Solved Could not connect to display unix/:40.0
MexmexMe
Betriebssystem: Linux
SinusBot Version: weiß ich nicht
TS3 Version: weiß ich nicht
Problembeschreibung
Ich habe eine neue Instanz erstellt und wollte den Bot starten, jedoch kommt diese Fehlermeldung.
Wäre nett, wenn mir jemand helfen könnnte. :)
2017-11-02T22:40:32+01:00 Storing configuration.
2017-11-02T22:40:13+01:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2017-11-02T22:40:13+01:00 Closed.
2017-11-02T22:40:13+01:00 TS>QXcbConnection: Could not connect to display unix/:40.0
2017-11-02T22:40:13+01:00 Starting instance ts3server://ip175.ip-151-80-53.eu?port=9987&nickname=Test&password=&channel=&channelpassword=
2017-11-02T22:40:12+01:00 Could not insert into News-Tableno such table: News
2017-11-02T22:40:12+01:00 Could not delete from Newsno such table: News
2017-11-02T22:40:12+01:00 Could not insert into Profiles-Tableno such table: Profiles
2017-11-02T22:40:12+01:00 Could not delete from Profilesno such table: Profiles
2017-11-02T22:40:12+01:00 Could not insert into FileTransfer-Tableno such table: FileTransfer
2017-11-02T22:40:12+01:00 Could not delete from FileTransferno such table: FileTransfer
2017-11-02T22:40:12+01:00 Could not create Notifications-Tabletable Notifications already exists
2017-11-02T22:40:12+01:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
2017-11-02T22:40:12+01:00 Could not create Chat-Tabletable Chat already exists
2017-11-02T22:40:12+01:00 About to run.
2017-11-02T22:40:12+01:00 Prespawn.
2017-11-02T22:35:32+01:00 Storing configuration.
2017-11-02T22:35:28+01:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2017-11-02T22:35:28+01:00 Closed.
2017-11-02T22:35:28+01:00 TS>QXcbConnection: Could not connect to display unix/:40.0
2017-11-02T22:35:28+01:00 Starting instance ts3server://ip175.ip-151-80-53.eu?port=9987&nickname=Test&password=&channel=&channelpassword=
2017-11-02T22:35:27+01:00 Could not insert into News-Tableno such table: News
2017-11-02T22:35:27+01:00 Could not delete from Newsno such table: News
2017-11-02T22:35:27+01:00 Could not insert into Profiles-Tableno such table: Profiles
2017-11-02T22:35:27+01:00 Could not delete from Profilesno such table: Profiles
2017-11-02T22:35:27+01:00 Could not insert into FileTransfer-Tableno such table: FileTransfer
2017-11-02T22:35:27+01:00 Could not delete from FileTransferno such table: FileTransfer
2017-11-02T22:35:27+01:00 About to run.
2017-11-02T22:35:27+01:00 Prespawn.
2017-11-02T22:35:25+01:00 BOT-CONFIG [admin] NICK NAME HOST CHAN CHANPW ANNOUNCE DESCRIPTION ANNOUNCESTR TTSURL CC OK
2017-11-02T22:34:32+01:00 Storing configuration.
2017-11-02T22:34:30+01:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2017-11-02T22:34:30+01:00 Closed.
2017-11-02T22:34:30+01:00 TS>QXcbConnection: Could not connect to display unix/:40.0
2017-11-02T22:34:30+01:00 Starting instance ts3server://timolp.de?port=9987&nickname=FAQBOT&password=&channel=&channelpassword=
2017-11-02T22:34:30+01:00 About to run.
2017-11-02T22:34:30+01:00 Prespawn.
2017-11-02T22:34:17+01:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2017-11-02T22:34:17+01:00 Closed.
2017-11-02T22:34:17+01:00 TS>QXcbConnection: Could not connect to display unix/:40.0
2017-11-02T22:34:17+01:00 Starting instance ts3server://timolp.de?port=9987&nickname=FAQBOT&password=&channel=&channelpassword=
2017-11-02T22:34:17+01:00 About to run.
2017-11-02T22:34:17+01:00 Prespawn.
2017-11-02T22:34:14+01:00 BOT-CONFIG [admin] HOST CHAN CHANPW ANNOUNCE DESCRIPTION ANNOUNCESTR TTSURL CC OK
2017-11-02T22:34:02+01:00 Storing configuration.
2017-11-02T22:34:01+01:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2017-11-02T22:34:01+01:00 Closed.
2017-11-02T22:34:01+01:00 TS>QXcbConnection: Could not connect to display unix/:40.0
2017-11-02T22:34:01+01:00 Starting instance ts3server://151.80.53.175?port=9987&nickname=FAQBOT&password=&channel=&channelpassword=
2017-11-02T22:34:01+01:00 About to run.
2017-11-02T22:34:01+01:00 Prespawn.
