TSClient quit - Error 1797
Floflobel
I have a problem for join a teamspeak server. I try for another ..
Hardware of my vm :
- Debian 8 64bit
- Memory 512 Mb
- Hard disk 20 go
config.ini
LicenseKey = "remove"
  UserAgent = "SinusBot (0.9.12-58b509d)"
Log with dubug lvl 10 :
2016/07/03 17:49:38 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin welcometext.js
2016/07/03 17:49:38 c2fda181          INFO   Loading instances
2016/07/03 17:49:38 c2fda181          INFO   Loading instance://7fdeaaf8-b633-4478-8e55-e666670be2f5
2016/07/03 17:49:38 c2fda181 7fdeaaf8 INFO   Initialization complete
2016/07/03 17:49:38 c2fda181          INFO   Loading instance://da71370f-415d-489b-b373-9b3f2d1caaad
2016/07/03 17:49:38 c2fda181 da71370f INFO   Initialization complete
2016/07/03 17:49:38 [GENERAL/FFMPEG ] INFO   FFmpeg/avcodec v3741798; license: LGPL version 2.1 or later; 81 codecs
2016/07/03 17:49:38 [GENERAL/FFMPEG ] INFO   FFmpeg/avformat v3742052; license: LGPL version 2.1 or later; 143 formats
2016/07/03 17:49:38 [GENERAL/!!!!!!!] NOTICE You may now configure and launch the bots from the webinterface. http://0.0.0.0:8087
2016/07/03 17:49:38 X [MAIN] Starting up fake x-server...
2016/07/03 17:49:38 [GENERAL/RADIO  ] INFO   RadioStation data loaded
2016/07/03 17:49:39 [GENERAL/RADIO  ] INFO   Imported radio stations
2016/07/03 17:49:43 c2fda181 da71370f DEBUG  Could not delete from Notificationsno such table: Notifications
2016/07/03 17:49:43 c2fda181 da71370f DEBUG  Could not insert into Notifications-Tableno such table: Notifications
2016/07/03 17:49:43 c2fda181 da71370f INFO   Starting instance ts3server://ts.baylife-roleplay.com?port=9987&nickname=baylife&password=&channel=&channelpassword=
2016/07/03 17:49:43 X [MAIN] New connection
2016/07/03 17:49:43 c2fda181 da71370f DEBUG  TS>Crashdump ENABLED,  directory is: /opt/ts3soundboard/data//ts3/c2fda181-b1da-403d-a455-328d5bb2eaf0/da71370f-415d-489b-b373-9b3f2d1caaad/crashdumps
2016/07/03 17:49:43 c2fda181 da71370f DEBUG  TS>DUMP defined! Dumpdir is: /opt/ts3soundboard/data//ts3/c2fda181-b1da-403d-a455-328d5bb2eaf0/da71370f-415d-489b-b373-9b3f2d1caaad/crashdumps
2016/07/03 17:49:43 c2fda181 da71370f INFO   TS |INFO    |              |   |TeamSpeak 3 Client 3.0.19.3 (2016-06-23 09:02:14)
2016/07/03 17:49:43 c2fda181 da71370f INFO   TS |INFO    |              |   |SystemInformation: Linux 3.16.0-4-amd64 #1 SMP Debian 3.16.7-ckt11-1+deb8u6 (2015-11-09) x86_64 Binary: 64bit
2016/07/03 17:49:43 c2fda181 da71370f INFO   TS |INFO    |              |   |Using hardware aes
2016/07/03 17:49:43 c2fda181 da71370f INFO   TS |ERROR   |SoundBckndIntf|   |libasound.so.2: cannot open shared object file: No such file or directory
2016/07/03 17:49:43 c2fda181 da71370f INFO   TS |ERROR   |SoundBckndIntf|   |libpulse.so.0: cannot open shared object file: No such file or directory
2016/07/03 17:49:43 c2fda181 da71370f INFO   TS |WARNING |SoundDevManager|   |Did not load any sound backends. No (usable) dynamic libraries found.
