Andrew Fox
Hello everyone.
I've been trying to get the SirusBot on my Debian VPS but struggling so far.
Printscreen of the putty's console from bot startup till running it from the web front end.
http://prntscr.com/be0272
Here's the info:
- Bot version: 0.9.12.2-58b509d
- OS: Debian 7
- Specs:
- My config.ini
And finally the diagonisis tool result.
Here's the info:
- OS: Debian 7
- Specs:
- KVM OpenStack
- 1 vCore
- 2,4 GHz
- 2 GB RAM
- SSD 10 GB
Local Raid 10
- My config.ini
ListenHost = "MY VPS IPS HERE"
LocalPlayback = true
EnableDebugConsole = true
LicenseKey = "NVHuV+5MN2MVpRxsjwsCBUMx8PWIrgS5LVgdJELwTl8="
UserAgent = "SinusBot (0.9.12-58b509d)"
- Operating System: Debian GNU/Linux 7.9 (wheezy)
- Kernel: Linux 3.2.0-4-amd64 x86_64
- Load Average: 0.00 0.04 0.10
- Uptime: 93 days, 4 hours, 24 minutes, 49 seconds
- OS Updates: 37 (updates available!)
- OS APT Last Update: 08.06.2016 21:17:14 CEST +02:00:00
CPU(s): 1
Thread(s) per core: 1
Core(s) per socket: 1
Socket(s): 1
CPU MHz: 2394.444
Virtualization: VT-x
Hypervisor vendor: KVM
Virtualization type: full
- RAM: B/1.91 GB in use (%)
- SWAP: B/ B in use (%)
- DISK: 2.12 GB/7.21 GB in use (29%)
> libglib: 2.33.12+really2.32.4-5
- Status: running (PIDs: 3892 3891, User: root)
- Binary: /opt/ts3soundboard/sinusbot (Hash: 8b94daaaf3ffd829669e70a3c6a5843d)
- Version: 0.9.12-58b509d
- Bot Plugin: 2c207af25e3000543d85b5f4275ef053
- TS3 Client: 2c207af25e3000543d85b5f4275ef053
- TS3Path = /opt/ts3soundboard/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64 (Version 3.0.19.1)
- YoutubeDLPath = not set
- Report date: 08.06.2016 21:28:05 CEST +02:00:00 (timezone: )
- TeamSpeak 3 Version: 3.0.19.1
- youtube-dl Version: unknown
- DiagScript version: 0.4.5
