TS3 and SinusBot with docker-compose
Has anyone set up a working docker-compose for sinusbot?
The teamspeak and the web interface run without problems, but I can't connect the bot to my ts.
The log throws no error, it even shows a working connection. No bot to be seen on the server. I used the container name, domain and IP as hostname.
Looking for another possibility to make sports.
Can you show us your docker-compose.yml?
version: '2'
services:
    teamspeak:
        image:  mbentley/teamspeak:latest
        restart: always
        volumes:
          - /docker/teamspeak3/teamspeak:/data
        ports:
          - "9987:9987/udp"
          - "30033:30033"
          - "10011:10011"
          - "41144:41144"
        environment:
          - TS3SERVER_LICENSE=accept
        networks:
          - back
    sinusbot:
        image: quay.io/galexrt/sinusbot:latest
        restart: always
        volumes:
          - /docker/teamspeak3/sinusbot/data:/sinusbot/data
          - /docker/teamspeak3/sinusbot/scripts:/sinusbot/scripts
          - /docker/teamspeak3/sinusbot/config:/sinusbot/config
          - /docker/nginx-proxy/certs:/etc/ssl/certs
        ports:
          - "8087:8087"
        networks:
          - back
networks:
    back:
        driver: bridge
@mxschmitt
Ich habe es jetzt mit der offiziellen Version gemacht, verbinden kann ich mich noch immer nicht.
docker-compose.yml:
YAML:
version: '2'
services:
    teamspeak:
        volumes:
        ports:
          - "9987:9987/udp"
          - "30033:30033"
          - "10011:10011"
          - "41144:41144"
        environment:
        networks:
          - back
        restart: always
    sinusbot:
        image: sinusbot/docker
        restart: always
        ports:
          - 8087:8087
        volumes:
          - ./sinusbot/scripts:/opt/sinusbot/scripts
          - ./sinusbot/data:/opt/sinusbot/data
          - ./sinusbot/config.ini:/opt/sinusbot/config.ini:ro
        networks:
          - back
networks:
    back:
        driver: bridge
Startlog:
Bash:
sinusbot_1   | Version: 0.14.3-0e747fd
sinusbot_1   | (C) 2013-2018 Michael Friese. All rights reserved.
sinusbot_1   |
sinusbot_1   | 2018/10/31 13:46:24 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin advertising.js
sinusbot_1   | 2018/10/31 13:46:24 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin alonemode.js
sinusbot_1   | 2018/10/31 13:46:24 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin bookmark.js
sinusbot_1   | 2018/10/31 13:46:24 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin followme.js
sinusbot_1   | 2018/10/31 13:46:24 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin norecording.js
sinusbot_1   | 2018/10/31 13:46:24 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin rememberChannel.js
sinusbot_1   | 2018/10/31 13:46:24 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin welcome.js
sinusbot_1   | 2018/10/31 13:46:24 a38269c8          INFO   Loading instances
sinusbot_1   | 2018/10/31 13:46:24 a38269c8          INFO   Loading instance://870f4963-5e40-4822-9714-2fa39ee60f50
sinusbot_1   | 2018/10/31 13:46:24 a38269c8 870f4963 INFO   Initialization complete
sinusbot_1   | 2018/10/31 13:46:24 [GENERAL/FFMPEG ] INFO   FFmpeg/avcodec v3741798; license: LGPL version 2.1 or later; 81 codecs
sinusbot_1   | 2018/10/31 13:46:24 [GENERAL/FFMPEG ] INFO   FFmpeg/avformat v3742052; license: LGPL version 2.1 or later; 143 formats
sinusbot_1   | 2018/10/31 13:46:24 [GENERAL/YTDL   ] INFO   youtube-dl checking...
sinusbot_1   | 2018/10/31 13:46:25 [GENERAL/YTDL   ] INFO   youtube-dl version compatible, support enabled
sinusbot_1   | 2018/10/31 13:46:25 [GENERAL/!!!!!!!] NOTICE You may now configure and launch the bots from the webinterface. http://0.0.0.0:8087
sinusbot_1   | 2018/10/31 13:46:25 [GENERAL/RADIO  ] INFO   Could not find RadioStation-Data (or outdated), updating...
sinusbot_1   | 2018/10/31 13:46:26 [GENERAL/RADIO  ] ERROR  Could not start request; E01502
config.ini:
INI:
UseSSL = true
SSLKeyFile = "/etc/ssl/certs/bobjunior.at.key"
SSLCertFile = "/etc/ssl/certs/bobjunior.at.crt"
Hostname = "bobjunior.at"
LicenseKey = "nHDRi9SQYHUoqKqdDTyChCve42XaZ+ph5yqkN46B0zA="
IsProxied = true
Konfiguration:
Log beim Starten des Bots:
Bash:
sinusbot_1   | 2018/10/31 13:39:15 a38269c8 870f4963 DEBUG  Prespawn.