2016/07/03 17:49:43 c2fda181 da71370f INFO   TS |INFO    |              |   |Loading plugin: libclientquery_plugin
2016/07/03 17:49:43 c2fda181 da71370f INFO   TS |INFO    |              |   |Loading plugin: liblua_plugin
2016/07/03 17:49:43 c2fda181 da71370f INFO   TS |INFO    |              |   |Loading plugin: libsoundbot_plugin
2016/07/03 17:49:43 c2fda181 da71370f INFO   TS |INFO    |              |   |Loading plugin: libtest_plugin
2016/07/03 17:49:43 c2fda181 da71370f INFO   TS |INFO    |Query         |   |listening on 127.0.0.1:25639
2016/07/03 17:49:43 c2fda181 da71370f DEBUG  TS>ClientQueryPlugin: currentServerConnectionChanged 1 (0)
2016/07/03 17:49:43 c2fda181 da71370f INFO   TS |INFO    |ClientUI      |   |Failed to init text to speech engine
2016/07/03 17:49:43 c2fda181 da71370f INFO   TS |INFO    |ClientUI      |   |Qt version: 5.5.1
2016/07/03 17:49:43 c2fda181 da71370f INFO   TS |INFO    |ClientUI      |   |Using configuration location: /opt/ts3soundboard/data//ts3/c2fda181-b1da-403d-a455-328d5bb2eaf0/da71370f-415d-489b-b373-9b3f2d1caaad/settings.db
2016/07/03 17:49:44 c2fda181 da71370f INFO   TS |INFO    |ClientUI      |   |ts3server: ts.baylife-roleplay.com?port=9987&nickname=baylife&password=&channel=&channelpassword=
2016/07/03 17:49:44 c2fda181 da71370f INFO   TS |INFO    |ClientUI      |1  |Connect to server: ts.baylife-roleplay.com
2016/07/03 17:49:44 c2fda181 da71370f INFO   TS |INFO    |ClientUI      |1  |Trying to resolve ts.baylife-roleplay.com
2016/07/03 17:49:44 c2fda181 da71370f INFO   TS |INFO    |TSDNS         |   |DNS resolve successful, "ts.baylife-roleplay.com"=185.38.150.57
2016/07/03 17:49:44 c2fda181 da71370f INFO   TS |INFO    |TSDNS         |   |SRV DNS resolve unsuccessful for "_ts3._udp.ts.baylife-roleplay.com"
2016/07/03 17:49:44 c2fda181 da71370f INFO   TS |INFO    |ClientUI      |   |Last update check was: Sun Jan 1 00:00:01 2017
2016/07/03 17:49:44 c2fda181 da71370f INFO   TS |INFO    |ClientUI      |   |Checking for update
2016/07/03 17:49:44 c2fda181 da71370f INFO   TS |INFO    |Update        |   |Checking for updates...
2016/07/03 17:49:44 c2fda181 da71370f INFO   TS |INFO    |Update        |   |Check license version: 1
2016/07/03 17:49:44 c2fda181 da71370f INFO   TS |INFO    |LicenseViewer |   |License language: en
2016/07/03 17:49:44 c2fda181 da71370f INFO   TS |INFO    |LicenseViewer |   |Found cached license for version 1 and language en
2016/07/03 17:49:48 c2fda181 da71370f INFO   TS |INFO    |ClientUI      |1  |Lookup finished: 185.38.150.57 9987 ts.baylife-roleplay.com 0 0
2016/07/03 17:49:48 c2fda181 da71370f INFO   TS |INFO    |ClientUI      |1  |Resolve successful: 185.38.150.57:9987
2016/07/03 17:49:48 c2fda181 da71370f INFO   TS |INFO    |ClientUI      |1  |Blacklist check ok
2016/07/03 17:49:48 c2fda181 da71370f INFO   TS |INFO    |ClientUI      |1  |Initiating connection: 185.38.150.57:9987 ts.baylife-roleplay.com
2016/07/03 17:49:48 c2fda181 da71370f INFO   TS |INFO    |PreProSpeex   |1  |Speex version: 1.2rc1
2016/07/03 17:49:48 c2fda181 da71370f INFO   TS |INFO    |ClientUI      |1  |Connect status: Connecting
2016/07/03 17:49:48 c2fda181 da71370f INFO   New connection status 1; Error 0
2016/07/03 17:49:53 c2fda181 da71370f INFO   TS |INFO    |ClientUI      |1  |Connect status: Disconnected
2016/07/03 17:49:53 c2fda181 da71370f INFO   TS |INFO    |ClientUI      |1  |Failed to connect to server, want autoreconnect = 0
2016/07/03 17:49:53 c2fda181 da71370f INFO   The bot could not connect. This might have several reasons: the server doesn't exist at that address, the server password is wrong, the default channel doesn't exist or the password is wrong or the security level of your identity is too low.
