"TSClient quit"
Lolnarr
So,
ich habe mich bereits durch etliche Forenbeiträge geangelt, dennoch hat keiner davon mein "TSClient quit" Problem gelöst.
Starten tue ich den Bot im Ordner mit ./sinusbot, wodurch das Interface ganz normal startet und auch alles dort funktioniert. Will ich jedoch den Client starten, erhalte ich nur die folgende Fehlermeldung im Log.
2015/12/28 10:03:23 bf6fe9d9 52401e1e DEBUG  Could not delete from Notificationsno such table: Notifications
2015/12/28 10:03:23 bf6fe9d9 52401e1e DEBUG  Could not insert into Notifications-Tableno such table: Notifications
2015/12/28 10:03:23 bf6fe9d9 52401e1e INFO   Starting instance ts3server://ts.playminity.com?port=9987&nickname=Lennarts%20Schepperkiste&password=&channel=&channelpassword=
2015/12/28 10:03:23 X [MAIN] New connection
2015/12/28 10:03:24 bf6fe9d9 52401e1e INFO   TS>Crashdump ENABLED,  directory is: /opt/ts3soundboard/data/ts3/bf6fe9d9-9e1e-4545-a9df-e0cf29d53e81/52401e1e-489a-43cb-8973-2935a2b13bc3/crashdumps
2015/12/28 10:03:24 bf6fe9d9 52401e1e INFO   TS>DUMP defined! Dumpdir is: /opt/ts3soundboard/data/ts3/bf6fe9d9-9e1e-4545-a9df-e0cf29d53e81/52401e1e-489a-43cb-8973-2935a2b13bc3/crashdumps
2015/12/28 10:03:24 bf6fe9d9 52401e1e INFO   TS |INFO    |              |   |TeamSpeak 3 Client 3.0.18.2 (2015-10-22 11:14:48)
2015/12/28 10:03:24 bf6fe9d9 52401e1e INFO   TS |INFO    |              |   |SystemInformation: Linux 2.6.32-042stab111.12 #1 SMP Thu Sep 17 11:38:20 MSK 2015 x86_64 Binary: 64bit
2015/12/28 10:03:24 bf6fe9d9 52401e1e INFO   TS |INFO    |              |   |Using hardware aes
2015/12/28 10:03:24 bf6fe9d9 52401e1e INFO   TS |ERROR   |SoundBckndIntf|   |libasound.so.2: cannot open shared object file: No such file or directory
2015/12/28 10:03:24 bf6fe9d9 52401e1e INFO   TS |ERROR   |SoundBckndIntf|   |libpulse.so.0: cannot open shared object file: No such file or directory
2015/12/28 10:03:24 bf6fe9d9 52401e1e INFO   TS |WARNING |SoundDevManager|   |Did not load any sound backends. No (usable) dynamic libraries found.
2015/12/28 10:03:24 bf6fe9d9 52401e1e INFO   TS>Breakpad crash /opt/ts3soundboard/data/ts3/bf6fe9d9-9e1e-4545-a9df-e0cf29d53e81/52401e1e-489a-43cb-8973-2935a2b13bc3/crashdumps/40888b6c-324c-e7d6-1de120a4-4d5bab85.dmp
2015/12/28 10:03:24 bf6fe9d9 52401e1e INFO   TS>Starting Error Reporter: /opt/ts3soundboard/TeamSpeak3-Client-linux_amd64/error_report
2015/12/28 10:03:24 X [MAIN] Disconnected:  0
2015/12/28 10:03:24 X [MAIN] New connection
2015/12/28 10:03:24 bf6fe9d9 52401e1e INFO   TSClient quit.
2015/12/28 10:03:24 X [MAIN] Disconnected:  1
2015/12/28 10:03:51 bf6fe9d9 52401e1e DEBUG  Storing configuration.
 - Operating System: Ubuntu 14.04.3 LTS (OpenVZ)
 - Kernel: Linux 2.6.32-042stab111.12 x86_64
 - Load Average: 0.18 0.09 0.02
 - Uptime: 0 days, 20 hours, 54 minutes, 19 seconds
 - OS APT Last Update: 27.12.2015 14:23:53 EST -05:00:00
    CPU(s):                8
    CPU MHz:               1700.500
    Virtualization:        VT-x
 - RAM: 15.87 MB/512.00 MB in use (3%)
 - SWAP: 21.24 MB/512.00 MB in use (4%)
 - DISK: 1.06 GB/8.93 GB in use (11%)
 - Report date: 28.12.2015 10:05:03 EST -05:00:00 (timezone: America/New_York)
 - Binary: /opt/ts3soundboard/sinusbot (Hash: 634662b72e5a6efc5ab92967bc8f3ace)
 - Version: 0.9.9-8f70ff3
   - Bot Plugin: 28511bf58fe820d911609f7252594400
   - TS3 Client: 28511bf58fe820d911609f7252594400
   - YoutubeDLPath = not set
 - Installed Scripts: advertising.js; aloneMode.js; badchan.js; bookmark.js; covatar.js; dev.js; followme.js; idle.js; metadata.js; norecording.js; rememberChannel.js; showcase.js; welcometext.js
SecretKey = [71, 232, 254, 174, 230, 70, 135, 119, 115, 58, 98, 13, 114, 95, 209, 162, 97, 226, 248, 19, 116, 202, 39, 179, 21, 136, 80, 65, 106, 214, 211, 161]
MTU = 1500
SampleInterval = 100
Gruß,
Lolnarr
Fallindor
Hast du das Plugin in den TS³ Ordner des Bots kopiert?
Wenn nicht dann führe mal bitte folgenden Befehl aus
während du in dem Ordner deines sinusbots bist
cp plugin/libsoundbot_plugin.so /opt/ts3soundboard/TeamSpeak3-Client-linux_amd64/plugins
_Edit_
Bitte häng noch den Error Report des TS³ Clients mit an, diesen findest du unter
einfach die datei "error_report" öffnen, am besten mit notepad++ und dann hier in den thread einfügen
Lolnarr
Ja, das Plugin wurde in den Ordner kopiert. Daran sollte es also nicht liegen.
Leider erhalte ich jedoch beim Öffnen der error_reporter Datei größtenteils nur wirre Buchstaben.
Raphraph
Tippe einfach mal dies in deine Konsole ein:
und dann auf Enter drücken :)
Und sonst versuche mal dies zu öffnen:
Lolnarr
Wenn ich das von dir genannte eingebe, bekomme ich leider nur folgende Fehlermeldung:
/opt/ts3soundboard/TeamSpeak3-Client-linux_amd64/error_report: error while loading shared libraries: libquazip.so: cannot open shared object file: No such file or directory
Die Chrashdump-Datei sieht bei mir wie folgt aus: http://hastebin.com/poyojiqaju.md
