Solved TS Client won't start.
trabbie
Hey guys I'm sure you guys get this problem a lot and I'm sorry that i have to nag you about this but I couldn't find a solution so far.
  • Sinus v0.9.9
  • Ubuntu 14.04
  • VPS with 128MB RAM
  • Chrome
ListenPort = 12117
MTU = 1500
LicenseKey = "1gGsGmpoxvkzA8zJ2WLkF3r0m9vO31GrHyu3Q5Q6xyk="
DisableLocalXServer = false
DebugLocalXServer = false
2016/02/14 13:34:17 d8822d5b 8625c06b INFO   TS |INFO    |ClientUI      |1  |Connect status: Disconnected
2016/02/14 13:34:17 d8822d5b 8625c06b INFO   TS |INFO    |ClientUI      |1  |Failed to connect to server, want autoreconnect = 0
2016/02/14 13:34:17 d8822d5b 8625c06b INFO   The bot could not connect. This might have several reasons: the server doesn't exist at that address, the server password is wrong or the security level of your identity is too low.
2016/02/14 13:34:17 d8822d5b 8625c06b INFO   New connection status 0; Error 1797
2016/02/14 13:34:18 d8822d5b 8625c06b INFO   TS>libpng warning: iCCP: known incorrect sRGB profile
2016/02/14 13:34:18 d8822d5b 8625c06b INFO   TS>warning: The VAD has been replaced by a hack pending a complete rewrite
2016/02/14 13:34:18 d8822d5b 8625c06b INFO   TS>qt.network.ssl: QSslSocket: cannot resolve SSLv2_client_method
2016/02/14 13:34:18 d8822d5b 8625c06b INFO   TS>qt.network.ssl: QSslSocket: cannot resolve SSLv2_server_method
2016/02/14 13:34:18 d8822d5b 8625c06b WARN   EOF
2016/02/14 13:34:18 X [MAIN] Disconnected:  0
2016/02/14 13:34:18 d8822d5b 8625c06b INFO   TSClient quit.
2016/02/14 13:34:18 d8822d5b 8625c06b INFO   Socket closed.
2016/02/14 13:34:18 X [MAIN] Disconnected:  5
2016/02/14 13:34:29 d8822d5b 8625c06b DEBUG  Storing configuration.
trabbie
- Operating System: Ubuntu 14.04 LTS (OpenVZ)
- Kernel: Linux 2.6.32-042stab112.15 x86_64
- Load Average: 0.42 0.28 0.15
- Uptime: 51 days, 11 hours, 37 minutes, 39 seconds
- OS Updates: 68 (updates available!)
- OS APT Last Update: 14.02.2016 12:43:52 UTC +00:00:00
    CPU(s):                8
    CPU MHz:               3411.405
    Virtualization:        VT-x
- RAM: 11.53 MB/128.00 MB in use (9%)
- SWAP: 38.56 MB/128.00 MB in use (30%)
- DISK: 2.27 GB/410.09 MB in use (568%)
- Report date: 14.02.2016 13:41:56 UTC +00:00:00 (timezone: Etc/UTC)
- Webinterface: port locally not reachable (Port: 12117)
- Binary: /opt/ts3soundboard/sinusbot (Hash: 8792e5fbe8cebf9acb2780fe22a784b0)
- Version:
   - Bot Plugin: cae22d367a30a6c9a4e31c13d722ff9a
   - TS3 Client: cae22d367a30a6c9a4e31c13d722ff9a
   - YoutubeDLPath = not set
- Installed scripts: advertising.js; aloneMode.js; badchan.js; bookmark.js; covatar.js; dev.js; followme.js; idle.js; metadata.js; norecording.js; rememberChannel.js; showcase.js; welcometext.js
- DiagScript version: v0.4.0
Initializing built-in extension Generic Event Extension
Initializing built-in extension SHAPE
Initializing built-in extension MIT-SHM
Initializing built-in extension XInputExtension
Initializing built-in extension XTEST
Initializing built-in extension BIG-REQUESTS
Initializing built-in extension SYNC
Initializing built-in extension XKEYBOARD
Initializing built-in extension XC-MISC
Initializing built-in extension SECURITY
Initializing built-in extension XINERAMA
Initializing built-in extension XFIXES
Initializing built-in extension RENDER
Initializing built-in extension RANDR
Initializing built-in extension COMPOSITE
Initializing built-in extension DAMAGE
Initializing built-in extension MIT-SCREEN-SAVER
