why not starting bots ?
i'am using my own php sinusbot installer panel
work on 2nd server but not work on 1nd server bots automaticly closed and not starting...
why ?
my ip addr: 207.154.235.141
[2019-04-23 14:48:48] [INFO] Starting diagSinusbot v0.7.1 [2018-05-23 22:20 UTC]...
[2019-04-23 14:48:48] [INFO] Checking for new diagnostic script version...
[2019-04-23 14:48:48] [OKAY] You are using the latest version.
[2019-04-23 14:48:49] [INFO] Detected operating system: Ubuntu 18.04.2 LTS
[2019-04-23 14:48:49] [INFO] Searching bot binary...
[2019-04-23 14:48:49] [DEBUG] Searching in directory '/opt/muzikbot1804'...
[2019-04-23 14:48:49] [DEBUG] Binary 'sinusbot' found.
[2019-04-23 14:48:49] [INFO] Binary found.
[2019-04-23 14:48:49] [DEBUG] Collecting information...
[2019-04-23 14:48:49] [INFO] (Scan may take some moments...)
[2019-04-23 14:48:49] [INFO] Collecting system information...
[2019-04-23 14:48:49] [DEBUG] Getting operating system version...
[2019-04-23 14:48:49] [DEBUG] Checking DNS resolution...
[2019-04-23 14:48:49] [DEBUG] Checking web IPv4 access...
[2019-04-23 14:48:49] [DEBUG] Checking for locales...
[2019-04-23 14:48:49] [DEBUG] Getting processor information...
[2019-04-23 14:48:49] [DEBUG] Checking for available operating system updates...
[2019-04-23 14:48:52] [DEBUG] Getting RAM information...
[2019-04-23 14:48:52] [DEBUG] Getting SWAP information...
[2019-04-23 14:48:52] [DEBUG] Getting DISK information...
[2019-04-23 14:48:52] [DEBUG] Getting disk info by using command:
[2019-04-23 14:48:52] [DEBUG] $ df -Tl --total -t ext4 -t ext3 -t ext2 -t reiserfs -t jfs -t ntfs -t fat32 -t btrfs -t fuseblk
[2019-04-23 14:48:52] [INFO] Collecting bot information...
[2019-04-23 14:48:52] [DEBUG] Trying to get SinusBot version using version parameter...
[2019-04-23 14:48:52] [DEBUG] Loading bot config file...
[2019-04-23 14:48:52] [DEBUG] Determining bot status...
[2019-04-23 14:48:52] [DEBUG] Reading ListenPort from bot configuration...
[2019-04-23 14:48:52] [DEBUG] Getting installed bot scripts...
[2019-04-23 14:48:52] [DEBUG] Reading LogLevel from bot configuration...
[2019-04-23 14:48:52] [DEBUG] Reading TS3Path from bot configuration...
[2019-04-23 14:48:52] [DEBUG] Trying to get ts3client version...
[2019-04-23 14:48:52] [DEBUG] Checking installation of bot plugin in ts3client...
[2019-04-23 14:48:52] [DEBUG] Checking for 'youtube-dl'...
[2019-04-23 14:48:54] [DEBUG] Generating output...
 - Operating System: Ubuntu 18.04.2 LTS
 - Kernel: Linux 4.15.0-47-generic x86_64
 - Load Average: 0.03 0.71 0.82
 - Uptime: 5 days, 22 hours, 20 minutes, 8 seconds
 - OS Updates: 36 (updates available!)
 - OS APT Last Update: 23.04.2019 14:32:17 UTC +00:00:00
 - SHELL LOCALE LANG: C.UTF-8
    Architecture:        x86_64
    CPU(s):              4
    Thread(s) per core:  1
    Core(s) per socket:  1
    Socket(s):           4
    Model name:          Intel(R) Xeon(R) CPU E5-2650L v3 @ 1.80GHz
    CPU MHz:             1799.998
    Virtualization:      VT-x
    Hypervisor vendor:   KVM
    Virtualization type: full
 - RAM: 563.52 MB/7.78 GB in use (7%)
 - DISK: 13.09 GB/154.89 GB in use (8%)
   + libglib: 2.56.3-0ubuntu0.18.04.1
 - Webinterface: port locally not reachable (Port: 1804)
 - Binary: /opt/muzikbot1804/sinusbot
 - Binary Info: MD5 Hash: 6f301dac3e4dfd45ce149933c5dadd08, Perms: 755, User: linuxkurulum
   - TS3Path = /opt/muzikbot1804/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64 (Version 3.1.9)
   - YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2019.04.17)
 - Installed scripts: Youtube_Search.js; advertising.js; alonemode.js; bookmark.js; command.js; followme.js; norecording.js; rememberChannel.js; welcome.js
 - Time (local): 23.04.2019 14:48:54 UTC +00:00:00
 - Time (remote): 23.04.2019 14:48:54 UTC +00:00:00
 - Timezone: Etc/UTC
 - TeamSpeak 3 Version: 3.1.9
 - youtube-dl Version: 2019.04.17
 - DiagScript Version: 0.7.1
What type of "php sinusbot installer panel" is this? you are aware that sinusbot is for private use ONLY
