Hello osyyyS,
Creation of the Sinusbot account:
Follow these steps to better follow:
1. Log in to your panel as 127.0.0.1:8087
2. Go to the User accounts tab at the top right click on "Add user (account)".
3. You complete the small registration as you wish.
As soon as this is done, you will have to fill in your friend's access permissions. The small symbols are clickable give him the permissions, if you want that he has a full access you check all the symbols.
To see the permissions of the symbols, I invite you to fly over them and you will see their actions.
To give access to your friend you must open port 8087 of your router thereafter give your IP to it followed by the port.
x.x.x.x.x:8087
You can find your IP here:
https://www.myip.com/