2016/07/03 17:49:53 c2fda181 da71370f INFO   New connection status 0; Error 1797
2016/07/03 17:49:53 c2fda181 da71370f INFO   TS |INFO    |ClientUI      |   |Blacklist check timeout
2016/07/03 17:49:54 c2fda181 da71370f DEBUG  TS>libpng warning: iCCP: known incorrect sRGB profile
2016/07/03 17:49:54 c2fda181 da71370f DEBUG  TS>QObject::connect: Cannot connect (null)::stateChanged(QNetworkSession::State) to QNetworkReplyHttpImpl::_q_networkSessionStateChanged(QNetworkSession::State)
2016/07/03 17:49:54 c2fda181 da71370f DEBUG  TS>warning: The VAD has been replaced by a hack pending a complete rewrite
2016/07/03 17:49:54 c2fda181 da71370f DEBUG  EOF
2016/07/03 17:49:54 c2fda181 da71370f INFO   TSClient quit.
iTaskmanager
Tier II
Tier I
That's the problem.
Floflobel
1. Is the lastest version install
2. I install already "Client 64-bit 3.0.19.3"
3. Lastest update install on my debian
Floflobel
I try again to copy plugin with "cp plugin/libsoundbot_plugin.so /opt/ts3soundboard/TeamSpeak3-Client-linux_amd64/plugins"
In the log file, the sinusbot resolve the DNS of my TS but no connect ..
I try another serveur, I have the same log file.
2016/07/04 10:14:24 c2fda181 da71370f INFO   TS |INFO    |ClientUI      |1  |Res        olve successful: 5.39.69.193:9987
2016/07/04 10:14:24 c2fda181 da71370f INFO   TS |INFO    |ClientUI      |1  |Bla        cklist check ok
2016/07/04 10:14:24 c2fda181 da71370f INFO   TS |INFO    |ClientUI      |1  |Ini        tiating connection: 5.39.69.193:9987 ts.omega-network.fr
2016/07/04 10:14:24 c2fda181 da71370f INFO   TS |INFO    |PreProSpeex   |1  |Spe        ex version: 1.2rc1
2016/07/04 10:14:24 c2fda181 da71370f INFO   TS |INFO    |ClientUI      |1  |Con        nect status: Connecting
2016/07/04 10:14:24 c2fda181 da71370f INFO   New connection status 1; Error 0
2016/07/04 10:14:29 c2fda181 da71370f INFO   TS |INFO    |ClientUI      |1  |Connect status: Disconnected
2016/07/04 10:14:29 c2fda181 da71370f INFO   TS |INFO    |ClientUI      |1  |Failed to connect to server, want autoreconnect = 0
2016/07/04 10:14:29 c2fda181 da71370f INFO   The bot could not connect. This might have several reasons: the server doesn't exist at that address, the server password is wrong, the default channel doesn't exist or the password is wrong or the security level of your identity is too low.
