NUGOSS
installed via the https://sinusbot-installer.de/ script, the installation proceeded normally, but the bot does not start, it enters the server and immediately crashes.
2019-04-29T19:25:24+03:00 TSClient quit.
2019-04-29T19:25:24+03:00 TS |INFO |Integrations | |Requesting integration icon download from https://ts3services.teamspeak.com/integration_icons/twitch/twitch.svg
2019-04-29T19:25:24+03:00 TS |INFO | | |Statistics report: Not yet, next report on Mon May 13 19:06:24 2019
2019-04-29T19:25:24+03:00 TS |INFO |ClientUI | |Last update check was: Sat Jan 1 00:00:01 2022
2019-04-29T19:25:24+03:00 TS |INFO |Bookmarks | |Collecting autoconnect bookmarks
2019-04-29T19:25:24+03:00 New connection status 4; Error 0
2019-04-29T19:25:24+03:00 TS |INFO |PermManager | |Loading permissions from cache
2019-04-29T19:25:24+03:00 TS |INFO |ClientUI |1 |Connect status: Connection established
2019-04-29T19:25:24+03:00 New connection status 3; Error 0
2019-04-29T19:25:24+03:00 TS |INFO |ClientUI |1 |Connect status: Establishing connection
2019-04-29T19:25:24+03:00 New connection status 2; Error 0
2019-04-29T19:25:24+03:00 TS |INFO |ClientUI |1 |Connect status: Connected
2019-04-29T19:25:24+03:00 TS |DEVELOP |PktHandler | |Puzzle solve time: 6
2019-04-29T19:25:24+03:00 New connection status 1; Error 0
2019-04-29T19:25:24+03:00 TS |INFO |ClientUI |1 |Connect status: Connecting
2019-04-29T19:25:24+03:00 TS |INFO |PreProSpeex |1 |Speex version: 1.2rc1
2019-04-29T19:25:24+03:00 TS |INFO |ClientUI |1 |Initiating connection: 127.0.0.1:9987
2019-04-29T19:25:24+03:00 TS |INFO |ClientUI |1 |Connect to server: 127.0.0.1
2019-04-29T19:25:24+03:00 TS |INFO |ClientUI | |ts3server: 127.0.0.1?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2019-04-29T19:25:23+03:00 TS |INFO |ClientUI | |Using configuration location: /opt/sinusbot/data/ts3/da29042c-df68-4f56-8535-512d0d80124e/5d1b94c0-c925-4574-8c87-2d7637350512/settings.db
2019-04-29T19:25:23+03:00 TS |INFO |ClientUI | |Qt version: 5.6.1
2019-04-29T19:25:23+03:00 TS |INFO |ClientUI | |Failed to init text to speech engine
2019-04-29T19:25:23+03:00 TS |DEVELOP |ClientUI | |Notifications init: Soundpack path: /opt/sinusbot/teamspeak3-client/sound/nosounds
2019-04-29T19:25:23+03:00 TS |INFO | | |*** Time [INIT]: 398
2019-04-29T19:25:23+03:00 TS |INFO | | |*** Time [MAINWINDOW]: 398
2019-04-29T19:25:23+03:00 TS |INFO | | |successfully downloaded revocation list for myteamspeak id
2019-04-29T19:25:23+03:00 TS |INFO | | |successfully downloaded revocation list for accounting
2019-04-29T19:25:23+03:00 TS |INFO |Plugins | |Loading plugin: libsoundbot_plugin.so
2019-04-29T19:25:23+03:00 TS |INFO |Addons | |Checking for addon updates...
2019-04-29T19:25:23+03:00 TS |ERROR |RevocationListCache| |Failed to import revocation list from cache
2019-04-29T19:25:23+03:00 TS |INFO |ClientUI | |Unable to create an Open GL context.
2019-04-29T19:25:23+03:00 TS |ERROR |SoundBckndIntf| |/opt/sinusbot/teamspeak3-client/soundbackends/libpulseaudio_linux_amd64.so error: NOT_CONNECTED
2019-04-29T19:25:22+03:00 TS |INFO | | |Using hardware aes
2019-04-29T19:25:22+03:00 TS |INFO | | |SystemInformation: Linux 4.9.0-8-amd64 #1 SMP Debian 4.9.144-3.1 (2019-02-19) x86_64 Binary: 64bit
2019-04-29T19:25:22+03:00 TS |INFO | | |TeamSpeak 3 Client 3.2.5 (2019-04-17 16:07:33)
2019-04-29T19:25:22+03:00 Starting instance ts3server://127.0.0.1?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2019-04-29T19:25:22+03:00 Could not create Notifications-Tabletable Notifications already exists
2019-04-29T19:25:22+03:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
2019-04-29T19:25:22+03:00 Could not create Chat-Tabletable Chat already exists
2019-04-29T19:21:59+03:00 script command loaded
2019-04-29T19:21:59+03:00 unloading instance
2019-04-29T19:21:28+03:00 script command loaded
2019-04-29T19:21:28+03:00 unloading instance
2019-04-29T19:20:10+03:00 script command loaded
2019-04-29T19:20:10+03:00 Initialization complete
LogLevel = 3
ExternalFileBase = ""
LicenseKey = "+Q16fXfYEQn7lMBm1v92aqUgwoK3OiSdgN2HMpDnNAI="
DevMode = false
UserAgent = "SinusBot (1.0.0-beta.1-06a54d7)"
[TTS]
Enabled = false
LogLevel = 3
DevMode = false
[TTS]
Enabled = false
