Hello everybody.
As already mentioned in many posts, the update of the TS3 server currently ensures that some can no longer use their SinusBot. In most cases this is probably due to the kernel version of the server itself. Now my question, am I also affected by this? If I see that correctly, all my versions are compatible according to the list. Here are the desired files with all necessary information.
Please don't be angry with me if it's another unnecessary post but I'm at a loss right now and hope for help here.
Thanks in advance.
Thanks in advance.
- Operating System: Debian GNU/Linux 9.11 (stretch)
- Kernel: Linux 4.9.0-11-amd64 x86_64
- Load Average: 0.26 0.14 0.10
- Uptime: 1 days, 8 hours, 13 minutes, 8 seconds
- OS Updates: 30 (updates available!)
- OS APT Last Update: 02.12.2019 06:25:27 CET +01:00:00
- Shell Locale: en_US.UTF-8
CPU(s): 4
Thread(s) per core: 1
Core(s) per socket: 4
Socket(s): 1
Model name: Intel(R) Xeon(R) Gold 6140 CPU @ 2.30GHz
CPU MHz: 2294.608
Hypervisor vendor: KVM
Virtualization type: full
- RAM: 983.15 MB/15.67 GB in use (6%)
- DISK: 5.90 GB/58.96 GB in use (10%)
- libglib: 2.50.3-2+deb9u1
- Webinterface: port locally not reachable (Port: xxxx)
- Binary: /sinusbot/sinusbot
- Binary Info: xxxx
- TS3Path = /sinusbot/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64 (Version 3.3.2)
- YoutubeDLPath = not set
- Installed scripts: advertising.js; alonemode.js; bookmark.js; command.js; followme.js; Jail.js; norecording.js; Reconnect.js; rememberChannel.js; welcome.js; WelcomeMessage.js
linux-vdso.so.1 (0x00007ffc8737f000)
libswresample.so.2 => /sinusbot/libswresample.so.2 (0x00007f438cc72000)
libavfilter.so.6 => /sinusbot/libavfilter.so.6 (0x00007f438c91a000)
libavformat.so.57 => /sinusbot/libavformat.so.57 (0x00007f438c519000)
libavcodec.so.57 => /sinusbot/libavcodec.so.57 (0x00007f438bbb4000)
libavutil.so.55 => /sinusbot/libavutil.so.55 (0x00007f438b940000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f438b73c000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f438b438000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f438b21b000)
libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f438ae99000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f438ac82000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f438a8e3000)
libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f438a6c9000)
librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f438a4c1000)
/lib64/ld-linux-x86-64.so.2 (0x00007f438ce8c000)
- Time (local): 03.12.2019 00:10:00 CET +01:00:00
- Time (remote): 03.12.2019 00:10:00 CET +01:00:00
- TeamSpeak3 Version: 3.3.2
- youtube-dl Version: unknown
2019/12/03 00:17:28 ad230f14 INFO Loading instances
2019/12/03 00:17:28 ad230f14 INFO Loading instance://b6f20a81-20f0-413e-b239-f08b63170185
2019/12/03 00:17:28 ad230f14 b6f20a81 INFO script command loaded
2019/12/03 00:17:28 ad230f14 b6f20a81 INFO script WelcomeMessage loaded
2019/12/03 00:17:28 ad230f14 b6f20a81 INFO Initialization complete
2019/12/03 00:17:28 [GENERAL/FFMPEG ] INFO FFmpeg/avcodec v3741798; license: LGPL version 2.1 or later; 81 codecs
2019/12/03 00:17:28 [GENERAL/FFMPEG ] INFO FFmpeg/avformat v3742052; license: LGPL version 2.1 or later; 143 formats
2019/12/03 00:17:28 [GENERAL/!!!!!!!] NOTICE You may now configure and launch the bots from the webinterface. http://0.0.0.0:xxxx
2019/12/03 00:17:28 ad230f14 b6f20a81 INFO script Jail loaded
2019/12/03 00:17:28 [GENERAL/RADIO ] INFO RadioStation data loaded
2019/12/03 00:17:28 [GENERAL/RADIO ] INFO Imported radio stations
2019/12/03 00:17:50 ad230f14 b6f20a81 WARN Could not create Chat-Tabletable Chat already exists
2019/12/03 00:17:50 ad230f14 b6f20a81 WARN Could not create WhisperReceive-Tabletable WhisperReceive already exists
2019/12/03 00:17:50 ad230f14 b6f20a81 WARN Could not create Notifications-Tabletable Notifications already exists
2019/12/03 00:17:50 ad230f14 b6f20a81 INFO Starting instance ts3server://127.0.0.1?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2019/12/03 00:17:50 X [MAIN] New connection
2019/12/03 00:17:50 ad230f14 b6f20a81 INFO TS |INFO | | |TeamSpeak Client 3.3.2 (2019-08-25 21:13:34)
2019/12/03 00:17:50 ad230f14 b6f20a81 INFO TS |INFO | | |SystemInformation: Linux 4.9.0-11-amd64 #1 SMP Debian 4.9.189-3+deb9u1 (2019-09-20) x86_64 Binary: 64bit
2019/12/03 00:17:50 ad230f14 b6f20a81 INFO TS |INFO | | |Using hardware aes
2019/12/03 00:17:50 ad230f14 b6f20a81 INFO TS |ERROR |SoundBckndIntf| |libpulse.so.0: cannot open shared object file: No such file or directory
2019/12/03 00:17:50 ad230f14 b6f20a81 INFO TS |INFO |ClientUI | |Unable to create an Open GL context.
