Connect - Play - Disconnect
Olli2k
Hey, habe mich gerade mal an dem Sinusbot versucht und dafür das Install Script verwendet. Alles ist also in Standard Pfaden auf einem Debian 9.6 System. Der Zeilserver ist auch localhost und läuft momentan auf der Version: 3.4.0
Das Log vom Sinusbot sieht folgendermaßen aus:
2019/01/03 13:46:00 a1aecc20 5350c981 WARN   Could not create Chat-Tabletable Chat already exists
2019/01/03 13:46:00 a1aecc20 5350c981 WARN   Could not create WhisperReceive-Tabletable WhisperReceive already exists
2019/01/03 13:46:00 a1aecc20 5350c981 WARN   Could not create Notifications-Tabletable Notifications already exists
2019/01/03 13:46:00 a1aecc20 5350c981 INFO   Starting instance ts3server://domain.de?port=port&nickname=MusicBot&password=&cid=46&channelpassword=
2019/01/03 13:46:00 X [MAIN] New connection
2019/01/03 13:46:00 a1aecc20 5350c981 INFO   TS |INFO    |              |   |TeamSpeak 3 Client 3.2.3 (2018-10-02 07:57:10)
2019/01/03 13:46:00 a1aecc20 5350c981 INFO   TS |INFO    |              |   |SystemInformation: Linux 4.9.0-8-amd64 #1 SMP Debian 4.9.130-2 (2018-10-27) x86_64 Binary: 64bit
2019/01/03 13:46:00 a1aecc20 5350c981 INFO   TS |INFO    |              |   |Using hardware aes
2019/01/03 13:46:00 a1aecc20 5350c981 INFO   TS |ERROR   |PulseAudio    |   |failed to connect to pulse audio server -
2019/01/03 13:46:00 a1aecc20 5350c981 INFO   TS |ERROR   |PulseAudio    |   |pa_context_connect failed -
2019/01/03 13:46:00 a1aecc20 5350c981 INFO   TS |ERROR   |SoundBckndIntf|   |/opt/sinusbot/teamspeak3-client/soundbackends/libpulseaudio_linux_amd64.so error: INIT_PA_IMPL
2019/01/03 13:46:00 a1aecc20 5350c981 INFO   TS |INFO    |ClientUI      |   |Unable to create an Open GL context.
2019/01/03 13:46:00 a1aecc20 5350c981 INFO   TS |ERROR   |RevocationListCache|   |Failed to import revocation list from cache
2019/01/03 13:46:00 a1aecc20 5350c981 INFO   TS |INFO    |Addons        |   |Checking for addon updates...
2019/01/03 13:46:00 a1aecc20 5350c981 INFO   TS |INFO    |Plugins       |   |Loading plugin: libsoundbot_plugin.so
2019/01/03 13:46:00 a1aecc20 5350c981 INFO   TS |INFO    |              |   |successfully downloaded revocation list for accounting
2019/01/03 13:46:00 a1aecc20 5350c981 INFO   TS |INFO    |              |   |successfully downloaded revocation list for myteamspeak id
2019/01/03 13:46:01 a1aecc20 5350c981 INFO   TS |INFO    |              |   |*** Time [MAINWINDOW]: 169
2019/01/03 13:46:01 a1aecc20 5350c981 INFO   TS |INFO    |              |   |*** Time [INIT]: 170
2019/01/03 13:46:01 a1aecc20 5350c981 INFO   TS |DEVELOP |ClientUI      |   |Notifications init: Soundpack path: /opt/sinusbot/teamspeak3-client/sound/nosounds
2019/01/03 13:46:01 a1aecc20 5350c981 INFO   TS |INFO    |ClientUI      |   |Failed to init text to speech engine
2019/01/03 13:46:01 a1aecc20 5350c981 INFO   TS |INFO    |ClientUI      |   |Qt version: 5.6.1
2019/01/03 13:46:01 a1aecc20 5350c981 INFO   TS |INFO    |ClientUI      |   |Using configuration location: /opt/sinusbot/data/ts3/a1aecc20-5373-4b21-b018-ce9a7f2cd9b8/5350c981-9707-4d14-9981-c8567fff01e2/settings.db
2019/01/03 13:46:01 a1aecc20 5350c981 INFO   TS |INFO    |ClientUI      |   |ts3server: domain.de?port=port&nickname=MusicBot&password=&cid=46&channelpassword=
