Youtube-dl not working correctly
So i have a weird issue but first here is the output from the diag script
[2019-07-30 17:13:12] [WELCOME] ================================================
[2019-07-30 17:13:12] [WELCOME] = HELLO!  Having an issue? I'm here to assist! =
[2019-07-30 17:13:12] [WELCOME] =                                              =
[2019-07-30 17:13:12] [WELCOME] =  Thanks for  using  this diagnostic script!  =
[2019-07-30 17:13:12] [WELCOME] =  The more  information  you   provide,  the  =
[2019-07-30 17:13:12] [WELCOME] =  better we  can help to solve your problem.  =
[2019-07-30 17:13:12] [WELCOME] =  The execution  may  take  some  moments to  =
[2019-07-30 17:13:12] [WELCOME] =  collection the most  important information  =
[2019-07-30 17:13:12] [WELCOME] =  of your system and  your bot installation.  =
[2019-07-30 17:13:12] [WELCOME] =  After everything  is  done, you will get a  =
[2019-07-30 17:13:12] [WELCOME] =  summarized output ready to copy & paste it  =
[2019-07-30 17:13:12] [WELCOME] =  within a CODE-tag  in  the SinusBot forum.  =
[2019-07-30 17:13:12] [WELCOME] =  [Link: https://forum.sinusbot.com]          =
[2019-07-30 17:13:12] [WELCOME] =  This script uses DNS resolutions and HTTPS  =
[2019-07-30 17:13:12] [WELCOME] =  requests  to  Sinusbot-related  domains to  =
[2019-07-30 17:13:12] [WELCOME] =  check  if your network settings are valid.  =
[2019-07-30 17:13:12] [WELCOME] = Please also report any feedback or issues    =
[2019-07-30 17:13:12] [WELCOME] = related to the script in the official forum. =
[2019-07-30 17:13:12] [WELCOME] = Thank you and happy debugging!               =
[2019-07-30 17:13:12] [WELCOME] =   -- Patrik Kernstock aka. Patschi.          =
[2019-07-30 17:13:12] [WAIT] Press [ENTER] to continue...
[2019-07-30 17:13:14] [INFO] Starting diagSinusbot v0.8.0 [2019-06-16 00:01 UTC]        ...
[2019-07-30 17:13:14] [INFO] Checking for new diagnostic script version...
[2019-07-30 17:13:15] [OKAY] You are using the latest version.
[2019-07-30 17:13:15] [INFO] Detected operating system: Ubuntu 19.04
[2019-07-30 17:13:15] [INFO] Searching bot binary...
[2019-07-30 17:13:15] [DEBUG] Searching in directory '/opt/sinusbot'...
[2019-07-30 17:13:15] [DEBUG] Binary 'sinusbot' found.
[2019-07-30 17:13:15] [INFO] Binary found.
[2019-07-30 17:13:15] [DEBUG] Collecting information...
[2019-07-30 17:13:15] [INFO] (Scan may take some moments...)
[2019-07-30 17:13:15] [INFO] Collecting system information...
[2019-07-30 17:13:15] [DEBUG] Getting operating system version...
[2019-07-30 17:13:15] [DEBUG] Checking DNS resolution...
[2019-07-30 17:13:15] [DEBUG] Checking web IPv4 access...
[2019-07-30 17:13:16] [DEBUG] Checking update server availability...
[2019-07-30 17:13:17] [DEBUG] Checking for locales...
[2019-07-30 17:13:17] [DEBUG] Getting processor information...
[2019-07-30 17:13:17] [DEBUG] Checking for available operating system updates...
[2019-07-30 17:13:18] [DEBUG] Getting RAM information...
[2019-07-30 17:13:18] [DEBUG] Getting SWAP information...
[2019-07-30 17:13:18] [DEBUG] Getting DISK information...
[2019-07-30 17:13:18] [DEBUG] Getting disk info by using command:
[2019-07-30 17:13:18] [DEBUG]  $ df -Tl --total -t ext4 -t ext3 -t ext2 -t reise        rfs -t jfs -t ntfs -t fat32 -t btrfs -t fuseblk
[2019-07-30 17:13:18] [INFO] Collecting bot information...
[2019-07-30 17:13:18] [DEBUG] Trying to get SinusBot version using version param        eter...
[2019-07-30 17:13:18] [DEBUG] Loading bot config file...
[2019-07-30 17:13:18] [DEBUG] Determining bot status...
[2019-07-30 17:13:18] [DEBUG] Getting LDD output from bot binary...
[2019-07-30 17:13:18] [DEBUG] Reading ListenPort from bot configuration...
[2019-07-30 17:13:18] [DEBUG] Getting installed bot scripts...
[2019-07-30 17:13:18] [DEBUG] Reading LogLevel from bot configuration...
[2019-07-30 17:13:18] [DEBUG] Reading TS3Path from bot configuration...
[2019-07-30 17:13:18] [DEBUG] Trying to get ts3client version...
[2019-07-30 17:13:18] [DEBUG] Checking installation of bot plugin in ts3client..        .
[2019-07-30 17:13:18] [DEBUG] Checking if libqxcb-glx-integration.so file exists        ...
[2019-07-30 17:13:18] [DEBUG] Checking for 'youtube-dl'...
[2019-07-30 17:13:20] [DEBUG] Generating output...
