A manual update is required
Seyru
Hi. I have problem with sinusbot on docker. When i reinstall and update sinusbot on docker i got this problem.
I check FAQ and other same problems and nothing helped.
Bot doesn't generate a password and site with bot not responding.
  • SinusBot version - 1.0.0-beta.16-ba60e37
  • TS Client and Server version - Client 3.5.6 and Server 3.13.6
  • OS Debian 10 64bit
[email protected]:~# docker logs bot1
Linux 4.19.0-18-amd64 x86_64 GNU/Linux
Thu 27 Jan 2022 10:13:49 AM UTC
Copied default scripts
Updating youtube-dl...
youtube-dl is up-to-date (2021.12.17)
2021.12.17
User ID: 0
Change file owner...
Drop privileges...
Clearing youtube-dl cache...
Removing cache dir /root/.cache/youtube-dl ..
Starting SinusBot...
PID: 25
2022/01/27 10:13:55 [GENERAL/!!!!!!!] WARN !!!!!!! YOU ARE RUNNING THE BOT AS UID 0 (ROOT) WITHOUT HAVING SET ANOTHER UID. THIS IS A SERIOUS SECURITY VIOLATION !!!!!!!!
___ ___ _ _ _ _ ___ ___ ___ _____
Version: 1.0.0-beta.16-ba60e37
a manual update is required