2016/07/04 10:14:29 c2fda181 da71370f INFO   New connection status 0; Error 1797
2016/07/04 10:14:29 c2fda181 da71370f INFO   TS |INFO    |ClientUI      |   |Blacklist check timeout
2016/07/04 10:14:30 c2fda181 da71370f DEBUG  TS>libpng warning: iCCP: known incorrect sRGB profile
2016/07/04 10:14:30 c2fda181 da71370f DEBUG  TS>QObject::connect: Cannot connect (null)::stateChanged(QNetworkSession::State) to QNetworkReplyHttpImpl::_q_networkSessionStateChanged(QNetworkSession::State)
2016/07/04 10:14:30 c2fda181 da71370f DEBUG  TS>warning: The VAD has been replaced by a hack pending a complete rewrite
2016/07/04 10:14:30 c2fda181 da71370f DEBUG  EOF
2016/07/04 10:14:30 c2fda181 da71370f INFO   TSClient quit.
2016/07/04 10:14:47 c2fda181 da71370f DEBUG  Storing configuration.
Floflobel
root@debian-vpn:/opt/ts3soundboard# ./sinusbot -RunningAsRootIsEvilAndIKnowThat
2016/07/04 10:37:15 [GENERAL/!!!!!!!] WARN   !!!!!!! YOU ARE RUNNING THE BOT AS UID 0 (ROOT) WITHOUT HAVING SET ANOTHER UID. THIS IS A SERIOUS SECURITY VIOLATION !!!!!!!!
Version: 0.9.12-58b509d
2016/07/04 10:37:15 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin advertising.js
2016/07/04 10:37:15 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin aloneMode.js
2016/07/04 10:37:15 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin badchan.js
2016/07/04 10:37:15 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin bookmark.js
2016/07/04 10:37:15 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin covatar.js
2016/07/04 10:37:15 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin dev.js
2016/07/04 10:37:15 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin followme.js
2016/07/04 10:37:15 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin idle.js
2016/07/04 10:37:15 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin metadata.js
2016/07/04 10:37:15 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin norecording.js
2016/07/04 10:37:15 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin rememberChannel.js
2016/07/04 10:37:15 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin showcase.js
2016/07/04 10:37:15 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin sound.js
2016/07/04 10:37:15 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin welcometext.js
2016/07/04 10:37:15 X [MAIN] Starting up fake x-server...
2016/07/04 10:37:15 c2fda181          INFO   Loading instances
2016/07/04 10:37:15 c2fda181          INFO   Loading instance://da71370f-415d-489b-b373-9b3f2d1caaad
2016/07/04 10:37:15 c2fda181 da71370f INFO   Initialization complete
2016/07/04 10:37:15 c2fda181          INFO   Loading instance://7fdeaaf8-b633-4478-8e55-e666670be2f5
2016/07/04 10:37:15 c2fda181 7fdeaaf8 INFO   Initialization complete
2016/07/04 10:37:15 [GENERAL/FFMPEG ] INFO   FFmpeg/avcodec v3741798; license: LGPL version 2.1 or later; 81 codecs
2016/07/04 10:37:15 [GENERAL/FFMPEG ] INFO   FFmpeg/avformat v3742052; license: LGPL version 2.1 or later; 143 formats
2016/07/04 10:37:15 [GENERAL/!!!!!!!] NOTICE You may now configure and launch the bots from the webinterface. http://0.0.0.0:8087
2016/07/04 10:37:15 [GENERAL/RADIO  ] INFO   RadioStation data loaded
2016/07/04 10:37:15 [GENERAL/RADIO  ] INFO   Imported radio stations
2016/07/04 10:37:18 c2fda181          DEBUG  Added EVListener
2016/07/04 10:38:36 c2fda181 da71370f DEBUG  Could not delete from Notificationsno such table: Notifications
2016/07/04 10:38:36 c2fda181 da71370f DEBUG  Could not insert into Notifications-Tableno such table: Notifications