2019/12/03 00:17:50 ad230f14 b6f20a81 INFO TS |ERROR |RevocationListCache| |Failed to import revocation list from cache
2019/12/03 00:17:50 ad230f14 b6f20a81 INFO TS |INFO |Addons | |Checking for addon updates...
2019/12/03 00:17:50 ad230f14 b6f20a81 INFO TS |INFO |Plugins | |Loading plugin: libsoundbot_plugin.so
2019/12/03 00:17:50 ad230f14 b6f20a81 INFO TS |INFO |Plugins | |Loading plugin: libclientquery_plugin_linux_amd64.so
2019/12/03 00:17:50 ad230f14 b6f20a81 INFO TS |INFO |Query | |listening on 127.0.0.1:25639
2019/12/03 00:17:50 ad230f14 b6f20a81 INFO TS |INFO | | |successfully downloaded revocation list for accounting
2019/12/03 00:17:50 ad230f14 b6f20a81 INFO TS |INFO | | |successfully downloaded revocation list for myteamspeak id
2019/12/03 00:17:50 ad230f14 b6f20a81 INFO TS |INFO | | |*** Time [MAINWINDOW]: 186
2019/12/03 00:17:50 ad230f14 b6f20a81 INFO TS |INFO | | |*** Time [INIT]: 187
2019/12/03 00:17:50 ad230f14 b6f20a81 INFO TS |INFO |ClientUI | |Failed to init text to speech engine
2019/12/03 00:17:50 ad230f14 b6f20a81 INFO TS |INFO |ClientUI | |Qt version: 5.12.1
2019/12/03 00:17:50 ad230f14 b6f20a81 INFO TS |INFO |ClientUI | |Using configuration location: /sinusbot/data/ts3/ad230f14-1e71-4442-b1a6-1f3e65953e97/b6f20a81-20f0-413e-b239-f08b63170185/settings.db
2019/12/03 00:17:51 ad230f14 b6f20a81 INFO TS |INFO |ClientUI | |ts3server: 127.0.0.1?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2019/12/03 00:17:51 ad230f14 b6f20a81 INFO TS |INFO |ClientUI |1 |Connect to server: 127.0.0.1
2019/12/03 00:17:51 ad230f14 b6f20a81 INFO TS |INFO |ClientUI |1 |Initiating connection: 127.0.0.1:9987
2019/12/03 00:17:51 ad230f14 b6f20a81 INFO TS |INFO |PreProSpeex |1 |Speex version: 1.2rc1
2019/12/03 00:17:51 ad230f14 b6f20a81 INFO TS |INFO |ClientUI |1 |Connect status: Connecting
2019/12/03 00:17:51 ad230f14 b6f20a81 INFO New connection status 1; Error 0
2019/12/03 00:17:51 ad230f14 b6f20a81 INFO TS |INFO |Bookmarks | |Collecting autoconnect bookmarks
2019/12/03 00:17:51 ad230f14 b6f20a81 INFO TS |INFO |ClientUI | |Last update check was: Sat Jan 1 00:00:01 2022
2019/12/03 00:17:51 ad230f14 b6f20a81 INFO TS |INFO | | |Statistics report: User has not yet confirmed participation
2019/12/03 00:17:56 ad230f14 b6f20a81 INFO TS |INFO |ClientUI |1 |Connect status: Disconnected
2019/12/03 00:17:56 ad230f14 b6f20a81 INFO TS |INFO |ClientUI |1 |Failed to connect to server, want autoreconnect = 0
2019/12/03 00:17:56 ad230f14 b6f20a81 INFO The bot could not connect. This might have several reasons: the server doesn't exist at that address, the server password is wrong, the default channel doesn't exist, the bot has been banned, the server is an illegal installation, the password is wrong, the security level of your identity is too low, the nickname is too short or too long or the server does not allow the version of the client you are using. See our Wiki / Forums for more help.
2019/12/03 00:17:56 ad230f14 b6f20a81 INFO New connection status 0; Error 1797
2019/12/03 00:17:57 ad230f14 b6f20a81 INFO TSClient quit.
