Hello there!
I have an issue with the volume.
The volume returns after some seconds always to maximum volume, regardless of what the volume is set to.
The volume slider stays at the set volume level but the loudness is as same as on volume 100.
Any ideas what could cause this issue?
Here is my sinusbot diagnostic output:
- Operating System: Ubuntu 16.04.6 LTS
- Kernel: Linux 4.4.0-112-generic x86_64
- Load Average: 0.10 0.26 0.27
- Uptime: 179 days, 20 hours, 44 minutes, 41 seconds
- OS Updates: 10 (updates available!)
- OS APT Last Update: 20.03.2020 00:28:17 CET +01:00:00
- Shell Locale: en_US.UTF-8
CPU(s): 8
Thread(s) per core: 2
Core(s) per socket: 4
Socket(s): 1
Model name: AMD Opteron(tm) Processor 3365
CPU MHz: 1100.000
Virtualization: AMD-V
- RAM: 10.31 GB/31.17 GB in use (33%)
- SWAP: 8.87 MB/7.62 GB in use (0%)
- DISK: 75.31 GB/450.69 GB in use (16%)
- libglib: 2.48.2-0ubuntu4.4
- Status: running (PIDs: 18875 18874, User: sinusbot)
- LogLevel = 10
- YoutubeDLPath = /opt/sinusbot/youtube-dl (does exist, version: 2020.03.08)
linux-vdso.so.1 => (0x00007ffc99994000)
libswresample.so.2 => /opt/sinusbot/libswresample.so.2 (0x00007fef00721000)
libavfilter.so.6 => /opt/sinusbot/libavfilter.so.6 (0x00007fef003c9000)
libavformat.so.57 => /opt/sinusbot/libavformat.so.57 (0x00007feefffc1000)
libavcodec.so.57 => /opt/sinusbot/libavcodec.so.57 (0x00007feeff659000)
libavutil.so.55 => /opt/sinusbot/libavutil.so.55 (0x00007feeff3e1000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007feeff1d9000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007feefeec9000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007feefeca9000)
libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007feefe921000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007feefe709000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007feefe339000)
libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007feefe119000)
librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007feefdf11000)
/lib64/ld-linux-x86-64.so.2 (0x00007fef00941000)
- Time (local): 20.03.2020 12:24:19 CET +01:00:00
- Time (remote): 20.03.2020 12:24:19 CET +01:00:00
- TeamSpeak3 Version: 3.3.2
- youtube-dl Version: 2020.03.08
