Initialision error
Ezequiel
Here is my sinusbit output:
2016/08/13 14:07:49 6e025867 INFO   Initializing bot://6e025867-5c65-46ba-a3cb-21de9d586e99
2016/08/13 14:07:49 6e025867 817845cf DEBUG  Spawning instance shortly due to missing configuration file
2016/08/13 14:07:49 6e025867 817845cf INFO   Loaded
2016/08/13 14:07:49 FFmpeg/avcodec v3675236; license: LGPL version 2.1 or later; 494 codecs
2016/08/13 14:07:49 FFmpeg/avformat v3674980; license: LGPL version 2.1 or later; 139 formats
2016/08/13 14:07:49 6e025867 817845cf INFO   Starting instance ts3server://127.0.0.1?port=9987&nickname=TS3SB-Demobot&password=&channel=&channelpassword=
QXcbConnection: Could not connect to display :0.0
2016/08/13 14:07:49 6e025867 817845cf INFO   TSClient quit.
2016/08/13 14:07:49 RadioStation data loaded
2016/08/13 14:07:50 Imported radio stations
2016/08/13 14:07:54 6e025867 817845cf WARN   Could not request shutdown
What can I do?
After diagnostic :
 - Operating System: Debian GNU/Linux 7.11 (wheezy)
 - Kernel: Linux 3.14.32-xxxx-grs-ipv6-64 x86_64
 - Load Average: 0.08 0.17 0.22
 - Uptime: 31 days, 17 hours, 50 minutes, 15 seconds
 - OS Updates: 476 (updates available!)
 - OS APT Last Update: 08.07.2016 20:17:10 CEST +02:00:00
    CPU(s):                8
    Thread(s) per core:    1
    Core(s) per socket:    4
    Socket(s):             2
    CPU MHz:               1600.000
    Virtualization:        VT-x
 - RAM: 8.27 GB/15.71 GB in use (52%)
 - SWAP: 5.89 MB/510.99 MB in use (1%)
 - DISK: 26.83 GB/1.67 TB in use (1%)
   > libglib: 2.42.1-1+b12.42.1-1+b1
 - Binary: /home/ts3bot/ts3bot (Hash: 3b2c7f99a3b0a358e7d328079c4fa8b8)
 - Version:
   - TS3Path = /home/ts3bot/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64 (Version 3.0.18.2)
   - YoutubeDLPath = not set
 - Report date: 13.08.2016 14:15:56 CEST +02:00:00 (timezone: Europe/Paris)
 - youtube-dl Version: unknown
 - DiagScript version: 0.4.5
