Bot doesnt connect
sbot version: newest Ts version. 3.3.0
a) always use version numbers instead of "newest" since
b) you're probably using 0.13.37 and did not read the BIG RED banner at the top
No DMs please - Currently inactive
do you mean sinusbot installed multiple times on other Ports?
/opt/sinusbot2/
One of the following is the reason:
The bot could not connect. This might have several reasons: the server doesn't exist at that address, the server password is wrong, the default channel doesn't exist, the bot has been banned, the server is an illegal installation or the password is wrong , the security level of your identity is too low or the server does not allow the version of the client you are using.
(probably the security level)
Badetuch
I tried everthing but it doesnt work ???
My teamspeak server is on 3.3.0 and the others are on 3.2.0 is that the problem?
Neks
i know the reason of this bug...
This It's due at this fucking update at teamspeak server the old client can't be connect at new server...
