04/25 15:10:15 a22c2073 INFO Loading instances
2020/04/25 15:10:15 a22c2073 INFO Loading instance://091c87f3-7af0-4762-aec2-d7d5ee5ce137
2020/04/25 15:10:15 a22c2073 091c87f3 DEBUG Spawning instance shortly due to missing configuration file.
2020/04/25 15:10:15 a22c2073 091c87f3 DEBUG Prespawn.
2020/04/25 15:10:15 a22c2073 091c87f3 DEBUG About to run.
2020/04/25 15:10:15 a22c2073 091c87f3 INFO Starting instance ts3server://178.63.65.194?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2020/04/25 15:10:15 a22c2073 091c87f3 DEBUG TS>Please set the environment variable TS3SERVER_LICENSE to "accept" in order to accept the license agreement.
2020/04/25 15:10:15 a22c2073 091c87f3 DEBUG TS>Alternatively, create a file named ".ts3server_license_accepted" in the working directory or start the server with the command line parameter "license_accepted=1".
2020/04/25 15:10:15 a22c2073 091c87f3 DEBUG TS>To view the license agreement set TS3SERVER_LICENSE to "view" in order to print the license to the console.
2020/04/25 15:10:15 a22c2073 091c87f3 DEBUG TS>Alternatively view the file "LICENSE" in your favorite text viewer yourself.
2020/04/25 15:10:15 a22c2073 091c87f3 DEBUG Closed.
2020/04/25 15:10:15 a22c2073 091c87f3 INFO TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2020/04/25 15:10:15 a22c2073 091c87f3 DEBUG executing script sinusbot-commands
2020/04/25 15:10:15 a22c2073 091c87f3 DEBUG executing script command
2020/04/25 15:10:15 a22c2073 091c87f3 PLUGIN [sinusbot-commands:86:12] Loaded SinusBot Commands v1.0.0 by Jonas Bögle (@irgendwr).
2020/04/25 15:10:15 a22c2073 091c87f3 DEBUG registered callback for event load
2020/04/25 15:10:15 a22c2073 091c87f3 INFO script sinusbot-commands loaded
2020/04/25 15:10:15 a22c2073 091c87f3 INFO Initialization complete
2020/04/25 15:10:15 a22c2073 091c87f3 INFO Auto-Starting a22c2073-71c9-418f-8dbd-aa8194affbf9/091c87f3-7af0-4762-aec2-d7d5ee5ce137 in 500 ms...
2020/04/25 15:10:15 [GENERAL/FFMPEG ] INFO FFmpeg/avcodec v3741798; license: LGPL version 2.1 or later; 81 codecs
2020/04/25 15:10:15 [GENERAL/FFMPEG ] INFO FFmpeg/avformat v3742052; license: LGPL version 2.1 or later; 143 formats
2020/04/25 15:10:15 [GENERAL/YTDL ] INFO youtube-dl checking...
2020/04/25 15:10:15 a22c2073 091c87f3 DEBUG registered callback for event chat
2020/04/25 15:10:15 a22c2073 091c87f3 DEBUG module registered as command
2020/04/25 15:10:15 a22c2073 091c87f3 INFO script command loaded
2020/04/25 15:10:15 a22c2073 091c87f3 DEBUG resolving module command
2020/04/25 15:10:15 a22c2073 091c87f3 DEBUG imported module: command
2020/04/25 15:10:16 a22c2073 091c87f3 DEBUG Prespawn.
2020/04/25 15:10:16 [GENERAL/YTDL ] INFO youtube-dl version compatible, support enabled
2020/04/25 15:10:16 [GENERAL/!!!!!!!] NOTICE You may now configure and launch the bots from the webinterface. http://0.0.0.0:8087
2020/04/25 15:10:16 [GENERAL/RADIO ] INFO RadioStation data loaded
2020/04/25 15:10:16 [GENERAL/RADIO ] INFO Imported radio stations
2020/04/25 15:10:16 a22c2073 091c87f3 DEBUG closing channels
2020/04/25 15:10:16 a22c2073 091c87f3 DEBUG About to run.
2020/04/25 15:10:16 a22c2073 091c87f3 INFO Starting instance ts3server://178.63.65.194?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2020/04/25 15:10:16 a22c2073 091c87f3 DEBUG eof from voice
2020/04/25 15:10:16 a22c2073 091c87f3 DEBUG TS>Please set the environment variable TS3SERVER_LICENSE to "accept" in order to accept the license agreement.
2020/04/25 15:10:16 a22c2073 091c87f3 DEBUG TS>Alternatively, create a file named ".ts3server_license_accepted" in the working directory or start the server with the command line parameter "license_accepted=1".
2020/04/25 15:10:16 a22c2073 091c87f3 DEBUG TS>To view the license agreement set TS3SERVER_LICENSE to "view" in order to print the license to the console.
2020/04/25 15:10:16 a22c2073 091c87f3 DEBUG TS>Alternatively view the file "LICENSE" in your favorite text viewer yourself.
2020/04/25 15:10:16 a22c2073 091c87f3 DEBUG Closed.
2020/04/25 15:10:16 a22c2073 091c87f3 INFO TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2020/04/25 15:10:17 a22c2073 091c87f3 DEBUG closing channels
2020/04/25 15:10:17 a22c2073 091c87f3 DEBUG eof from voice
2020/04/25 15:10:45 a22c2073 091c87f3 DEBUG Storing configuration.
but it have the .ts3server_license_accepted with the command line parameter "license_accepted=1" but it won't start
I use:
Linux Debian 9
8GB DDR4 Ram
amd epic
Hope you can help me
I use:
Linux Debian 9
8GB DDR4 Ram
amd epic
