The bot does not listen to my commands
Poledica
When I open the chat bot and write !register Poledica and !password Poledica It does not give the command at all that I am registered or! Help, this happens to me for the first time after your update, I deleted and uninstalled everything and nothing in the end, it even has a musicbot permission on the teamspeak 3 server. Do you know what the problem is. Thank you for your understanding ?
__Duch__
I have had the same problem since January 4. Better said, since I got "This version has expired" message and reinstalled the program. Bot works fine from website, just commands on TS3 does not work.
  • SinusBot version: 1.0.0-beta.13-dc94a7c
  • TS Client: 3.5.6 [Stable] Windows
  • Server version: 3.13.2 Linux
  • OS: Windows 10 64bit
  • hardware specs: Core i7-8750H, 16GB RAM
    2021-01-12T10:16:05+01:00 2568/insufficient client permissions/i_channel_needed_description_view_power2021-01-12T10:16:05+01:00 2568/insufficient client permissions/i_channel_needed_description_view_power
    2021-01-12T10:16:05+01:00 New connection status 4; Error 0
    2021-01-12T10:16:05+01:00 New connection status 3; Error 0
    2021-01-12T10:16:05+01:00 New connection status 2; Error 0
    2021-01-12T10:16:04+01:00 New connection status 1; Error 0
    2021-01-12T10:16:02+01:00 TS>DUMP defined! Dumpdir is: C:\SinusBot\data\ts3\2097328e-3cb4-4d35-a0de-952ad5bf83cd\c6d42f40-5599-44c8-bb4b-ae5665eb1b07\crashdumps
    2021-01-12T10:16:02+01:00 TS>Crashdump ENABLED, directory is: C:\SinusBot\data\ts3\2097328e-3cb4-4d35-a0de-952ad5bf83cd\c6d42f40-5599-44c8-bb4b-ae5665eb1b07\crashdumps
    2021-01-12T10:16:02+01:00 Starting instance ts3server://82.208.17.92?port=6875&nickname=Music%20BOT%201&password=&channel=&channelpassword=
    2021-01-12T10:16:02+01:00 Could not insert into FileTransfer-Tableno such table: FileTransfer
    2021-01-12T10:16:02+01:00 Could not delete from FileTransferno such table: FileTransfer
    2021-01-12T10:16:02+01:00 Could not create Notifications-Tabletable Notifications already exists
    2021-01-12T10:16:02+01:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
    2021-01-12T10:16:02+01:00 Could not create Chat-Tabletable Chat already exists
    2021-01-12T10:16:02+01:00 About to run.
    2021-01-12T10:16:02+01:00 Prespawn.
    2021-01-12T10:16:02+01:00 [sinusbot-commands:222:24] command.js can be found here: https://github.com/Multivit4min/Sinusbot-Command/blob/master/command.js
    2021-01-12T10:16:02+01:00 [sinusbot-commands:221:24] command.js library not found! Please download command.js to your scripts folder and restart the SinusBot, otherwise this script will not work.
    2021-01-12T10:16:02+01:00 imported module: command
    2021-01-12T10:16:02+01:00 resolving module command
    2021-01-12T10:16:02+01:00 script sinusbot-commands loaded
    2021-01-12T10:16:02+01:00 registered callback for event load
    2021-01-12T10:16:02+01:00 registered callback for event ytdl.error
    2021-01-12T10:16:02+01:00 registered callback for event ytdl.success
    2021-01-12T10:16:02+01:00 [sinusbot-commands:114:12] SinusBot v1.0.0-beta.13-dc94a7c on windows
    2021-01-12T10:16:02+01:00 [sinusbot-commands:113:12] Loaded SinusBot Commands v1.1.2 by Jonas Bögle (@irgendwr).
    2021-01-12T10:16:02+01:00 Auto-Starting 2097328e-3cb4-4d35-a0de-952ad5bf83cd/c6d42f40-5599-44c8-bb4b-ae5665eb1b07 in 500 ms...
    2021-01-12T10:16:02+01:00 Initialization complete
    2021-01-12T10:16:02+01:00 executing script sinusbot-commands
    2021-01-12T10:16:15+01:00 LOGIN [admin] OK
    2021-01-12T10:16:01+01:00 Loading instance://c6d42f40-5599-44c8-bb4b-ae5665eb1b07
    2021-01-12T10:16:01+01:00 Loading instances
    DataDir = "C:\\SinusBot\\data\\"
    ExternalFileBase = ""
    LicenseKey = "AdFs7So6WctxgjO3sbKUo2/ZmAesooFrKRXgLnrNQ0s="
    DevMode = false
    UserAgent = "SinusBot (1.0.0-beta.13-dc94a7c)"
    [TTS]
    Enabled = false
