I can’t connect after updating
angarsk3
SinusBot 1.0.0-beta.10-202ee4d
2020-01-25T17:32:50+08:00 error on setTimeout/setInterval callback: Uncaught exception: TypeError: Cannot read property 'getCurrentTrack' of undefined at Advanced_Display_Playback_Information:114:29 var track = sinusbot.getCurrentTrack(); ^ Stack trace: TypeError: Cannot read property 'getCurrentTrack' of undefined at Advanced_Display_Playback_Information:114:30
2020-01-25T17:32:49+08:00 error on setTimeout/setInterval callback: Uncaught exception: TypeError: Cannot read property 'getCurrentTrack' of undefined at Advanced_Display_Playback_Information:114:29 var track = sinusbot.getCurrentTrack(); ^ Stack trace: TypeError: Cannot read property 'getCurrentTrack' of undefined at Advanced_Display_Playback_Information:114:30
2020-01-25T17:32:48+08:00 error on setTimeout/setInterval callback: Uncaught exception: TypeError: Cannot read property 'getCurrentTrack' of undefined at Advanced_Display_Playback_Information:114:29 var track =
angarsk3
Version: 1.0.0-beta.10-202ee4d
2020/01/25 12:49:41 27f9bfc5          INFO   Loading instances
2020/01/25 12:49:41 27f9bfc5          INFO   Loading instance://2b65c676-0ae8-4c4d-8507-45480c8aa58d
2020/01/25 12:49:41 27f9bfc5 2b65c676 PLUGIN [sinusbot-commands:86:12] Loaded SinusBot Commands v1.0.0 by Jonas Bögle (@irgendwr).
2020/01/25 12:49:41 27f9bfc5 2b65c676 INFO   script sinusbot-commands loaded
2020/01/25 12:49:41 27f9bfc5 2b65c676 INFO   script command loaded
2020/01/25 12:49:41 27f9bfc5 2b65c676 INFO   script CountOnlineUsers loaded
2020/01/25 12:49:41 27f9bfc5 2b65c676 INFO   script LastFM_Scrobbling loaded
2020/01/25 12:49:41 27f9bfc5 2b65c676 PLUGIN [AFK_Mover_(AwayMuteDeafIdle):695:24] [INFO] debug messages are disabled
2020/01/25 12:49:41 27f9bfc5 2b65c676 PLUGIN [AFK_Mover_(AwayMuteDeafIdle):695:24] [INFO] AFK mover (Away/Mute/Deaf/Idle) v2.1.2 by irgendwer / Jonas <[email protected]
> loaded successfully!
2020/01/25 12:49:41 27f9bfc5 2b65c676 INFO   script AFK_Mover_(AwayMuteDeafIdle) loaded
2020/01/25 12:49:41 27f9bfc5 2b65c676 INFO   script Server_Join_Alert loaded
2020/01/25 12:49:41 27f9bfc5 2b65c676 INFO   script norecording loaded
2020/01/25 12:49:41 27f9bfc5 2b65c676 INFO   Initialization complete
2020/01/25 12:49:41 27f9bfc5 2b65c676 INFO   Last track was 20263a46-3fe2-4bbe-aca0-9b0fec133695, will auto-play soon
2020/01/25 12:49:41 27f9bfc5          INFO   Loading instance://c6fb5260-89ca-4938-9a85-1c6a11bd0c0b
2020/01/25 12:49:41 27f9bfc5 2b65c676 INFO   script Advanced_Display_Playback_Information loaded
2020/01/25 12:49:41 27f9bfc5 c6fb5260 INFO   script command loaded
2020/01/25 12:49:41 27f9bfc5 c6fb5260 PLUGIN [sinusbot-commands:86:12] Loaded SinusBot Commands v1.0.0 by Jonas Bögle (@irgendwr).
2020/01/25 12:49:41 27f9bfc5 c6fb5260 INFO   script sinusbot-commands loaded
2020/01/25 12:49:41 27f9bfc5 c6fb5260 INFO   script Advanced_Display_Playback_Information loaded
2020/01/25 12:49:41 27f9bfc5 c6fb5260 INFO   Initialization complete
2020/01/25 12:49:41 [GENERAL/FFMPEG ] INFO   FFmpeg/avcodec v3741798; license: LGPL version 2.1 or later; 81 codecs
2020/01/25 12:49:41 [GENERAL/FFMPEG ] INFO   FFmpeg/avformat v3742052; license: LGPL version 2.1 or later; 143 formats
2020/01/25 12:49:41 [GENERAL/YTDL   ] INFO   youtube-dl checking...