2016/07/04 10:38:36 c2fda181 da71370f INFO   Starting instance ts3server://ts.omega-network.fr?port=9987&nickname=omega-network&password=&channel=&channelpassword=
2016/07/04 10:38:36 X [MAIN] New connection
2016/07/04 10:38:36 c2fda181 da71370f DEBUG  TS>Crashdump ENABLED,  directory is: /opt/ts3soundboard/data//ts3/c2fda181-b1da-403d-a455-328d5bb2eaf0/da71370f-415d-489b-b373-9b3f2d1caaad/crashdumps
2016/07/04 10:38:36 c2fda181 da71370f DEBUG  TS>DUMP defined! Dumpdir is: /opt/ts3soundboard/data//ts3/c2fda181-b1da-403d-a455-328d5bb2eaf0/da71370f-415d-489b-b373-9b3f2d1caaad/crashdumps
2016/07/04 10:38:36 c2fda181 da71370f INFO   TS |INFO    |              |   |TeamSpeak 3 Client 3.0.19.3 (2016-06-23 09:02:14)
2016/07/04 10:38:36 c2fda181 da71370f INFO   TS |INFO    |              |   |SystemInformation: Linux 3.16.0-4-amd64 #1 SMP Debian 3.16.7-ckt25-2+deb8u2 (2016-06-25) x86_64 Binary: 64bit
2016/07/04 10:38:36 c2fda181 da71370f INFO   TS |INFO    |              |   |Using hardware aes
2016/07/04 10:38:36 c2fda181 da71370f INFO   TS |ERROR   |SoundBckndIntf|   |libasound.so.2: cannot open shared object file: No such file or directory
2016/07/04 10:38:36 c2fda181 da71370f INFO   TS |ERROR   |SoundBckndIntf|   |libpulse.so.0: cannot open shared object file: No such file or directory
2016/07/04 10:38:36 c2fda181 da71370f INFO   TS |WARNING |SoundDevManager|   |Did not load any sound backends. No (usable) dynamic libraries found.
2016/07/04 10:38:36 c2fda181 da71370f INFO   TS |INFO    |              |   |Loading plugin: libclientquery_plugin
2016/07/04 10:38:36 c2fda181 da71370f INFO   TS |INFO    |              |   |Loading plugin: liblua_plugin
2016/07/04 10:38:36 c2fda181 da71370f INFO   TS |INFO    |              |   |Loading plugin: libsoundbot_plugin
2016/07/04 10:38:36 c2fda181 da71370f INFO   TS |INFO    |              |   |Loading plugin: libtest_plugin
2016/07/04 10:38:36 c2fda181 da71370f INFO   TS |INFO    |Query         |   |listening on 127.0.0.1:25639
2016/07/04 10:38:36 c2fda181 da71370f DEBUG  TS>ClientQueryPlugin: currentServerConnectionChanged 1 (0)
2016/07/04 10:38:36 c2fda181 da71370f INFO   TS |INFO    |ClientUI      |   |Failed to init text to speech engine
2016/07/04 10:38:36 c2fda181 da71370f INFO   TS |INFO    |ClientUI      |   |Qt version: 5.5.1
2016/07/04 10:38:36 c2fda181 da71370f INFO   TS |INFO    |ClientUI      |   |Using configuration location: /opt/ts3soundboard/data//ts3/c2fda181-b1da-403d-a455-328d5bb2eaf0/da71370f-415d-489b-b373-9b3f2d1caaad/settings.db
2016/07/04 10:38:37 c2fda181 da71370f INFO   TS |INFO    |ClientUI      |   |ts3server: ts.omega-network.fr?port=9987&nickname=omega-network&password=&channel=&channelpassword=
2016/07/04 10:38:37 c2fda181 da71370f INFO   TS |INFO    |ClientUI      |1  |Connect to server: ts.omega-network.fr
2016/07/04 10:38:37 c2fda181 da71370f INFO   TS |INFO    |ClientUI      |1  |Trying to resolve ts.omega-network.fr
2016/07/04 10:38:37 c2fda181 da71370f INFO   TS |INFO    |TSDNS         |   |DNS resolve successful, "ts.omega-network.fr"=5.39.69.193
2016/07/04 10:38:37 c2fda181 da71370f INFO   TS |INFO    |TSDNS         |   |SRV DNS resolve unsuccessful for "_ts3._udp.ts.omega-network.fr"
2016/07/04 10:38:37 c2fda181 da71370f INFO   TS |INFO    |ClientUI      |   |Last update check was: Sun Jan 1 00:00:01 2017
2016/07/04 10:38:37 c2fda181 da71370f INFO   TS |INFO    |ClientUI      |   |Checking for update
2016/07/04 10:38:37 c2fda181 da71370f INFO   TS |INFO    |Update        |   |Checking for updates...
