Solved Could not insert into Profiles-Tablefile is encrypted or is not a database - Solved
iPistachi
Operating System: Linux Ubuntu 14.04.4 LTS
SinusBot Version: 0.9.18-8499d2c
TS3 Version: 3.0.19.4
I received this error message in the log!!!
And the bot does not starto_O
Could not delete from Profilesfile is encrypted or is not a database
How I solved
Go to the sinusbot folder
YourSinusBotFolder/data/ts3/(A ID Like this 32yb9jk7-1747.....)
Find the Bot that has the problem by the Instance-ID. You can find the ID in :
(Choose the bot with problems) YouBot --> Instance Settings
At the bottom of the page you can find the ID
Instance-ID: a63ff6789-f2ds-3bf6-sr4.....
Now rename the folder to Ex. OLD-a63ff6789-f2ds-3bf6-sr4.....
In the Sinusbot page, try to restart the bot, a new folder (a63ff6789-f2ds-3bf6-sr4.....) will be created, wait a while and restart again the bot.
Okay, problem solved.
Worked here.
(The ID a63ff6789-f2ds-3bf6-sr4..... was invented to explain better.);)
I hope to help someone.:)