2019/01/03 13:46:01 a1aecc20 5350c981 INFO   TS |INFO    |ClientUI      |1  |Connect to server: domain.de
2019/01/03 13:46:01 a1aecc20 5350c981 INFO   TS |INFO    |ClientUI      |1  |Trying to resolve bping.de
2019/01/03 13:46:01 a1aecc20 5350c981 INFO   TS |INFO    |Bookmarks     |   |Collecting autoconnect bookmarks
2019/01/03 13:46:01 a1aecc20 5350c981 INFO   TS |INFO    |ClientUI      |   |Last update check was: Di. Jan. 1 00:00:01 2019
2019/01/03 13:46:01 a1aecc20 5350c981 INFO   TS |INFO    |ClientUI      |   |Checking for update
2019/01/03 13:46:01 a1aecc20 5350c981 INFO   TS |INFO    |TSDNS         |   |SRV DNS resolve unsuccessful, "_ts3._udp.domain.de" DNS server returned answer with no data
2019/01/03 13:46:01 a1aecc20 5350c981 INFO   TS |INFO    |TSDNS         |   |A/AAAA DNS resolve for possible TSDNS successful, "domain.de" =(h: 2a01:4f8:190:8064::2 p:0), (h: 144.76.5.101 p:0)
2019/01/03 13:46:01 a1aecc20 5350c981 INFO   TS |INFO    |TSDNS         |   |A/AAAA DNS resolve successful, "domain.de" =(h: 2a01:4f8:190:8064::2 p:0), (h: 144.76.5.101 p:0)
2019/01/03 13:46:01 a1aecc20 5350c981 INFO   TS |INFO    |TSDNS         |   |SRV DNS resolve unsuccessful, "_tsdns._tcp.domain.de" DNS server returned answer with no data
2019/01/03 13:46:01 a1aecc20 5350c981 INFO   TS |INFO    |TSDNS         |   |TSDNS queried unsuccessfully ipv6:ipv6:ipv6:ipv6::2:41144
2019/01/03 13:46:01 a1aecc20 5350c981 INFO   TS |INFO    |TSDNS         |   |TSDNS queried unsuccessfully ipv4.ipv4.ipv4.ipv4:41144
2019/01/03 13:46:01 a1aecc20 5350c981 INFO   TS |INFO    |TSDNS         |   |No TSDNS found
2019/01/03 13:46:01 a1aecc20 5350c981 INFO   TS |INFO    |Update        |   |Checking for updates...
2019/01/03 13:46:01 a1aecc20 5350c981 INFO   TS |INFO    |ClientUI      |1  |Lookup finished: ip=****::2 port=7777 query=bping.de error=0
2019/01/03 13:46:01 a1aecc20 5350c981 INFO   TS |INFO    |ClientUI      |1  |Resolve successful: [****::2]:7777144.76.5.101:***
2019/01/03 13:46:01 a1aecc20 5350c981 INFO   TS |INFO    |ClientUI      |1  |Initiating connection: [****::2]:****
2019/01/03 13:46:02 a1aecc20 5350c981 INFO   TS |INFO    |PreProSpeex   |1  |Speex version: 1.2rc1
2019/01/03 13:46:02 a1aecc20 5350c981 INFO   TS |INFO    |Update        |   |Check license: version=4, min_version=4, my_license_version=4, my_license_min_version=1
2019/01/03 13:46:02 a1aecc20 5350c981 INFO   TS |INFO    |LicenseViewer |   |View license: version=4, language=en, require accept=1
2019/01/03 13:46:02 a1aecc20 5350c981 INFO   TS |INFO    |LicenseViewer |   |Found cached license for version 4 and language en
2019/01/03 13:46:02 a1aecc20 5350c981 INFO   TS |INFO    |ClientUI      |1  |Connect status: Connecting
2019/01/03 13:46:02 a1aecc20 5350c981 INFO   New connection status 1; Error 0
2019/01/03 13:46:07 a1aecc20 5350c981 INFO   TS |INFO    |ClientUI      |1  |Connect status: Disconnected
2019/01/03 13:46:07 a1aecc20 5350c981 INFO   The bot could not connect. This might have several reasons: the server doesn't exist at that address, the server password is wrong, the default channel doesn't exist, the bot has been banned, the server is an illegal installation or the password is wrong , the security level of your identity is too low or the server does not allow the version of the client you are using. See our Wiki / Forums for more help.