Initializing built-in extension DOUBLE-BUFFER
Initializing built-in extension RECORD
Initializing built-in extension DPMS
Initializing built-in extension Present
Initializing built-in extension DRI3
Initializing built-in extension X-Resource
Initializing built-in extension XVideo
Initializing built-in extension XVideo-MotionCompensation
Initializing built-in extension SELinux
Initializing built-in extension GLX
Crashdump ENABLED,  directory is: /home/sinusbot/.ts3client/crashdumps
DUMP defined! Dumpdir is: /home/sinusbot/.ts3client/crashdumps
2016-02-14 14:08:14.326013|INFO    |              |   |TeamSpeak 3 Client 3.0.18.2 (2015-10-22 11:14:48)
2016-02-14 14:08:14.326190|INFO    |              |   |SystemInformation: Linux 2.6.32-042stab112.15 #1 SMP Tue Oct 20 17:22:56 MSK 2015 x86_64 Binary: 64bit
2016-02-14 14:08:14.326218|INFO    |              |   |Using hardware aes
2016-02-14 14:08:14.391995|DEBUG   |PulseAudio    |   |connected to pulse audio server
2016-02-14 14:08:14.438897|INFO    |              |   |Loading plugin: libappscanner_plugin
2016-02-14 14:08:14.439002|INFO    |              |   |Loading plugin: libclientquery_plugin
2016-02-14 14:08:14.439043|INFO    |              |   |Loading plugin: liblua_plugin
2016-02-14 14:08:14.439082|INFO    |              |   |Loading plugin: libsoundbot_plugin
2016-02-14 14:08:14.439128|INFO    |              |   |Loading plugin: libtest_plugin
2016-02-14 14:08:14.443431|INFO    |Query         |   |listening on 127.0.0.1:25639
2016-02-14 14:08:14.929038|INFO    |              |   |*** Time [MAINWINDOW]: 177
2016-02-14 14:08:14.929191|INFO    |              |   |*** Time [INIT]: 178
2016-02-14 14:08:14.929237|INFO    |ClientUI      |   |*** Time [SQLITE_CONVERTER]: 4
2016-02-14 14:08:14.934529|INFO    |ClientUI      |   |Failed to init text to speech engine
2016-02-14 14:08:14.934645|INFO    |ClientUI      |   |Qt version: 5.5.0
2016-02-14 14:08:14.934783|INFO    |ClientUI      |   |Using configuration location: /home/sinusbot/.ts3client/settings.db
2016-02-14 14:08:15.431635|INFO    |ClientUI      |   |Last update check was: Never
2016-02-14 14:08:15.431742|INFO    |ClientUI      |   |Checking for update
2016-02-14 14:08:15.434441|INFO    |Update        |   |Checking for updates...
2016-02-14 14:08:15.493144|INFO    |Update        |   |Check license version: 1
2016-02-14 14:08:15.494624|INFO    |LicenseViewer |   |License language: C
2016-02-14 14:08:15.494747|INFO    |LicenseViewer |   |Requesting remote license for version 1 and language C
2016-02-14 14:08:15.564560|INFO    |LicenseViewer |   |Failed to download license file for version 1 and language C, retrying english fallback
2016-02-14 14:08:15.564693|INFO    |LicenseViewer |   |Requesting remote license for version 1 and language en
QThread: Destroyed while thread is still running
2016-02-14 14:08:15.618006|INFO    |LicenseViewer |   |Downloaded license file for version 1 and language en
Breakpad crash /home/sinusbot/.ts3client/crashdumps/0ce2608e-0bcd-b354-141503ed-68d91f7e.dmp
Starting Error Reporter: /opt/ts3soundboard/TeamSpeak3-Client-linux_amd64/error_report
waiting for X server to shut down QXcbConnection: Could not connect to display :1
Qhiliqq
Licensed Partner
Wurde gefixt :)
Wenn der Bot auf dem selben Server wie der TS läuft sollte auch die IP 127.0.0.1 genutzt werden ;)
__________________
Fixed :)
If the bot and the teamspeak-server is located on the same server the ip should be 127.0.0.1 ;)
