Bug Unable to start bot, "< CloseListener"?
Bitz
Recently updated and obviously cannot undo the update.
Here is the console log of the sinusbot cli. The last 4 occurrences happened when I clicked the power button on the web interface once.
Version: 0.9.12.3-36fce3c
2016/08/19 21:03:10 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin UseTSAdminBOT.        js
2016/08/19 21:03:10 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin advertising.js
2016/08/19 21:03:10 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin aloneMode.js
2016/08/19 21:03:10 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin badchan.js
2016/08/19 21:03:10 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin bookmark.js
2016/08/19 21:03:10 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin come.js
2016/08/19 21:03:10 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin covatar.js
2016/08/19 21:03:10 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin dev.js
2016/08/19 21:03:10 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin followme.js
2016/08/19 21:03:10 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin idle.js
2016/08/19 21:03:10 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin metadata.js
2016/08/19 21:03:10 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin norecording.js
2016/08/19 21:03:10 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin rememberChannel.js
2016/08/19 21:03:10 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin showcase.js
2016/08/19 21:03:10 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin sound.js
2016/08/19 21:03:10 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin welcometext.js
2016/08/19 21:03:10 X [MAIN] Starting up fake x-server...
2016/08/19 21:03:10 f67f6e45          INFO   Loading instances
2016/08/19 21:03:10 f67f6e45          INFO   Loading instance://2ece8bc0-cb51-427c-a928-e625fe63f9ed
2016/08/19 21:03:10 f67f6e45 2ece8bc0 INFO   Initialization complete
2016/08/19 21:03:10 f67f6e45          INFO   Loading instance://d5603fc1-c427-42d9-a6e0-c9bfbc6a3dbb
2016/08/19 21:03:10 f67f6e45 d5603fc1 INFO   Loading script aloneMode
2016/08/19 21:03:10 f67f6e45 d5603fc1 INFO   Loading script come
2016/08/19 21:03:10 f67f6e45 d5603fc1 INFO   Initialization complete
2016/08/19 21:03:10 [GENERAL/FFMPEG ] INFO   FFmpeg/avcodec v3741798; license: LGPL version 2.1 or later; 81 codecs
2016/08/19 21:03:10 [GENERAL/FFMPEG ] INFO   FFmpeg/avformat v3742052; license:   LGPL version 2.1 or later; 143 formats
2016/08/19 21:03:10 [GENERAL/YTDL   ] INFO   youtube-dl checking...
2016/08/19 21:03:11 [GENERAL/YTDL   ] INFO   youtube-dl version compatible, support enabled
2016/08/19 21:03:11 [GENERAL/!!!!!!!] NOTICE You may now configure and launch the bots from the webinterface. http://0.0.0.0:8087
2016/08/19 21:03:11 [GENERAL/RADIO  ] INFO   RadioStation data loaded
2016/08/19 21:03:11 [GENERAL/RADIO  ] INFO   Imported radio stations
2016/08/19 21:05:36 f67f6e45 2ece8bc0 DEBUG  > PrepareListener
2016/08/19 21:05:36 f67f6e45 2ece8bc0 DEBUG  < PrepareListener
2016/08/19 21:05:36 f67f6e45 2ece8bc0 DEBUG  > CloseListener
2016/08/19 21:05:36 f67f6e45 2ece8bc0 DEBUG  < CloseListener
- Operating System: Ubuntu 14.04.5 LTS
- Kernel: Linux 4.6.3-x86_64-linode70 x86_64
- Load Average: 0.31 0.29 0.27
- Uptime: 9 days, 17 hours, 49 minutes, 26 seconds
- OS Updates: 23 (updates available!)
- OS APT Last Update: 19.08.2016 19:21:04 UTC +00:00:00
    CPU(s):                1
    Thread(s) per core:    1
    Core(s) per socket:    1
    Socket(s):             1
    CPU MHz:               2499.992
    Hypervisor vendor:     KVM
    Virtualization type:   full
- RAM: 622.53 MB/1.95 GB in use (31%)
- SWAP: 504.06 MB/1023.99 MB in use (49%)
- DISK: 15.01 GB/7.32 GB in use (205%)
   > libglib: 2.40.2-0ubuntu1
- Status: running (PIDs: 21750 21749, User: bitz)
- Binary: /opt/ts3bot/sinusbot (Hash: 731121f8516ade834d3bc3e9ebf64a4f)
- Version: 0.9.12.3-36fce3c
   - Bot Plugin: a27dfe2f92730b55119b69ca0dc2268d
   - TS3 Client: a27dfe2f92730b55119b69ca0dc2268d
   - TS3Path = /opt/ts3bot/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64 (Version 3.0.19.4)
   - YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2016.08.01)
- Installed scripts: advertising.js; aloneMode.js; badchan.js; bookmark.js; come.js; covatar.js; dev.js; followme.js; idle.js; metadata.js; norecording.js; rememberChannel.js; showcase.js; sound.js; UseTSAdminBOT.js; welcometext.js
- Report date: 19.08.2016 21:03:21 UTC +00:00:00 (timezone: Etc/UTC)
- youtube-dl Version: 2016.08.01
- DiagScript version: 0.4.5
Which Browser do you using?
Did you clicked on the Orange Start button?
Bitz
Chrome 53.0.2785.57 beta-m (64-bit)
Yes, that's when it throws the errors:
Could you please check the browser console (Dev-Tools in Chrome) for errors?
Bitz
Nothing in the console at all.
I got the same Problem, does anyone know the resolution? Cant use it!
2016/09/13 17:39:35 0bddf495 5fb23bb8 DEBUG > PrepareListener
2016/09/13 17:39:35 0bddf495 5fb23bb8 DEBUG < PrepareListener
2016/09/13 17:39:35 0bddf495 5fb23bb8 DEBUG > CloseListener
2016/09/13 17:39:35 0bddf495 5fb23bb8 DEBUG < CloseListener
heanz
well there is no other bot thats as good. :D but its not a common bug (right now), maybe it has to do with pulseaudio or stuff. actually its the libsound.so plugin thats causing the problem on the ts3client, its not about the bot itself.
So there is no fix? Noone from the dev's are writing anything :(
