Bot wont start
That's completely normal, you need to update the security level yourself with your Teamspeak client installed on your machine with a GUI. There you increase the level how much you need and export the identity into a file. After you have opened the identity with an editor you copy the longest string from there and paste it into your Webinterface->Settings->Instance Settings->Identity.
Good luck :)
NoPotion
Good luck :)
How do i do that please can u send me a youtube video or something or join my teamspeak please i really need help my teamspeak ip is sweetarts.teamspeak3.com
Ambrika
Hi all!
Os: Linux Debian 7 64bit
Me installing and starting sinusbot 0.9.12.3
and install teamspeak 3.0.19.4
and me starting bot (true)
start join to teamspeak: not working
log:
BOT-CONFIG [admin] CHAN CHANPW ANNOUNCE DESCRIPTION ANNOUNCESTR TTSURL CHATIGNSRV CC OK
Please help the problem
Or
help install commands and TEXT install tutorial.
Thank you all!
We don't support a outdated operating system. Debian 8, 8.5, 8.6 only. Here you can download it :)
NoPotion
The musis bot wont start when i press the start button it goes green and then 2 secounds later it goes back to orange please help.
Operating System
: Windows / Linux
SinusBot Version: 0.9.x
TS3 Version: 3.x.x
Describe your problem in detail. What did you do exactly, what did you expect to happen and what did actually happen?. When i press the start button it goes green and then goes back to orange please help i really wanna listen to some music with my friend if u can join my teamspeak and help me i would love that
Paste output of the diagnostic tool in here, if possible.
Can you read? Fill out this template and don't leave it blank! :)
freshlink
Operating System: Linux
Linux Version: Deban 7
SinusBot Version: sinusbot-0.9.12.2-58b509d
TS3 Version: 3.19.4
I install sinusbot in sinusbot-0.9.12.2-58b509d version but aplication dosen't start and he dosen't send error message with send command
root@omgserv-79262:/opt/ts3soundboard# ./sinusbot
freshlink
Thanks you very much ! I installing it but when i start a bot,
2016/10/29 03:26:46 e32e5dc0 ab76a1f6 DEBUG  TS>/opt/ts3soundboard1/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /opt/ts3soundboard1/TeamSpeak3-Client-linux_amd64/libc++abi.so.1)
2016/10/29 03:26:46 e32e5dc0 ab76a1f6 DEBUG  Closed.
2016/10/29 03:26:46 e32e5dc0 ab76a1f6 INFO   TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2016/10/29 03:26:47 e32e5dc0 ab76a1f6 DEBUG  > CloseListener
2016/10/29 03:26:47 e32e5dc0 ab76a1f6 DEBUG  < CloseListener
Help me Please :'(
kanalumaddela
First update all your packages
apt-get update
apt-get upgrade
apt-get dist-update
Make sure you stop all important services (apache, nginx, mysql, etc.)
Then update your OS to Debian 8 (8.6 is the latest)
nano /etc/apt/sources.list
Replace any repos for wheezy with jessie (debian 8)
deb http://ftp.us.debian.org/debian/ jessie main
deb-src http://ftp.us.debian.org/debian/ jessie main
deb http://security.debian.org/ jessie/updates main
deb-src http://security.debian.org/ jessie/updates main
# jessie-updates, previously known as 'volatile'
deb http://ftp.us.debian.org/debian/ jessie-updates main
deb-src http://ftp.us.debian.org/debian/ jessie-updates main
These other 2 repos showed on my sources.list when I had installed Debian.
deb http://httpredir.debian.org/debian/ jessie main contrib non-free
deb http://httpredir.debian.org/debian/ jessie-backports main
Refresh package list and update important packages
apt-get update && apt-get install apt dpkg aptitude
Then update all packages again
apt-get dist-upgrade
Finally reboot :D. It's a long process, but old OSes aren't supported.
freshlink
Thank's ! I have see and do your indication and it's all good the bot would like to start and join my teamspeak ! :D
