NeoXen
Hey all,
i know there are like thousands of other posts regarding this issue, but none of them really helped me out.
Every time i try to start the bot i get this error:
Running it as a non-root user didn't help, even downgrading to TS 3.0.18.2 didn't help.
The web-interface is working, the bot is just not connecting to my server.
The bot is running on a ubuntu-vps, so when i try to start the ts-client, it says:
Would be nice if anyone knows how to work around this error
Thanks in advance!
This is the output from the diag-tool:
root@vps:/home/musicbot/MusicBot# ./ts3bot -RunningAsRootIsEvilAndIKnowThat
2016/08/02 05:52:50 !!!!!!! YOU ARE RUNNING THE BOT AS UID 0 (ROOT) WITHOUT HAVING SET ANOTHER UID. THIS IS A SERIOUS SECURITY VIOLATION !!!!!!!!
2016/08/02 05:52:50 a899a74f INFO Initializing bot://a899a74f-2d11-4c8d-a49c-5801e589a596
2016/08/02 05:52:50 a899a74f c5942aa2 INFO Loaded
2016/08/02 05:52:50 FFmpeg/avcodec v3675236; license: LGPL version 2.1 or later; 494 codecs
2016/08/02 05:52:50 FFmpeg/avformat v3674980; license: LGPL version 2.1 or later; 139 formats
2016/08/02 05:52:50 a899a74f c5942aa2 INFO Starting instance ts3server://ts.neoxen.de?port=9987&nickname=Music-Bot&password=&channel=&channelpassword=
2016/08/02 05:52:50 a899a74f c5942aa2 INFO TSClient quit.
2016/08/02 05:52:50 RadioStation data loaded
2016/08/02 05:52:51 Imported radio stations
2016/08/02 05:52:55 a899a74f c5942aa2 WARN Could not request shutdown
root@vps:~/TeamSpeak-Client/TeamSpeak3-Client-linux_amd64# sh ts3client_runscript.sh
QXcbConnection: Could not connect to display
Aborted
Thanks in advance!
- Operating System: Ubuntu 16.04.1 LTS (OpenVZ)
- Kernel: Linux 2.6.32-042stab111.12 x86_64
- Load Average: 0.24 0.22 0.17
- Uptime: 1 days, 15 hours, 48 minutes, 4 seconds
- OS APT Last Update: 31.07.2016 13:49:43 EDT -04:00:00
- RAM: B/4.00 GB in use (%)
- SWAP: B/ B in use (%)
- DISK: 2.29 GB/197.70 GB in use (1%)
> libglib: 2.48.1-1~ubuntu16.04.1
- Status: running (PIDs: 15767, User: root)
- Binary: /home/musicbot/MusicBot/ts3bot (Hash: 3b2c7f99a3b0a358e7d328079c4fa8b8)
- Version:
- TS3Path = /home/musicbot/TeamSpeak-Client/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64 (Version 3.0.19.4)
- YoutubeDLPath = not set
- Report date: 02.08.2016 05:53:24 EDT -04:00:00 (timezone: America/New_York)
- youtube-dl Version: unknown
- DiagScript version: 0.4.5