2016/07/04 10:38:37 c2fda181 da71370f INFO   TS |INFO    |Update        |   |Check license version: 1
2016/07/04 10:38:37 c2fda181 da71370f INFO   TS |INFO    |LicenseViewer |   |License language: en
2016/07/04 10:38:37 c2fda181 da71370f INFO   TS |INFO    |LicenseViewer |   |Found cached license for version 1 and language en
2016/07/04 10:38:41 c2fda181 da71370f INFO   TS |INFO    |ClientUI      |1  |Lookup finished: 5.39.69.193 9987 ts.omega-network.fr 0 0
2016/07/04 10:38:41 c2fda181 da71370f INFO   TS |INFO    |ClientUI      |1  |Resolve successful: 5.39.69.193:9987
2016/07/04 10:38:41 c2fda181 da71370f INFO   TS |INFO    |ClientUI      |1  |Blacklist check ok
2016/07/04 10:38:41 c2fda181 da71370f INFO   TS |INFO    |ClientUI      |1  |Initiating connection: 5.39.69.193:9987 ts.omega-network.fr
2016/07/04 10:38:41 c2fda181 da71370f INFO   TS |INFO    |PreProSpeex   |1  |Speex version: 1.2rc1
2016/07/04 10:38:41 c2fda181 da71370f INFO   TS |INFO    |ClientUI      |1  |Connect status: Connecting
2016/07/04 10:38:41 c2fda181 da71370f INFO   New connection status 1; Error 0
2016/07/04 10:38:41 c2fda181 da71370f DEBUG  Storing configuration.
2016/07/04 10:38:46 c2fda181 da71370f INFO   TS |INFO    |ClientUI      |1  |Connect status: Disconnected
2016/07/04 10:38:46 c2fda181 da71370f INFO   TS |INFO    |ClientUI      |1  |Failed to connect to server, want autoreconnect = 0
2016/07/04 10:38:46 c2fda181 da71370f INFO   The bot could not connect. This might have several reasons: the server doesn't exist at that address, the server password is wrong, the default channel doesn't exist or the password is wrong or the security level of your identity is too low.
2016/07/04 10:38:46 c2fda181 da71370f INFO   New connection status 0; Error 1797
2016/07/04 10:38:46 c2fda181 da71370f INFO   TS |INFO    |ClientUI      |   |Blacklist check timeout
2016/07/04 10:38:47 c2fda181 da71370f DEBUG  TS>libpng warning: iCCP: known incorrect sRGB profile
2016/07/04 10:38:47 c2fda181 da71370f DEBUG  TS>QObject::connect: Cannot connect (null)::stateChanged(QNetworkSession::State) to QNetworkReplyHttpImpl::_q_networkSessionStateChanged(QNetworkSession::State)
2016/07/04 10:38:47 c2fda181 da71370f DEBUG  TS>warning: The VAD has been replaced by a hack pending a complete rewrite
2016/07/04 10:38:47 c2fda181 da71370f DEBUG  EOF
2016/07/04 10:38:47 c2fda181 da71370f INFO   TSClient quit.
2016/07/04 10:39:10 c2fda181 da71370f DEBUG  Storing configuration.
