BOT Stops playing after playlist ended
xDefcon
I'm running lastest beta version on linux, and i have a bot with 2 playlists.
i have ticked the options "play when idle" "play on startup" for a playlist that i want to play 24/7, but after sometime (probably when it ends) the bot stop to play.
Have i to write a script to check if is playing and if not re-run my playlist?
Chris100184
This button should fix your problem.
