V 1.0 Plans
jaamulberry
Will V1.0 be a subscription plan or will it be a one time cost? We are a small group and wondering if it just makes sense to downgrade to 1.7 for more instances or if we should wait for the 1.0 release.
currently there are no detailed info's for 1.0 . But it seems at the moment for a one time cost.
If you do a down grade you don't get support, or updates the Old Versions are no longer Supportet.
If the 1.0 is ready we will announce it, if you want more Instances you can take a look in the FAQ or make use of the Give-Aways :)