2020/01/25 12:49:41 27f9bfc5 c6fb5260 INFO   script wotrating loaded
2020/01/25 12:49:42 27f9bfc5 2b65c676 INFO   Auto-Playing last track
2020/01/25 12:49:42 27f9bfc5 2b65c676 PLUGIN error on setTimeout/setInterval callback: Uncaught exception: TypeError: Cannot read property 'getCurrentTrack' of undefined
2020/01/25 12:49:42 27f9bfc5 c6fb5260 PLUGIN error on setTimeout/setInterval callback: Uncaught exception: TypeError: Cannot read property 'getCurrentTrack' of undefined
2020/01/25 12:49:42 [GENERAL/YTDL   ] INFO   youtube-dl version compatible, support enabled
2020/01/25 12:49:42 [GENERAL/!!!!!!!] NOTICE You may now configure and launch the bots from the webinterface. http://0.0.0.0:8087
Disable your malfunctioning scripts, and try to get a vanilla bot installation running.
Afterwards you can put in those scripts one by one, to find the malicious ones. (or read the log)
angarsk3
2020-01-26T09:32:16+08:00 Storing configuration.
2020-01-26T09:32:09+08:00 closing channels
2020-01-26T09:32:08+08:00 Closed.
2020-01-26T09:32:08+08:00 TS>terminating with uncaught exception of type boost::exception_detail::clone_impl<boost::exception_detail::error_info_injector<boost::uuids::entropy_error> >: getrandom
2020-01-26T09:32:08+08:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2020-01-26T09:32:08+08:00 TS>QXcbIntegration: Cannot create platform OpenGL context, neither GLX nor EGL are enabled
2020-01-26T09:32:08+08:00 TS>QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-sinusbot'
2020-01-26T09:32:08+08:00 TS>qt.qpa.xkeyboard: no keyboard layouts with latin keys present
2020-01-26T09:32:08+08:00 TS>QCoreApplication::applicationDirPath: Please instantiate the QApplication object first
2020-01-26T09:32:08+08:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libdbus-1.so.3: no version information available (required by /opt/sinusbot/teamspeak3-client/libQt5WebEngineCore.so.5)
https://sinusbot.github.io/docs/installation/linux/#compatible-versions
You're most likely trying to run TS-client 3.3.x on a system with a kernel version lower than 3.17.
This won't work. You can check the compatible versions in the link above.
How to update teamspeak?
There's an exact answer to this in the FAQs. :rolleyes:
And fyi ... there no "update" command, strongly suggesting to tighten your linux knowledge a little, if you wan't to leave the path sticking to the FAQs.
angarsk3
2020-01-27T20:56:14+08:00 eof from data
2020-01-27T20:56:14+08:00 eof from voice
2020-01-27T20:56:14+08:00 closing channels
2020-01-27T20:56:13+08:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2020-01-27T20:56:13+08:00 Closed.
2020-01-27T20:56:13+08:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: symbol lookup error: /opt/sinusbot/teamspeak3-client/libQt5XcbQpa.so.5: undefined symbol: FT_Get_Font_Format
2020-01-27T20:56:13+08:00 TS>QXcbIntegration: Cannot create platform OpenGL context, neither GLX nor EGL are enabled
2020-01-27T20:56:13+08:00 TS>QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-sinusbot'
2020-01-27T20:56:13+08:00 TS>qt.qpa.xkeyboard: no keyboard layouts with latin keys present
2020-01-27T20:56:13+08:00 TS>QCoreApplication::applicationDirPath: Please instantiate the QApplication object first
2020-01-27T20:56:13+08:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libdbus-1.so.3: no version information available (required by /opt/sinusbot/teamspeak3-client/libQt5WebEngineCore.so.5)
2020-01-27T20:56:13+08:00 TS |INFO |Addons | |Checking for addon updates...
2020-01-27T20:56:12+08:00 TS |ERROR |RevocationListCache| |Failed to import revocation list from cache
2020-01-27T20:56:12+08:00 TS |INFO |ClientUI | |Unable to create an Open GL context.
2020-01-27T20:56:12+08:00 TS |ERROR |SoundBckndIntf| |/opt/sinusbot/teamspeak3-client/soundbackends/libpulseaudio_linux_amd64.so error: INIT_PA_IMPL
2020-01-27T20:56:12+08:00 TS |ERROR |PulseAudio | |pa_context_connect failed -
2020-01-27T20:56:12+08:00 TS |ERROR |PulseAudio | |failed to connect to pulse audio server -
2020-01-27T20:56:12+08:00 TS |INFO | | |SystemInformation: Linux 4.9.0-0.bpo.11-amd64 #1 SMP Debian 4.9.189-3+deb9u2~deb8u1 (2019-11-12) x86_64 Binary: 64bit
2020-01-27T20:56:12+08:00 TS |INFO | | |TeamSpeak Client 3.3.2 (2019-08-25 21:13:34)
2020-01-27T20:56:12+08:00 TS>DUMP defined! Dumpdir is: /opt/sinusbot/data/ts3/2ef94147-2eac-455e-9696-beff5c69f068/a232d8c9-f8c9-475c-a7cb-debecfb13872/crashdumps
2020-01-27T20:56:12+08:00 TS>Crashdump ENABLED, directory is: /opt/sinusbot/data/ts3/2ef94147-2eac-455e-9696-beff5c69f068/a232d8c9-f8c9-475c-a7cb-debecfb13872/crashdumps
