Two instances dont work, Please Help
Fabian Groß
SinusbotVersion: 1.0.0-beta.1-06a54d7
TeamSpeakVersion: 3.2.5
OS: Debian GNU/Linux 9.9 (stretch)
- Running as service from Debian
- Start Stop Restart via service sinusbot <command>
- Donor Licences added
- only 4 Bots/Instances of 6 Startup
- all connect to the same Server wich is on 127.0.0.1
- Installation followed from the SinusBot Official Website: https://sinusbot.github.io/docs/installation/linux/
Instanz-Log, Bot I
2019-04-29T12:34:19+03:00 Storing configuration.
2019-04-29T12:34:14+03:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2019-04-29T12:34:14+03:00 Closed.
2019-04-29T12:34:14+03:00 TS>terminating with uncaught exception of type std::__1::system_error: thread constructor failed: Resource temporarily unavailable
2019-04-29T12:34:14+03:00 TS>QXcbIntegration: Cannot create platform OpenGL context, neither GLX nor EGL are enabled
2019-04-29T12:34:14+03:00 TS>QCoreApplication::applicationDirPath: Please instantiate the QApplication object first
2019-04-29T12:34:14+03:00 TS |INFO |Addons | |Checking for addon updates...
2019-04-29T12:34:14+03:00 TS |INFO | | |*** Time [ICONMANGER]: 106
2019-04-29T12:34:14+03:00 TS |ERROR |RevocationListCache| |Failed to import revocation list from cache
2019-04-29T12:34:14+03:00 TS |INFO |ClientUI | |Unable to create an Open GL context.
2019-04-29T12:34:14+03:00 TS |ERROR |SoundBckndIntf| |libpulse.so.0: cannot open shared object file: No such file or directory
2019-04-29T12:34:14+03:00 TS |INFO | | |Using hardware aes
2019-04-29T12:34:14+03:00 TS |INFO | | |SystemInformation: Linux 2.6.32-openvz-042stab127.2-amd64 #1 SMP Thu Jan 4 16:43:57 MSK 2018 x86_64 Binary: 64bit
2019-04-29T12:34:14+03:00 TS |INFO | | |TeamSpeak 3 Client 3.2.5 (2019-04-17 16:07:33)
2019-04-29T12:34:14+03:00 TS>DUMP defined! Dumpdir is: /opt/sinusbot/data/ts3/f6375a9d-00a6-40c4-b5b7-018df8c2b476/e8eb9490-a372-4bba-867f-166959dd444e/crashdumps
2019-04-29T12:34:14+03:00 TS>Crashdump ENABLED, directory is: /opt/sinusbot/data/ts3/f6375a9d-00a6-40c4-b5b7-018df8c2b476/e8eb9490-a372-4bba-867f-166959dd444e/crashdumps
2019-04-29T12:34:14+03:00 Starting instance ts3server://127.0.0.1?port=9987&nickname=Moderators%20-%20Music&password=&channel=&channelpassword=
Instanz-Log, Bot II
2019-04-29T12:42:38+03:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2019-04-29T12:42:38+03:00 Closed.
2019-04-29T12:42:38+03:00 TS>terminating with uncaught exception of type std::__1::system_error: thread constructor failed: Resource temporarily unavailable
2019-04-29T12:42:38+03:00 TS>QXcbIntegration: Cannot create platform OpenGL context, neither GLX nor EGL are enabled
2019-04-29T12:42:38+03:00 TS>QCoreApplication::applicationDirPath: Please instantiate the QApplication object first
2019-04-29T12:42:38+03:00 TS |INFO |Addons | |Checking for addon updates...
2019-04-29T12:42:38+03:00 TS |ERROR |RevocationListCache| |Failed to import revocation list from cache
2019-04-29T12:42:38+03:00 TS |INFO |ClientUI | |Unable to create an Open GL context.
2019-04-29T12:42:38+03:00 TS |ERROR |SoundBckndIntf| |libpulse.so.0: cannot open shared object file: No such file or directory
2019-04-29T12:42:38+03:00 TS |INFO | | |Using hardware aes
2019-04-29T12:42:38+03:00 TS |INFO | | |SystemInformation: Linux 2.6.32-openvz-042stab127.2-amd64 #1 SMP Thu Jan 4 16:43:57 MSK 2018 x86_64 Binary: 64bit
2019-04-29T12:42:38+03:00 TS |INFO | | |TeamSpeak 3 Client 3.2.5 (2019-04-17 16:07:33)
2019-04-29T12:42:38+03:00 TS>DUMP defined! Dumpdir is: /opt/sinusbot/data/ts3/f6375a9d-00a6-40c4-b5b7-018df8c2b476/74cf8036-4b33-464f-af78-0646f3d1bc24/crashdumps
2019-04-29T12:42:38+03:00 TS>Crashdump ENABLED, directory is: /opt/sinusbot/data/ts3/f6375a9d-00a6-40c4-b5b7-018df8c2b476/74cf8036-4b33-464f-af78-0646f3d1bc24/crashdumps
2019-04-29T12:42:38+03:00 Starting instance ts3server://127.0.0.1?port=9987&nickname=Builder%20-%20Music&password=&channel=&channelpassword=
