mitto98
yesterday i've tryed to install this bot in my ovh vps with centos 6 installed, but it didn't worked, so today i've installed debian 8 with vesta, but it give me the same error that i had with centos.
used version: 0.9.12-6bb0227
used operating system: Debian 8 64 bit updated with vesta cp
hardware specs: RAM 1gb, 1 vcore
used browser : I think that it isn't installed
Thanks for your help.
LicenseKey = "36TbuPgo1oGkYoHqe86kn2thV+26zwlHJXj35qB88jw="
UserAgent = "SinusBot (0.9.12-6bb0227)"
2016/04/28 17:48:02 X [MAIN] Starting up fake x-server...
2016/04/28 17:48:02 db80ec53 INFO Loading instances
2016/04/28 17:48:02 db80ec53 INFO Loading instance://6f910bb7-889b-4862-b6dc-ced549b0d61b
2016/04/28 17:48:02 db80ec53 6f910bb7 INFO Initialization complete
2016/04/28 17:48:02 [GENERAL/FFMPEG ] INFO FFmpeg/avcodec v3741798; license: LGPL version 2.1 or later; 81 codecs
2016/04/28 17:48:02 [GENERAL/FFMPEG ] INFO FFmpeg/avformat v3742052; license: LGPL version 2.1 or later; 143 formats
2016/04/28 17:48:02 [GENERAL/YTDL ] INFO youtube-dl checking...
2016/04/28 17:48:03 [GENERAL/YTDL ] INFO youtube-dl version compatible, support enabled
2016/04/28 17:48:03 [GENERAL/!!!!!!!] NOTICE You may now configure and launch the bots from the webinterface. http://0.0.0.0:8087
2016/04/28 17:48:03 [GENERAL/RADIO ] INFO RadioStation data loaded
2016/04/28 17:48:03 [GENERAL/RADIO ] INFO Imported radio stations
2016/04/28 17:48:06 db80ec53 6f910bb7 DEBUG Could not delete from Notificationsno such table: Notifications
2016/04/28 17:48:06 db80ec53 6f910bb7 DEBUG Could not insert into Notifications-Tableno such table: Notifications
2016/04/28 17:48:06 db80ec53 6f910bb7 INFO Starting instance ts3server://ts3.eazygaming.it?port=9987&nickname=TS3SB-Demobot&password=&channel=&channelpassword=
2016/04/28 17:48:06 X [MAIN] New connection
2016/04/28 17:48:06 db80ec53 6f910bb7 DEBUG TS>Crashdump ENABLED, directory is: /opt/sinusbot/data//ts3/db80ec53-b173-4e0e-8d7d-824044cd0cc5/6f910bb7-889b-4862-b6dc-ced549b0d61b/crashdumps
2016/04/28 17:48:06 db80ec53 6f910bb7 DEBUG TS>DUMP defined! Dumpdir is: /opt/sinusbot/data//ts3/db80ec53-b173-4e0e-8d7d-824044cd0cc5/6f910bb7-889b-4862-b6dc-ced549b0d61b/crashdumps
2016/04/28 17:48:06 db80ec53 6f910bb7 INFO TS |INFO | | |TeamSpeak 3 Client 3.0.19.1 (2016-04-25 12:56:09)
2016/04/28 17:48:06 db80ec53 6f910bb7 INFO TS |INFO | | |SystemInformation: Linux 2.6.32-042stab111.12 #1 SMP Thu Sep 17 11:38:20 MSK 2015 x86_64 Binary: 64bit
2016/04/28 17:48:06 db80ec53 6f910bb7 INFO TS |ERROR |SoundBckndIntf| |libpulse.so.0: impossibile aprire il file oggetto condiviso: File o directory non esistente
2016/04/28 17:48:06 db80ec53 6f910bb7 INFO TS |ERROR |SoundBckndIntf| |libasound.so.2: impossibile aprire il file oggetto condiviso: File o directory non esistente
2016/04/28 17:48:06 db80ec53 6f910bb7 INFO TS |WARNING |SoundDevManager| |Did not load any sound backends. No (usable) dynamic libraries found.
