TSClient quit - "invalid playback device" [SinusBot 0.9.9]
arlextra
Hello, I instaled the SinusBot 0.9.9 on my vps but when I start bot on the web interface the console give me an error and the bot don't join Teamspeak server.
On the same server I have already installed ts3bot 0.9.5 and 0.9.8 without any problems.
2015/08/30 22:36:00 bd554cda 2d53226f DEBUG  Could not delete from Notificationsno such table: Notifications
2015/08/30 22:36:00 bd554cda 2d53226f DEBUG  Could not insert into Notifications-Tableno such table: Notifications
2015/08/30 22:36:00 bd554cda 2d53226f INFO   Starting instance ts3server://******?port=10032&nickname=Bot%20yolo&password=&channel=&channelpassword=
2015/08/30 22:36:00 X [MAIN] New connection
2015-08-30 22:36:00.854268|INFO    |              |   | TeamSpeak 3 Client 3.0.16 (2014-08-04 13:42:43)
2015-08-30 22:36:00.854432|INFO    |              |  2015/08/30 22:36:51 bd554cda 2d53226f DEBUG  Could not delete from Notificationsno such table: Notifications
2015/08/30 22:36:51 bd554cda 2d53226f DEBUG  Could not insert into Notifications-Tableno such table: Notifications
2015/08/30 22:36:51 bd554cda 2d53226f INFO   Starting instance ts3server://*******?port=10032&nickname=Bot%20yolo&password=&channel=&channelpassword=
2015/08/30 22:36:51 X [MAIN] New connection
2015-08-30 22:36:51.481415|INFO    |              |   | TeamSpeak 3 Client 3.0.16 (2014-08-04 13:42:43)
2015-08-30 22:36:51.481550|INFO    |              |   | SystemInformation: Linux 2.6.32-042stab108.8 #1 SMP Wed Jul 22 17:23:23 MSK 2015 x86_64 Binary: 64bit
2015-08-30 22:36:51.481580|INFO    |              |   | Using hardware aes
2015-08-30 22:36:51.482364|ERROR   |SoundBckndIntf|   | libpulse.so.0: cannot open shared object file: No such file or directory
2015-08-30 22:36:51.482537|ERROR   |SoundBckndIntf|   | libasound.so.2: cannot open shared object file: No such file or directory
2015-08-30 22:36:51.482586|WARNING |SoundDevManager|   | Did not load any sound backends. No (usable) dynamic libraries found.
2015-08-30 22:36:51.505335|INFO    |              |   | Loading plugin: libappscanner_plugin
2015-08-30 22:36:51.505420|INFO    |              |   | Loading plugin: libclientquery_plugin
2015-08-30 22:36:51.505447|INFO    |              |   | Loading plugin: liblua_plugin
2015-08-30 22:36:51.505475|INFO    |              |   | Loading plugin: libsoundbot_plugin
2015-08-30 22:36:51.505508|INFO    |              |   | Loading plugin: libtest_plugin
2015-08-30 22:36:51.508277|INFO    |Query         |   | listening on 127.0.0.1:25639
2015-08-30 22:36:51.621991|INFO    |              |   | *** Time [MAINWINDOW]: 120
2015-08-30 22:36:51.622179|INFO    |              |   | *** Time [INIT]: 120
2015-08-30 22:36:51.627079|INFO    |ClientUI      |   | Failed to init text to speech engine
2015-08-30 22:36:51.627290|INFO    |ClientUI      |   | Qt version: 5.2.1
2015-08-30 22:36:51.627356|INFO    |ClientUI      |   | Using configuration location: /opt/sinusbot/data/ts3/bd554cda-1258-4e3c-9e81-8186e74421ae/2d53226f-48de-4373-a3d6-9442adf0dbd6/settings.db
2015-08-30 22:36:51.922432|INFO    |ClientUI      |   | ts3server: *********?port=10032&nickname=Bot%20yolo&password=&channel=&channelpassword=
2015-08-30 22:36:51.923068|INFO    |ClientUI      |  1| Connect to server: *********
2015-08-30 22:36:51.924179|INFO    |ClientUI      |  1| Blacklist check ok
2015-08-30 22:36:51.924241|INFO    |ClientUI      |  1| Initiating connection: *******:10032 *********
2015-08-30 22:36:51.927132|INFO    |PlaySoundSet  |   | Found invalid playback device 'SinusBot', using default device '
2015/08/30 22:36:51 bd554cda 2d53226f INFO   TSClient quit.
2015/08/30 22:36:51 X [MAIN] Disconnected:  3
2015/08/30 22:36:51 X [MAIN] Disconnected:  2
2015/08/30 22:37:05 bd554cda 2d53226f DEBUG  Storing configuration.
You should have got a plugin named "libsoundbot_plugin.so" in the "plugin" folder of the version you have downloaded. You have to move this file to the folder named "plugins" which you will find in the folder of your TeamSpeak Client.
