bot could not acquire servergroups for the clients
lupus123
Hi, I installed sinusbot using the script from the mainpage but when I log into the server I have this error so I cannot add privileges. (the problem is not the ts server because it was working but I had to reinstall using the script because after my VM crashed ./sinusbot doesnt open anymore)
  • used version: 0.9.12.3-5b7c0cd
  • used operating system (e.g. Windows, 64bit): lubuntu 16.04
  • hardware specs (e.g. VPS, Core i7, 8 GB RAM): core i5, 8gbram (in VM i5 1core 1gbram
  • used browser (and maybe plugins): firefox
WEBINTERFACE:
https://puu.sh/qbrwm/ff1246fe0d.png
LicenseKey = "TzrFKSDuLPgEHFHGFfhEZUAUtL0qLTJevDT0vIdeRkA="
  UserAgent = "SinusBot (0.9.12.3-5b7c0cd)"
thanks in advance!
PD: please explain or detail the instructions because Im pretty new at linux
When no output appears, just update to the latest beta.
If you can't login, take a look in the FAQ Entry nr 1.
I hope I help you with that Information.
lupus123
already updated from the script 2 times and one from here: https://forum.sinusbot.com/resources/sinusbot-beta.3/
Sinusbotdiagnostic:
- Operating System: Ubuntu 16.04.1 LTS
- Kernel: Linux 4.4.0-21-generic x86_64
- Load Average: 0.25 0.29 0.23
- Uptime: 0 days, 4 hours, 40 minutes, 9 seconds
- OS Updates: 9 (updates available!)
- OS APT Last Update: 23.07.2016 19:00:53 ART -03:00:00
  CPU(s):  1
  Socket(s):  1
  Model name:  Intel(R) Core(TM) i5-3330 CPU @ 3.00GHz
  CPU MHz:  2993.230
- RAM: 515.50 MB/975.07 MB in use (52%)
- SWAP: 85.92 MB/1021.99 MB in use (8%)
- DISK: 3.40 GB/14.20 GB in use (23%)
  > libglib: 2.48.1-1~ubuntu16.04.1
- Binary: /opt/sinusbot/sinusbot (Hash: f61a001d17bdaa6d74dc04652ef2fcec)
- Version: 0.9.12.3-5b7c0cd
  - Bot Plugin: 3b0269841baede0f8e72bc8063e5b05e
  - TS3 Client: 3b0269841baede0f8e72bc8063e5b05e
  - YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2016.07.22)
- Report date: 23.07.2016 21:05:56 ART -03:00:00 (timezone: America/Argentina/Buenos_Aires)
- youtube-dl Version: 2016.07.22
- DiagScript version: 0.4.5
iTaskmanager
Tier II
Tier I
The Bot could not acquire servergroups for the clients. Please enable b_virtualserver_servergroup_client_list for the bot if you need this feature.
... no comment.
