Charming Potato
Hi. Whenever someone use the !ytdl command it opens a command line window on the server with youtubedl.exe and stays there. And it keep repeating this everytime the command is used.
I have tried using the built-in ytdl and external one but both are having the same problems.
My specs are as follows:
i7 920
16gb ram
Windows 10 64bit
Bot version 0.9.13
Plus I have made a few bot Playlists using YouTube playlists (with hundreds of songs in each), and most of the song play for a few seconds before they skip to another song in the playlist. I have given the bot and teamspeak client high priority from task manager but still it's happening.
EDIT: Fixed the second issue by reinstalling. First issue with multiple commandline windows popping up is still there.
i7 920
16gb ram
Windows 10 64bit
Bot version 0.9.13
