tre
Operating System: Linux
TS3 Version: 3.0.19.4
The bot used to work fine but now it only connects to my server for a short amount of time. I have tried it on other servers and it works fine. I'm not sure what the problem is as I've reinstalled the server and sinusbot and both VPSs multiple times.
Config.ini
Any help is appreciated!
- Operating System: Ubuntu 16.04.2 LTS (OpenVZ)
- Kernel: Linux 2.6.32-042stab093.4 x86_64
- Load Average: 0.00 0.00 0.00
- Uptime: 0 days, 0 hours, 6 minutes, 11 seconds
- OS APT Last Update: 13.02.2017 07:29:46 EST -05:00:00
- RAM: B/128.00 MB in use (%)
- SWAP: B/ B in use (%)
- DISK: 982.82 MB/11.04 GB in use (8%)
> libglib: 2.48.2-0ubuntu1
- Status: running (PIDs: 507 506, User: sinusbot)
- Binary: /opt/sinusbot/sinusbot (MD5 Hash: 0005c8c289b99913844c9f761dbb50e9)
- Version: 0.9.16-10f0fad
- Bot Plugin: 28b54596e19937601df973b709aa0667
- TS3 Client: 28b54596e19937601df973b709aa0667
- YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2017.02.11)
- Report date: 13.02.2017 09:23:24 EST -05:00:00 (timezone: America/New_York)
- youtube-dl Version: 2017.02.11
- DiagScript version: 0.4.6
Config.ini
LicenseKey = "7vXrJ9/fQfm1oojZXdqrSWSyfXNu40qfY/cztrpAOAc="
UserAgent = "SinusBot (0.9.16-10f0fad)"