2019/01/03 13:46:07 a1aecc20 5350c981 INFO   New connection status 0; Error 1797
2019/01/03 13:46:07 a1aecc20 5350c981 INFO   TS |INFO    |ClientUI      |1  |Initiating connection: ipv4:1234
2019/01/03 13:46:07 a1aecc20 5350c981 INFO   TS |INFO    |ClientUI      |1  |Connect status: Connecting
2019/01/03 13:46:07 a1aecc20 5350c981 INFO   New connection status 1; Error 0
2019/01/03 13:46:07 a1aecc20 5350c981 INFO   TS |DEVELOP |PktHandler    |   |Puzzle solve time: 4
2019/01/03 13:46:07 a1aecc20 5350c981 INFO   TS |INFO    |ClientUI      |1  |Connect status: Connected
2019/01/03 13:46:07 a1aecc20 5350c981 INFO   New connection status 2; Error 0
2019/01/03 13:46:07 a1aecc20 5350c981 INFO   TS |INFO    |ClientUI      |1  |Connect status: Establishing connection
2019/01/03 13:46:07 a1aecc20 5350c981 INFO   New connection status 3; Error 0
2019/01/03 13:46:07 a1aecc20 5350c981 WARN   Error in script (event clientMove): TypeError: Cannot access member 'replace' of undefined
    at welcome.js:23:15
2019/01/03 13:46:07 Deprecated use of .ID() on Channel. Please use .id() instead.
    at welcome.js:23:15
2019/01/03 13:46:07 a1aecc20 5350c981 INFO   TS |INFO    |ClientUI      |1  |Connect status: Connection established
2019/01/03 13:46:07 a1aecc20 5350c981 INFO   TS |INFO    |PermManager   |   |Loading permissions from cache
2019/01/03 13:46:07 a1aecc20 5350c981 INFO   New connection status 4; Error 0
2019/01/03 13:46:07 a1aecc20 5350c981 INFO   TS |INFO    |              |   |No image, refusing to display
2019/01/03 13:46:08 a1aecc20 5350c981 INFO   TSClient quit.
Troubleshooting bin ich durch, in der Praxis connected der Bot, spielt ca. 0,3 Sekunden Musik und verstummt und disconencted dann mit connection lost.
Vielen Dank im voraus.
Olli2k
Auf Loglevel 10 ist noch folgendes hinzu gekommen:
2019/01/03 15:37:25 a1aecc20 5350c981 DEBUG  TS>QCoreApplication::applicationDirPath: Please instantiate the QApplication object first
2019/01/03 15:37:25 a1aecc20 5350c981 DEBUG  TS>QXcbIntegration: Cannot create platform OpenGL context, neither GLX nor EGL are enabled
2019/01/03 15:37:25 a1aecc20 5350c981 DEBUG  TS>XDG_RUNTIME_DIR (/run/user/0) gehört uns (Benutzerkennung 1001) nicht, sondern der Benutzerkennung 0! Dies kann beispielsweise passieren, wenn Sie sich über das native Protokoll als Root-Benutzer mit einem ohne Root-Rechte betriebenen PulseAudio-Server verbinden wollen. Sie sollten dies nicht tun.
2019/01/03 15:37:25 a1aecc20 5350c981 DEBUG  TS>libpng warning: iCCP: known incorrect sRGB profile
2019/01/03 15:37:25 a1aecc20 5350c981 DEBUG  Closed.
2019/01/03 15:37:25 a1aecc20 5350c981 INFO   TSClient quit.
2019/01/03 15:37:51 a1aecc20 5350c981 DEBUG  Storing configuration.
Ausgabe von:
xinit /opt/sinusbot/teamspeak3-client/ts3client_linux_amd64 -- /usr/bin/Xvfb :1 -screen 0 800x600x16 -ac
Ist:
/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: error while loading shared libraries: libquazip.so: cannot open shared object file: No such file or directory
Olli2k
Ich habe jetzt mal die Libarys quick and dirty gesymlinkt und das Ergebnis sieht jetzt so aus:
This application failed to start because it could not find or load the Qt platform plugin "xcb"
in "".
Available platform plugins are: xcb.
Reinstalling the application may fix this problem.
A
Al3x
Guest
Hey Olli2k,
bitte versuche folgendes:
1. Lösche alle Sinusbot-Dateien (normalerweise unter /opt/sinusbot)
2. Update deinen Host (ssh --> "apt-get update && apt-get upgrade")
3. Installiere den Sinusbot neu und nutze hierfür die offizielle Anleitung: https://wiki.sinusbot.com/en:guides:installation:linux
4. Sinusbot via Webinterface (Port 8087) konfigurieren und auf deinen TS/Discord joinen lassen.
Kannst uns gerne ne Info dalassen ob es geklappt hat.
