Apache not displaying SinusBot correctly
Jade97
How can I make Apache correctly work with SinusBot? I've set up my config as this screenshot will show:
It reroutes the port correctly, but when I navigate to the /musicbot directory on the server, SinusBot just displays this blank page with the "Loading, please wait" image:
I'm not sure if this is a confg error, or it's not loading correctly or what, but I would appreciate if anybody could help.
Thanks!
Jade97
Update: Edited original post with what I actually needed assistance with. If anyone has any Apache knowledge, I'd appreciate the help; thanks!
Jade97
I've had it set like that. It doesn't affect anything. Still just displaying the nonstop loading screen.
kanalumaddela
place the proxypass and proxypassreverse in the vhost block and test
EDIT: i dont think you need proxypass AND proxypassreverse, remove proxypassreverse. then do vice versa and see that happens
You can't use a Subdirectory for that (The Bot doesn't like it). Use a subdomain instead: musicbot.domain.tld ;)