Floflobel
- Operating System: Debian GNU/Linux 8.5 (jessie)
- Load Average: 0.08 0.03 0.05
- Uptime: 0 days, 0 hours, 33 minutes, 36 seconds
- OS APT Last Update: 04.07.2016 10:11:50 CEST +02:00:00
    CPU(s):                1
    Thread(s) per core:    1
    Core(s) per socket:    1
    Socket(s):             1
    Model name:            AMD FX(tm)-8350 Eight-Core Processor
    CPU MHz:               4018.539
    Hypervisor vendor:     VMware
    Virtualization type:   full
- RAM: 84.50 MB/480.94 MB in use (17%)
- SWAP: 0 B/671.99 MB in use (0%)
- DISK: 1.23 GB/16.54 GB in use (7%)
   > libglib: 2.42.1-1+b1
- Binary: /opt/ts3soundboard/sinusbot (Hash: 8b94daaaf3ffd829669e70a3c6a5843d)
- Version: 0.9.12-58b509d
   - Bot Plugin: 2c207af25e3000543d85b5f4275ef053
   - TS3 Client: 2c207af25e3000543d85b5f4275ef053
   - TS3Path = /opt/ts3soundboard/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64 (Version 3.0.19.3)
   - YoutubeDLPath = not set
- Report date: 04.07.2016 10:44:04 CEST +02:00:00 (timezone: Europe/Paris)
- TeamSpeak 3 Version: 3.0.19.3
- youtube-dl Version: unknown
- DiagScript version: 0.4.5
Floflobel
I try on the last server and another.
It's possible the firewall block ?
2016/07/04 13:21:15 55efd3b6 1d0f172e INFO   Starting instance ts3server://ts.badlion.net?port=9987&nickname=TS3SB-Demobot&password=&channel=&channelpassword=
2016/07/04 13:21:15 X [MAIN] New connection
2016/07/04 13:21:15 55efd3b6 1d0f172e INFO   TS |INFO    |              |   |TeamSpeak 3 Client 3.0.19.3 (2016-06-23 09:02:14)
2016/07/04 13:21:15 55efd3b6 1d0f172e INFO   TS |INFO    |              |   |SystemInformation: Linux 3.16.0-4-amd64 #1 SMP Debian 3.16.7-ckt25-2+deb8u2 (2016-06-25) x86_64 Binary: 64bit
2016/07/04 13:21:15 55efd3b6 1d0f172e INFO   TS |INFO    |              |   |Using hardware aes
2016/07/04 13:21:15 55efd3b6 1d0f172e INFO   TS |ERROR   |SoundBckndIntf|   |libasound.so.2: cannot open shared object file: No such file or directory
2016/07/04 13:21:15 55efd3b6 1d0f172e INFO   TS |ERROR   |SoundBckndIntf|   |libpulse.so.0: cannot open shared object file: No such file or directory
2016/07/04 13:21:15 55efd3b6 1d0f172e INFO   TS |WARNING |SoundDevManager|   |Did not load any sound backends. No (usable) dynamic libraries found.
2016/07/04 13:21:15 55efd3b6 1d0f172e INFO   TS |INFO    |              |   |Loading plugin: libclientquery_plugin
2016/07/04 13:21:15 55efd3b6 1d0f172e INFO   TS |INFO    |              |   |Loading plugin: liblua_plugin
2016/07/04 13:21:15 55efd3b6 1d0f172e INFO   TS |INFO    |              |   |Loading plugin: libsoundbot_plugin
2016/07/04 13:21:15 55efd3b6 1d0f172e INFO   TS |INFO    |              |   |Loading plugin: libtest_plugin
2016/07/04 13:21:15 55efd3b6 1d0f172e INFO   TS |INFO    |Query         |   |listening on 127.0.0.1:25639
2016/07/04 13:21:15 55efd3b6 1d0f172e INFO   TS |INFO    |ClientUI      |   |Failed to init text to speech engine
2016/07/04 13:21:15 55efd3b6 1d0f172e INFO   TS |INFO    |ClientUI      |   |Qt version: 5.5.1