Viel Glück & Viele Grüße
Alex
Olli2k
Danke für die Hilfe, habe auch alles exakt wie in dem Tutorial beschrieben neu installiert, aber bis auf den Pfad für die TS3 Client Installation hat sich nichtw geändert. Gleiches Verhalten und das gleiche Log:
2019/01/08 11:51:51 9143df65 23fb8259 INFO   TS |INFO    |              |   |No image, refusing to display
2019/01/08 11:51:51 9143df65 23fb8259 DEBUG  TS>QCoreApplication::applicationDirPath: Please instantiate the QApplication object fi                              rst
2019/01/08 11:51:51 9143df65 23fb8259 DEBUG  TS>QXcbIntegration: Cannot create platform OpenGL context, neither GLX nor EGL are ena                              bled
2019/01/08 11:51:51 9143df65 23fb8259 DEBUG  TS>XDG_RUNTIME_DIR (/run/user/0) gehört uns (Benutzerkennung 1001) nicht, sondern der                               Benutzerkennung 0! Dies kann beispielsweise passieren, wenn Sie sich über das native Protokoll als Root-Benutzer mit einem ohne Roo                              t-Rechte betriebenen PulseAudio-Server verbinden wollen. Sie sollten dies nicht tun.
2019/01/08 11:51:51 9143df65 23fb8259 DEBUG  TS>libpng warning: iCCP: known incorrect sRGB profile
2019/01/08 11:51:51 9143df65 23fb8259 INFO   TSClient quit.
2019/01/08 11:51:51 9143df65 23fb8259 DEBUG  Closed.
2019/01/08 11:52:11 9143df65 23fb8259 DEBUG  Storing configuration.
A
Al3x
Guest
Hi Oli,
kann es sein, dass du den Bot als Root gestartet hast?
Wenn du dich via SSH auf deinen Rootserver/VPS verbindest kannst du das gerne als Root tun, danach wechsle bitte mit "su <Benutzername>" zu deinem Benutzer den du für den Sinusbot angelegt hast. Versuche dann nochmal, den Bot zu starten.
Zudem solltest du vor dem starten mal den Scripts-Ordner leeren.
Viel Erfolg! :)
Grüße
Alex
Olli2k
Nein, der Bot läuft nicht als Root. Wie im Tutorial beschrieben wurde ein neuer User dafür eingerichtet und dieser wird auch benutzt. Ein leeren des Script Ordner hat nicht geholfen.
Das Problem bleibt unverändert.
Olli2k
Sry, hätte ich schon lange posten müssen:
 - Operating System: Debian GNU/Linux 9.6 (stretch)
 - Kernel: Linux 4.9.0-8-amd64 x86_64
 - Load Average: 0.22 0.06 0.06
 - Uptime: 9 days, 1 hours, 5 minutes, 37 seconds
 - OS APT Last Update: 17.01.2019 15:00:10 CET +01:00:00
    CPU(s):                8
    CPU MHz:               1601.013
 - RAM: 6.37 GB/15.37 GB in use (41%)
 - SWAP: 87.15 MB/7.99 GB in use (1%)
 - DISK: 153.18 GB/2.67 TB in use (5%)
   + libglib: 2.50.3-2
 - Version: 0.14.3-0e747fd
   - TS3Path = /opt/sinusbot/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64 (Version 3.2.3)
   - YoutubeDLPath = not set (does exist anyway, version: 2019.01.02)
 - Installed scripts: *.js
 - Time (local): 17.01.2019 15:54:04 CET +01:00:00
 - Time (remote): 17.01.2019 15:54:04 CET +01:00:00
 - TeamSpeak 3 Version: 3.2.3
 - youtube-dl Version: 2019.01.02
 - DiagScript Version: 0.7.1
No DMs please - Currently inactive
Teste doch mal die version 1.0.0-alpha (siehe Insider Beta)
Olli2k
2019/01/17 16:12:37 9143df65 23fb8259 DEBUG TS>QCoreApplication::applicationDirPath: Please instantiate the QApplication object first
2019/01/17 16:12:37 9143df65 23fb8259 DEBUG TS>QXcbIntegration: Cannot create platform OpenGL context, neither GLX nor EGL are enabled
2019/01/17 16:12:37 9143df65 23fb8259 DEBUG TS>libpng warning: iCCP: known incorrect sRGB profile
2019/01/17 16:12:37 9143df65 23fb8259 DEBUG Closed.
2019/01/17 16:12:37 9143df65 23fb8259 INFO TSClient quit.
^C
2019/01/17 16:12:58 [GENERAL ] Shutting down... Hold on...
