WebStream, ERR_CONNECTION_REFUSED (Solution: check url)
Thank, it was wrong in the url.. --
But "Online Webstream" is just a joke (The code was never tested...)
I tested and modified the code of Online Webstream. I have a live instance running at this url.
EDIT: If you try it, be sure to properly configure config.ini and to tweak the index.php file a bit if you assigned a subdomain name to the bot's port and cannot normally reach port 8087 because of a firewall issue in some locations (in my case, schools generally block all ports that aren't for general http / https traffic.
Once you add your ip address that links to your sinusbot instance in the config.php file, the bot should stream what your ts bot is streaming. I had an issue similar to this, but found that it was strictly user error. The websteam tool itself works wonderfully.
How does this solve link problem ?
https://github.com/crank015/SinusBot-Stream/blob/master/index.php#L72
- I think your path is the Problem... @the index.php there is no http or https:// for the URL, so the browser uses the / this is in your case /test/SinusBot-Stream-master.
Note to the Dev's: It's also something bad Code style. The complete Image / get Song and Search part could be Served by one php File with GET Params.
You creating for each file a Instance of the PHP-Class, this could all be handled by one Instance, (https://secure.php.net/manual/de/language.oop5.php)
Also the: error_reporting('E_ERROR'); is crap? Configure your test Servers for Development (Debugging output) and not add this to your live Code bad configured User Servers can so Report critical Data.
In my instance, I removed all but the required audio tag, to which I added a // to replace http or https. The only things that run in mine are the audio tag and the getSong call. I think I linked my bot for reference in an above post. I made a mistake earlier today (I ran rm -rf on /opt instead of df to get the disk usage, but it's recovering), but it still plays music.