2017-11-02T22:33:57+01:00 BOT-CONFIG [admin] NAME HOST CHAN CHANPW ANNOUNCE DESCRIPTION ANNOUNCESTR TTSURL CHATIGNSRV CHATIGNCHAN CC OK
2017-11-02T22:33:32+01:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2017-11-02T22:33:32+01:00 Starting instance ts3server://?port=9987&nickname=FAQBOT&password=&channel=&channelpassword=
2017-11-03T13:10:11+01:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2017-11-03T13:10:11+01:00 Closed.
2017-11-03T13:10:11+01:00 TS>QXcbConnection: Could not connect to display unix/:40.0
2017-11-03T13:10:11+01:00 Starting instance ts3server://151.80.53.175?port=9987&nickname=test3&password=&channel=&channelpassword=
2017-11-03T13:10:11+01:00 About to run.
2017-11-03T13:10:11+01:00 Prespawn.
2017-11-03T13:10:09+01:00 BOT-CONFIG [admin] HOST CHAN CHANPW ANNOUNCE DESCRIPTION ANNOUNCESTR TTSURL CC OK
2017-11-03T13:05:40+01:00 Storing configuration.
2017-11-03T13:05:32+01:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2017-11-03T13:05:32+01:00 Closed.
2017-11-03T13:05:32+01:00 TS>QXcbConnection: Could not connect to display unix/:40.0
2017-11-03T13:05:32+01:00 Starting instance ts3server://timolp.de?port=9987&nickname=test3&password=&channel=&channelpassword=
2017-11-03T13:05:32+01:00 About to run.
2017-11-03T13:05:32+01:00 Prespawn.
2017-11-03T13:05:29+01:00 BOT-CONFIG [admin] NAME HOST CHAN CHANPW ANNOUNCE DESCRIPTION ANNOUNCESTR TTSURL CC OK
2017-11-03T13:05:10+01:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2017-11-03T13:05:10+01:00 Starting instance ts3server://?port=9987&nickname=test3&password=&channel=&channelpassword=
No DMs please - Currently inactive
Danke für deine sinnvole und hilfreiche Nachricht.
Kein Problem, ich Helfe wo ich kann :)
Ich weiß einfach nicht, wo man nachschaut, welche Version man hat.
In diesem sub-Forum ist ganz oben der Thread "LIES MICH BEVOR DU SCHREIBST" verlinkt in dem wiederum das Diag script vom lieben PatschPatsch verlinkt ist (beim erstellen der Threads wird man auch gebeten den Output davon Anzuhängen).
MexmexMe
 - Operating System: Debian GNU/Linux 8.9 (jessie) (OpenVZ)
 - Kernel: Linux 2.6.32-042stab120.6 x86_64
 - Load Average: 0.65 0.39 0.38
 - Uptime: 5 days, 23 hours, 35 minutes, 8 seconds
 - OS APT Last Update: 03.11.2017 09:24:41 EDT -04:00:00
 - RAM:  B/6.00 GB in use (%)
 - SWAP:  B/ B in use (%)
 - DISK: 2.73 GB/197.26 GB in use (1%)
  > libglib: 2.42.1-1+b1
 - Status: running (PIDs: 31843 31842, User: sinusbot)
 - Binary: /opt/sinusbot/sinusbot (MD5 Hash: febce0ebdd2d2e9d7f69701bc5a7c339)
 - Version: 0.10.8-71ba94b
  - TS3Path = /opt/sinusbot/teamspeak3-client/ts3client_linux_amd64 (Version 3.0.18.2)
  - YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2017.10.29)
 - Installed scripts: advertising.js; alonemode.js; bookmark.js; followme.js; norecording.js; rememberChannel.js; support-channel manager_de.js; welcome.js
 - Report date: 03.11.2017 09:25:08 EDT -04:00:00 (timezone: America/New_York)
 - youtube-dl Version: 2017.10.29
 - DiagScript version: 0.5.1
MexmexMe
Habe es mal jetzt neu installiert und es geht eigentlich auch.
Aber wenn ich putty schließe (also die sinusbot "Konsole") dann gehen die Bots offline.
Jniklas2
weil der Prozess dann auch automatisch beendet wird
Versuche den Bot mal mit
screen -S sinusbot ./sinusbot
zu starten
Um dann später wieder zur Konsole zu verbinden nutze einfach
screen -r sinusbot
Wenn da was kommt das der Befehl nicht gefunden wurde, dann installiere das Programm screen (bei Debian macht man das mit
apt install screen
Der Befehl muss mit Root Rechten ausgeführt werden)
Jniklas2
Oder noch einfacher: Deinstallier den Bot und nutz das Installer Script welches dir das starten und stoppen deutlich erleichtert weil du da nur zum starten
service sinusbot start
und zum stoppen
service sinusbot stop
eingeben musst
