Can Someone Help me Pls
peco65814
My bot can't connect to a server Here's the log
2018-08-09T20:44:55-05:00 TSClient quit.
2018-08-09T20:44:54-05:00 New connection status 0; Error 0
2018-08-09T20:44:54-05:00 The bot could not connect. This might have several reasons: the server doesn't exist at that address, the server password is wrong, the default channel doesn't exist, the bot has been banned, the server is an illegal installation or the password is wrong , the security level of your identity is too low or the server does not allow the version of the client you are using. See our Wiki / Forums for more help.
2018-08-09T20:44:54-05:00 TS |INFO |ClientUI |1 |Disconnected or forced to leave, want autoreconnect = 0
2018-08-09T20:44:54-05:00 TS |INFO |ClientUI |1 |Connect status: Disconnected
2018-08-09T20:44:54-05:00 TS |DEVELOP |PktHandler | |Puzzle solve time: 2
2018-08-09T20:44:54-05:00 TS |INFO | | |Statistics report: User has not yet confirmed participation
2018-08-09T20:44:54-05:00 New connection status 1; Error 0
2018-08-09T20:44:54-05:00 TS |INFO |ClientUI | |Last update check was: Tue Jan 1 00:00:01 2019
2018-08-09T20:44:54-05:00 TS |INFO |Bookmarks | |Collecting autoconnect bookmarks
2018-08-09T20:44:54-05:00 TS |INFO |ClientUI |1 |Connect status: Connecting
2018-08-09T20:44:53-05:00 TS |INFO |PreProSpeex |1 |Speex version: 1.2rc1
2018-08-09T20:44:47-05:00 TS |INFO |ClientUI |1 |Initiating connection: 94.23.201.5:9987
2018-08-09T20:44:47-05:00 TS |INFO |ClientUI |1 |Connect to server: 94.23.201.5
2018-08-09T20:44:47-05:00 TS |INFO |ClientUI | |ts3server: 94.23.201.5?port=9987&nickname=KEY&password=&channel=&channelpassword=
2018-08-09T20:44:47-05:00 TS |INFO |ClientUI | |Using configuration location: /opt/sinusbot2/data/ts3/c79e831a-8873-4094-a5e3-9938619605b8/9d7440d0-4116-418f-bfcb-4b610ed0ed22/settings.db
2018-08-09T20:44:47-05:00 TS |INFO |ClientUI | |Qt version: 5.6.1
2018-08-09T20:44:47-05:00 TS |INFO |ClientUI | |Failed to init text to speech engine
2018-08-09T20:44:47-05:00 TS |DEVELOP |ClientUI | |Notifications init: Soundpack path: /opt/sinusbot2/teamspeak3-client/sound/nosounds
2018-08-09T20:44:47-05:00 TS |INFO | | |*** Time [INIT]: 148
2018-08-09T20:44:47-05:00 TS |INFO | | |*** Time [MAINWINDOW]: 148
2018-08-09T20:44:42-05:00 TS |INFO | | |successfully downloaded revocation list
2018-08-09T20:44:42-05:00 Could not send config: HTTP returned an error: Error; Code: 500; Message: Error
2018-08-09T20:44:42-05:00 TS |INFO |Plugins | |Loading plugin: libsoundbot_plugin.so
2018-08-09T20:44:42-05:00 TS |INFO |Addons | |Checking for addon updates...
2018-08-09T20:44:42-05:00 TS |INFO |ClientUI | |Unable to create an Open GL context.
2018-08-09T20:44:42-05:00 TS |ERROR |SoundBckndIntf| |/opt/sinusbot2/teamspeak3-client/soundbackends/libpulseaudio_linux_amd64.so error: INIT_PA_IMPL
2018-08-09T20:44:42-05:00 TS |ERROR |PulseAudio | |pa_context_connect failed -
2018-08-09T20:44:42-05:00 TS |ERROR |PulseAudio | |failed to connect to pulse audio server -
2018-08-09T20:44:42-05:00 TS |INFO | | |Using hardware aes
2018-08-09T20:44:42-05:00 TS |INFO | | |SystemInformation: Linux 2.6.32-042stab127.2 #1 SMP Thu Jan 4 16:41:44 MSK 2018 x86_64 Binary: 64bit
2018-08-09T20:44:42-05:00 TS |INFO | | |TeamSpeak 3 Client 3.1.9 (2018-05-04 13:54:44)
2018-08-09T20:44:35-05:00 Starting instance ts3server://94.23.201.5?port=9987&nickname=KEY&password=&channel=&channelpassword=
2018-08-09T20:44:34-05:00 Could not create Notifications-Tabletable Notifications already exists
2018-08-09T20:44:34-05:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
2018-08-09T20:44:34-05:00 Could not create Chat-Tabletable Chat already exists
2018-08-09T20:44:29-05:00 BOT-CONFIG [admin] CHAN CHANPW ANNOUNCE DESCRIPTION ANNOUNCESTR TTSURL CC OK
