Youtube-dl not avaliable
peuonnis
Hello, when i try to use commands like !qyt (link) and it doesn't work
at upload shows like this https://i.imgur.com/naErr4a.png
youtube-dl not avaliable
im using windows 10, i downloaded last version of youtube-dl api
i downloaded and installed python 3.7.0-amd64.exe
my SinusBot config.ini its like https://i.imgur.com/vY9Q22O.png
and the file youtube-dl its on SinusFolder https://i.imgur.com/O6Lg7Ju.png
what is wrong? idk why isn't working.
sorry for bad english
Kir-à
I have you tried to install earlier version of python? it may work.
Kir-à
I don't know why it ain't working tbh, that's weird.
Everything is setup correctly. o.o
We are missing something.
Kir-à
You can try and it should be the first thing you had to do.
Thought you already did it^^