sinusbot_1   | 2018/10/31 13:39:15 a38269c8 870f4963 DEBUG  About to run.
sinusbot_1   | 2018/10/31 13:39:15 a38269c8 870f4963 WARN   Could not create Chat-Tabletable Chat already exists
sinusbot_1   | 2018/10/31 13:39:15 a38269c8 870f4963 WARN   Could not create WhisperReceive-Tabletable WhisperReceive already exists
sinusbot_1   | 2018/10/31 13:39:15 a38269c8 870f4963 WARN   Could not create Notifications-Tabletable Notifications already exists
sinusbot_1   | 2018/10/31 13:39:15 a38269c8 870f4963 WARN   Could not delete from Applicationno such table: Application
sinusbot_1   | 2018/10/31 13:39:15 a38269c8 870f4963 WARN   Could not insert into Application-Tableno such table: Application
sinusbot_1   | 2018/10/31 13:39:15 a38269c8 870f4963 DEBUG  Could not delete from FileTransferno such table: FileTransfer
sinusbot_1   | 2018/10/31 13:39:15 a38269c8 870f4963 DEBUG  Could not insert into FileTransfer-Tableno such table: FileTransfer
sinusbot_1   | 2018/10/31 13:39:15 a38269c8 870f4963 WARN   Could not delete from Profilesno such table: Profiles
sinusbot_1   | 2018/10/31 13:39:15 a38269c8 870f4963 WARN   Could not insert into Profiles-Tableno such table: Profiles
sinusbot_1   | 2018/10/31 13:39:15 a38269c8 870f4963 DEBUG  Could not delete from Newsno such table: News
sinusbot_1   | 2018/10/31 13:39:15 a38269c8 870f4963 DEBUG  Could not insert into News-Tableno such table: News
sinusbot_1   | 2018/10/31 13:39:16 a38269c8 870f4963 INFO   Starting instance ts3server://teamspeak3_teamspeak_1?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
sinusbot_1   | 2018/10/31 13:39:16 X [MAIN] New connection
sinusbot_1   | 2018/10/31 13:39:17 a38269c8 870f4963 DEBUG  Storing configuration.
Log beim Beenden:
Bash:
sinusbot_1   | 2018/10/31 13:41:08 a38269c8 870f4963 WARN   Could not request shutdown. Please make sure that the plugin is installed correctly; HTTP returned an error: Timeout; Code: 500; Message: Timeout
sinusbot_1   | 2018/10/31 13:41:09 a38269c8 870f4963 INFO   KILL [admin] OK
sinusbot_1   | 2018/10/31 13:41:09 a38269c8 870f4963 DEBUG  TS>QCoreApplication::applicationDirPath: Please instantiate the QApplication object first
sinusbot_1   | 2018/10/31 13:41:09 a38269c8 870f4963 DEBUG  TS>QXcbIntegration: Cannot create platform OpenGL context, neither GLX nor EGL are enabled
sinusbot_1   | 2018/10/31 13:41:09 a38269c8 870f4963 INFO   TSClient quit.
sinusbot_1   | 2018/10/31 13:41:09 a38269c8 870f4963 DEBUG  Closed.
sinusbot_1   | 2018/10/31 13:41:17 a38269c8 870f4963 DEBUG  Storing configuration.
sinusbot_1   | echo: http: TLS handshake error from 127.0.0.1:50330: tls: first record does not look like a TLS handshake
Hab mal selbst nachgebaut, auch mit offiziellen teamspeak docker image. Das hier funktioniert:
version: '2'
services:
  teamspeak:
    image: teamspeak
    restart: always
    ports:
      - 9987:9987/udp
      - 10011:10011
      - 30033:30033
    environment:
      TS3SERVER_LICENSE: accept
    networks:
      mynetwork:
        aliases:
          - teamspeak.docker.local
  sinusbot:
    restart: always
    ports:
      - 8087:8087
    volumes:
      - ./scripts:/opt/sinusbot/scripts
      - ./data:/opt/sinusbot/data
    networks:
     - mynetwork
networks:
    mynetwork:
        driver: bridge
Liegt dran, dass der TeamSpeak³ Client eine vollen hostname + Domain braucht, sodass er das auflösen kann. In meinem Fall siehe oben "teamspeak.docker.local". Das funktioniert auch, gerade getestet.
lennard7001
Ich verwende diese docker-compose.yml und verbinde mich im webpanel per localhost.
YAML:
version: '3.1'
volumes:
  teamspeak:
services:
  app:
    image: teamspeak
    restart: always
    ports:
      - 9987:9987/udp
      - 10011:10011
      - 30033:30033
    volumes:
      - teamspeak:/var/ts3server/
    environment:
  bot:
    ports:
      - 80:8087
    volumes:
      - ./bot1/scripts:/opt/sinusbot/scripts
      - ./bot1/data:/opt/sinusbot/data