2016/04/28 17:48:06 db80ec53 6f910bb7 INFO TS |INFO | | |Loading plugin: libclientquery_plugin
2016/04/28 17:48:06 db80ec53 6f910bb7 INFO TS |INFO | | |Loading plugin: liblua_plugin
2016/04/28 17:48:06 db80ec53 6f910bb7 INFO TS |INFO | | |Loading plugin: libsoundbot_plugin
2016/04/28 17:48:06 db80ec53 6f910bb7 INFO TS |INFO | | |Loading plugin: libtest_plugin
2016/04/28 17:48:06 db80ec53 6f910bb7 INFO TS |INFO |Query | |listening on 127.0.0.1:25639
2016/04/28 17:48:07 X [MAIN] New connection
2016/04/28 17:48:07 db80ec53 6f910bb7 DEBUG TS>ClientQueryPlugin: currentServerConnectionChanged 1 (0)
2016/04/28 17:48:07 db80ec53 6f910bb7 INFO TS |INFO |ClientUI | |Failed to init text to speech engine
2016/04/28 17:48:07 db80ec53 6f910bb7 INFO TS |INFO |ClientUI | |Qt version: 5.5.1
2016/04/28 17:48:07 db80ec53 6f910bb7 INFO TS |INFO |ClientUI | |Using configuration location: /opt/sinusbot/data//ts3/db80ec53-b173-4e0e-8d7d-824044cd0cc5/6f910bb7-889b-4862-b6dc-ced549b0d61b/settings.db
2016/04/28 17:48:07 db80ec53 6f910bb7 INFO TS |INFO |ClientUI | |ts3server: ts3.eazygaming.it?port=9987&nickname=TS3SB-Demobot&password=&channel=&channelpassword=
2016/04/28 17:48:07 db80ec53 6f910bb7 INFO TS |INFO |ClientUI |1 |Connect to server: ts3.eazygaming.it
2016/04/28 17:48:07 db80ec53 6f910bb7 INFO TS |INFO |ClientUI |1 |Trying to resolve ts3.eazygaming.it
2016/04/28 17:48:07 db80ec53 6f910bb7 INFO TS |INFO |TSDNS | |No SRV TSDNS found at "_tsdns._tcp.eazygaming.it"
2016/04/28 17:48:07 db80ec53 6f910bb7 INFO TS |INFO |TSDNS | |SRV DNS resolve unsuccessful for "_ts3._udp.ts3.eazygaming.it"
2016/04/28 17:48:07 db80ec53 6f910bb7 INFO TS |INFO |TSDNS | |DNS resolve successful, "ts3.eazygaming.it"=31.14.139.115
2016/04/28 17:48:07 db80ec53 6f910bb7 INFO TS |INFO |ClientUI | |Last update check was: dom gen 1 00:00:01 2017
2016/04/28 17:48:07 db80ec53 6f910bb7 INFO TS |INFO |ClientUI | |Checking for update
2016/04/28 17:48:07 db80ec53 6f910bb7 INFO TS |INFO |Update | |Checking for updates...
2016/04/28 17:48:07 db80ec53 6f910bb7 INFO TS |INFO |Update | |Check license version: 1
2016/04/28 17:48:07 db80ec53 6f910bb7 INFO TS |INFO |LicenseViewer | |License language: en
2016/04/28 17:48:07 db80ec53 6f910bb7 INFO TS |INFO |LicenseViewer | |Found cached license for version 1 and language en
2016/04/28 17:48:11 db80ec53 6f910bb7 INFO TS |INFO |ClientUI |1 |Lookup finished: 31.14.139.115 9987 ts3.eazygaming.it 0 0
2016/04/28 17:48:11 db80ec53 6f910bb7 INFO TS |INFO |ClientUI |1 |Resolve successful: 31.14.139.115:9987
2016/04/28 17:48:11 db80ec53 6f910bb7 INFO TS |INFO |ClientUI |1 |Blacklist check ok
2016/04/28 17:48:11 db80ec53 6f910bb7 INFO TS |INFO |ClientUI |1 |Initiating connection: 31.14.139.115:9987 ts3.eazygaming.it
2016/04/28 17:48:11 db80ec53 6f910bb7 INFO TS |INFO |PreProSpeex |1 |Speex version: 1.2rc1
2016/04/28 17:48:11 db80ec53 6f910bb7 INFO TS |INFO |ClientUI |1 |Connect status: Connecting
2016/04/28 17:48:11 db80ec53 6f910bb7 INFO New connection status 1; Error 0
2016/04/28 17:48:16 db80ec53 6f910bb7 INFO TS |INFO |ClientUI |1 |Connect status: Disconnected
2016/04/28 17:48:16 db80ec53 6f910bb7 INFO TS |INFO |ClientUI |1 |Failed to connect to server, want autoreconnect = 0
2016/04/28 17:48:16 db80ec53 6f910bb7 INFO The bot could not connect. This might have several reasons: the server doesn't exist at that address, the server password is wrong, the default channel doesn't exist or the password is wrong or the security level of your identity is too low.
2016/04/28 17:48:16 db80ec53 6f910bb7 INFO New connection status 0; Error 1797
2016/04/28 17:48:16 db80ec53 6f910bb7 INFO TS |INFO |ClientUI | |Blacklist check timeout
2016/04/28 17:48:17 db80ec53 6f910bb7 DEBUG TS>libpng warning: iCCP: known incorrect sRGB profile
2016/04/28 17:48:17 db80ec53 6f910bb7 DEBUG TS>QObject::connect: Cannot connect (null)::stateChanged(QNetworkSession::State) to QNetworkReplyHttpImpl::_q_networkSessionStateChanged(QNetworkSession::State)
2016/04/28 17:48:17 db80ec53 6f910bb7 DEBUG TS>warning: The VAD has been replaced by a hack pending a complete rewrite
2016/04/28 17:48:17 db80ec53 6f910bb7 WARN EOF
2016/04/28 17:48:17 db80ec53 6f910bb7 INFO TSClient quit.
^C
sinusbot@vps168678:/opt/sinusbot$
2016/04/28 17:48:26 [GENERAL ] Shutting down... Hold on...
^C