[CODE]
- Operating System: Ubuntu 19.04
- Kernel: Linux 5.0.0-21-generic x86_64
- Load Average: 0.14 0.36 0.29
- Uptime: 0 days, 0 hours, 10 minutes, 29 seconds
- OS APT Last Update: 30.07.2019 04:18:33 BST +01:00:00
- Shell Locale: en_US.UTF-8
    Architecture:        x86_64
    CPU(s):              2
    Thread(s) per core:  2
    Core(s) per socket:  1
    Socket(s):           1
    Model name:          Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz
    CPU MHz:             2591.997
    Hypervisor vendor:   Microsoft
- RAM: 599.44 MB/3.83 GB in use (15%)
- DISK: 9.26 GB/77.75 GB in use (11%)
   - libglib: 2.60.4-0ubuntu0.19.04.1
- Status: running (PIDs: 2634 2632, User: sinusbot)
- Webinterface: port locally reachable (Port: 8283)
- Binary Info: MD5 Hash: d770dee2259d159aa78550962d3251e3, Perms: 755, User: si        nusbot
   - TS3Path = /opt/sinusbot/teamspeak3-client/ts3client_linux_amd64 (Version 3.        3.0)
   - YoutubeDLPath = not set (does exist anyway, version: 2019.07.27)
- Installed scripts: advertising.js; AFK_Mover_(AwayMuteDeafIdle).js; alonemode        .js; Animated_Nickname.js; bookmark.js; Change_Channelcodec_And_Quality_Automati        cly.js; command.js; CoverLoader_[Radio_Station_Support].js; followme.js; LastFM_        Scrobbling.js; norecording.js; rememberChannel.js; Server_Rules.js; ShowPlaylist        s.js; welcome.js; YT-search.js
    linux-vdso.so.1 (0x00007ffd11564000)
    libswresample.so.2 => /opt/sinusbot/libswresample.so.2 (0x00007fa59abb6000)
    libavfilter.so.6 => /opt/sinusbot/libavfilter.so.6 (0x00007fa59a85e000)
    libavformat.so.57 => /opt/sinusbot/libavformat.so.57 (0x00007fa59a45d000)
    libavcodec.so.57 => /opt/sinusbot/libavcodec.so.57 (0x00007fa599af8000)
    libavutil.so.55 => /opt/sinusbot/libavutil.so.55 (0x00007fa599884000)
    libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007fa59986b000)
    libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007fa59971b000)
    libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007fa5996fa000        )
    libstdc++.so.6 => /lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007fa599518000)
    libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007fa5994fe000)
    libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007fa599313000)
    libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007fa5992f7000)
    librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007fa5992ea000)
    /lib64/ld-linux-x86-64.so.2 (0x00007fa59add2000)
- HTTPS check with IPv4 mode: SUCCESS [Connection established to www.sinusbot.c        om, CODE #200]
- Time (local): 30.07.2019 17:13:20 BST +01:00:00
- Time (remote): 30.07.2019 17:13:20 BST +01:00:00
- Timezone: Europe/London
- TeamSpeak3 Version: 3.3.0
- youtube-dl Version: 2019.07.27
[2019-07-30 17:13:20] [DEBUG] Done.
[/code]
Here is my config.ini
ListenPort = <BLANKED>
ExternalFileBase = "/home/<BLANKED>/music/"
LicenseKey = "<BLANKED>"
  BufferSize = 5242880
  MaxSimultaneousChunkDownloads = 3
  CacheStreamed = true
  AllowGIF = true
  DevMode = false
[TTS]
  Enabled = false
Right to the issue if i issue the youtube-dl command in CLI via ssh it works every time without an issue however if i use the webgui to include either a youtube or soundcloud link it will always fail with the link is not good or download fail in teamspeak or Error
The provided URL could not be recognized as a valid stream. Sorry. , i have followed the FAQ the works and this issue is still not budging at all.
I know the links are valid as i have used the same links in CLI SSH without issues just seems the bot has issue with them in webgui and ts3 itself.
Does anyone know of a way to resolve this. Thanks in advance
Himsel
your config.ini
where is youtube-dl located ?
youtube-dl is located inside the sinusbot folder as well as /usr/local/bin and i have tried both places and it still has the same issue, the youtube-dl binary is the same version on each attempt. I have also youtube-dl -U with no luck either.
Himsel
you have to put the path in there
it should be
in your config.ini !!!
Right i have made the change and reran youtube-dl -U which has now upgraded itself to 2019.07.30 and when adding via WebGui is still shows the same error.
I have also rebooted the system, still getting
Download failed fo no good format found and Error
Himsel
Do you want to add a Radio Station or just want to stream a youtubve video? can you give me an example?
No i am trying to get sinus to add my playlists that are on soundcloud or play music directly,
for example
!ytdl https://soundcloud.com/william-rogers-750048615/sets/rickyroll/s-DQNMy gives me this Download failed for https://soundcloud.com/william-rogers-750048615/sets/rickyroll/s-DQNMy; no good format found and running the same link in webGUI gives me The provided URL could not be recognized as a valid stream. Sorry.
However if i issue the command in ssh cli with the same link it works without issue.
I didn't have the same issue when i was using another ts3m******* (which kept on crashing hence my move to sinusbot)
