Joel Smith
With the "newly" added scripting it looks like we're using node in some way. I was thinking if it is possible to use node modules in my scripts to connect to a database or to access the filesystem for example.
Could it be possible just to "npm init" inside of the sinusbot root directory or the scripts directory?
Nope, the sinusbot has nothing to do with node and you won't be able to use external libaries such as node modules. In one of the upcoming updates a DB connection feature will be available so be aware :)
