Solved How to add a Radio Station
Danielitor
HERE IS THE FINAL SOLUTION!
1- ACCESS A http://www.listenlive.eu/ AND SELECT THE COUNTRY OF THE RADIO YOU ARE LOOKING FOR.
2- SEARCH THE RADIO THAT YOU WANT TO ADD AND DOWNLOAD THE .PLC FILE (by clicking below listen live).
3- ONCE DOWNLOADED THE .PLC FILE; LET'S GO TO OUR SINUSBOT PANEL, CLICK ON ALL MUSIC, THEN CLICK ON ADD URL.
4- NOW YOU MUST LOOK FOR THE .PLC FILE THAT YOU DOWNLOADED AND DRAG ON THE BOX THAT IS OPEN WHEN PRESSING IN ADD URL IN THE SINUSBOT PANEL.
5- OPEN A LIST WITH VARIOUS LINKS, COPY ANYWHERE FROM BEGINNING TO END (example: "http://20043.live.streamtheworld.com:80/LOS40_SC".
6- LAST, WE RECHARGE THE SINUSBOT PANEL AND RETURN TO PRESS URL ADD; BUT THIS TIME WE WILL PEGAR THE LINK THAT WE COPIED IN THE PREVIOUS AND READY STEP.
CONGRATULATIONS, YOU'VE ALREADY ADDED YOUR RADIO!