2016/07/04 13:21:15 55efd3b6 1d0f172e INFO   TS |INFO    |ClientUI      |   |Using configuration location: /opt/sinusbot/data//ts3/55efd3b6-62af-4352-9443-5be4705b81c4/1d0f172e-0675-40aa-980b-082a911246f6/settings.db
2016/07/04 13:21:16 55efd3b6 1d0f172e INFO   TS |INFO    |ClientUI      |   |ts3server: ts.badlion.net?port=9987&nickname=TS3SB-Demobot&password=&channel=&channelpassword=
2016/07/04 13:21:16 55efd3b6 1d0f172e INFO   TS |INFO    |ClientUI      |1  |Connect to server: ts.badlion.net
2016/07/04 13:21:16 55efd3b6 1d0f172e INFO   TS |INFO    |ClientUI      |1  |Trying to resolve ts.badlion.net
2016/07/04 13:21:16 55efd3b6 1d0f172e INFO   TS |INFO    |TSDNS         |   |DNS resolve successful, "ts.badlion.net"=158.69.57.27
2016/07/04 13:21:16 55efd3b6 1d0f172e INFO   TS |INFO    |TSDNS         |   |SRV DNS resolve unsuccessful for "_ts3._udp.ts.badlion.net"
2016/07/04 13:21:16 55efd3b6 1d0f172e INFO   TS |INFO    |ClientUI      |   |Last update check was: Sun Jan 1 00:00:01 2017
2016/07/04 13:21:16 55efd3b6 1d0f172e INFO   TS |INFO    |ClientUI      |   |Checking for update
2016/07/04 13:21:16 55efd3b6 1d0f172e INFO   TS |INFO    |Update        |   |Checking for updates...
2016/07/04 13:21:16 55efd3b6 1d0f172e INFO   TS |INFO    |Update        |   |Check license version: 1
2016/07/04 13:21:16 55efd3b6 1d0f172e INFO   TS |INFO    |LicenseViewer |   |License language: en
2016/07/04 13:21:16 55efd3b6 1d0f172e INFO   TS |INFO    |LicenseViewer |   |Found cached license for version 1 and language en
2016/07/04 13:21:20 55efd3b6 1d0f172e INFO   TS |INFO    |ClientUI      |1  |Lookup finished: 158.69.57.27 9987 ts.badlion.net 0 0
2016/07/04 13:21:20 55efd3b6 1d0f172e INFO   TS |INFO    |ClientUI      |1  |Resolve successful: 158.69.57.27:9987
2016/07/04 13:21:20 55efd3b6 1d0f172e INFO   TS |INFO    |ClientUI      |1  |Blacklist check ok
2016/07/04 13:21:20 55efd3b6 1d0f172e INFO   TS |INFO    |ClientUI      |1  |Initiating connection: 158.69.57.27:9987 ts.badlion.net
2016/07/04 13:21:20 55efd3b6 1d0f172e INFO   TS |INFO    |PreProSpeex   |1  |Speex version: 1.2rc1
2016/07/04 13:21:20 55efd3b6 1d0f172e INFO   TS |INFO    |ClientUI      |1  |Connect status: Connecting
2016/07/04 13:21:20 55efd3b6 1d0f172e INFO   New connection status 1; Error 0
2016/07/04 13:21:25 55efd3b6 1d0f172e INFO   TS |INFO    |ClientUI      |1  |Connect status: Disconnected
2016/07/04 13:21:25 55efd3b6 1d0f172e INFO   TS |INFO    |ClientUI      |1  |Failed to connect to server, want autoreconnect = 0
2016/07/04 13:21:25 55efd3b6 1d0f172e INFO   The bot could not connect. This might have several reasons: the server doesn't exist at that address, the server password is wrong, the default channel doesn't exist or the password is wrong or the security level of your identity is too low.
2016/07/04 13:21:25 55efd3b6 1d0f172e INFO   New connection status 0; Error 1797
2016/07/04 13:21:25 55efd3b6 1d0f172e INFO   TS |INFO    |ClientUI      |   |Blacklist check timeout
2016/07/04 13:21:26 55efd3b6 1d0f172e INFO   TSClient quit.
