mistergoliath
I have a problem with this tutorial:
https://wiki.sinusbot.com/en:guides:installation:reverse-proxy:apache2
Error:
Logs:
Apache config:
Error:
Job for apache2.service failed. See 'systemctl status apache2.service' and 'journalctl -xn' for details.
Logs:
root@omgserv-176729:/etc# systemctl status apache2.service
● apache2.service - LSB: Apache2 web server
Loaded: loaded (/etc/init.d/apache2)
Drop-In: /lib/systemd/system/apache2.service.d
└─forking.conf
Active: active (running) (Result: exit-code) since jeu. 2018-01-11 13:16:49 CET; 7min ago
Process: 9723 ExecReload=/etc/init.d/apache2 reload (code=exited, status=1/FAILURE)
CGroup: /system.slice/apache2.service
├─9423 /usr/sbin/apache2 -k start
├─9638 /usr/sbin/apache2 -k start
└─9639 /usr/sbin/apache2 -k start
janv. 11 13:21:21 omgserv-176729 systemd[1]: Reloading LSB: Apache2 web server.
janv. 11 13:21:21 omgserv-176729 apache2[9723]: Reloading web server: apache...!
janv. 11 13:21:21 omgserv-176729 apache2[9723]: The apache2 configtest faile....
janv. 11 13:21:21 omgserv-176729 apache2[9723]: Output of config test was:
janv. 11 13:21:21 omgserv-176729 apache2[9723]: AH00526: Syntax error on lin...:
janv. 11 13:21:21 omgserv-176729 apache2[9723]: Invalid command 'ProxyPreser...n
janv. 11 13:21:21 omgserv-176729 apache2[9723]: Action 'configtest' failed.
janv. 11 13:21:21 omgserv-176729 apache2[9723]: The Apache error log may hav....
janv. 11 13:21:21 omgserv-176729 systemd[1]: apache2.service: control proces...1
janv. 11 13:21:22 omgserv-176729 systemd[1]: Reload failed for LSB: Apache2 ....
Hint: Some lines were ellipsized, use -l to show in full.
Apache config:
<VirtualHost localhost:80>
ServerName bot.example.tld
ErrorLog ${APACHE_LOG_DIR}/error.log
CustomLog ${APACHE_LOG_DIR}/access.log combined
ProxyPreserveHost On
ProxyPass / http://localhost:8080/
ProxyPassReverse / http://localhost:8080/
</VirtualHost>