Auf Version:
 - Load Average: 0.07 0.14 0.10
 - Uptime: 9 days, 1 hours, 27 minutes, 58 seconds
 - OS APT Last Update: 17.01.2019 16:00:07 CET +01:00:00
    CPU(s):                8
    CPU MHz:               1599.975
 - RAM: 6.39 GB/15.37 GB in use (41%)
 - DISK: 153.21 GB/2.67 TB in use (5%)
   + libglib: 2.50.3-2
 - Binary Info: MD5 Hash: 066ec3dae178e4fe6e11dc726a6a84ab, Perms: 755, User: sinusbot
 - Version: 1.0.0-alpha.2-9a3be66
   - Bot Plugin: 0cb7720523475e509ea99d101804e5f0
   - TS3 Client: 0cb7720523475e509ea99d101804e5f0
 - Time (local): 17.01.2019 16:16:25 CET +01:00:00
 - Time (remote): 17.01.2019 16:16:25 CET +01:00:00
<16:12:35> "MusicBot" loggte sich in Channel "Music" ein
<16:13:04> Die Verbindung von "MusicBot" wurde unterbrochen (connection lost)
Gleiches Verhalten.
Der Server ist als Stretch minimal image aufgesetzt worden. Muss da noch iregendwas an sonstigen Packages drauf?
GLXinfo sagt zum Beispiel:
[email protected]:/opt/sinusbot$ glxinfo
Error: unable to open display
Denn Fehler hatte ich auch Mal, lag bei mir glaub ich daran das ich von TS 3.0.19.4 auf TS 3.1 geupgraded hätte und dann denn TS Data Ordner nicht entfernt hatte. Weiß nicht ob das bei dir der Fall ist.
Sonst nochmal: Bist du sicher das du die qxl Integration File gelöscht hast?
Olli2k
Da ich ja kein Update gemacht habe, sondern eine frische Installation, sollte das eigentlich nicht der Fall sein. Allerdings finde ich auch kein "Data" ordner im TeamSpeak3-Client-linux_amd64 Verzeichnis. Ich habe aber wie gesagt schon 4 mal alles gelöscht und von vorne angefangen. Und immer mit der v3.2.3..
[email protected] ~ # ls /opt/sinusbot/TeamSpeak3-Client-linux_amd64/xcbglintegrations
libqxcb-egl-integration.so
Da im Tutorial steht :
rm TeamSpeak3-Client-linux_amd64/xcbglintegrations/libqxcb-glx-integration.so
gehe ich davon aus, dass die egl Datei nicht gelöscht werden sollte, oder muss die auch weg?
Nope, nur die Datei die aufgeführt ist. Wenns kein update war dann weiß ich auch nicht weiter, sorry. Evtl kann @flyth da noch was zu sagen, sonst ka.
Olli2k
Also, ich habe gerade nochmal rm sinusbot -r in /opt/ gemacht. Dann habe ich es nochmal mit dem Script versucht und zunächst noch einmal den Menüpunkt remove gewählt. Danach habe ich alles über das Script neu installiert und jetzt läuft er.. Ich habe keinen blassen Schimmer, was falsch war, aber jetzt bekomme ich nur noch eine Menge Script Fehler "TypeError: Cannot access member 'replace' of undefined at welcome.js:23:15" und wenn ich ein paar mal in den Bot Chanel wechsel und wieder raus gehe: "Server wurde gestoppt: Server Shutdown!". Aber es läuft ;).
Scriptfehler dürften an problemen zwischen den alten scripts und der neuen event Logik liegen. Soweit ich weiß werden jetzt schon beim connecten z.B. channel create events abgefeuert.
Evtl sind die events auch einfach schlecht abgefangen und werden so z.B. schon ausgeführt wenn der bot geladen ist aber noch nicht connected. Dann gibt es natürlich auch errors.
Olli2k
Um die Sache bezüglich der Server Shutdowns noch aufzuklären:
Bei mir läuft alle 5 Minuten ein cron auf ein bash script, welches mit:
ps ax | grep ts3server | grep -v grep | wc -l
prüft, ob der Server online ist, als Ergebnis wurde bisher 1 erwartet und falls das nicht der Fall ist, wurde der Server restartet. Nun, der Sinusbot hat das Ergebnis auf 2 erhöht und somit gab es alle 5 Minuten einen "gewollten" Restart. Das Script habe ich angepasst, jetzt gibt es auch keine Shutdowns mehr. Scripte laufen auch alle soweit, bis auf das Welcome.js.
Ist jetzt aber auch nicht wichtig. Betriebsmodus ist jetzt akzeptabel und vielen Dank für die vielen Denkanstöße!
