Instance stopps instantly
Flammenfuchs_YT
Hey guys,
I've got a problem with my sinusbot installation. I try to give you all needing informations. I hope anyone can help me.
Diagnose-Script
- Kernel: Linux 4.9.0-0.bpo.12-amd64 x86_64
- Load Average: 0.22 0.25 0.27
- Uptime: 0 days, 2 hours, 0 minutes, 7 seconds
- OS APT Last Update: 29.04.2020 00:01:11 CEST +02:00:00
- Shell Locale: en_US.UTF-8
    CPU(s):                8
    Thread(s) per core:    1
    Core(s) per socket:    8
    Socket(s):             1
    Model name:            Intel(R) Xeon(R) Gold 6140 CPU @ 2.30GHz
    CPU MHz:               2294.608
    Hypervisor vendor:     KVM
    Virtualization type:   full
- RAM: 7.11 GB/62.92 GB in use (11%)
- DISK: 123.39 GB/1.96 TB in use (6%)
   - libglib: 2.42.1-1+deb8u3
- Status: running (PIDs: 21499 21498, User: sinusbot)
   - YoutubeDLPath = not set
    linux-vdso.so.1 (0x00007ffc32cca000)
    libswresample.so.2 => /opt/sinusbot/libswresample.so.2 (0x00007f73a8f22000)
    libavfilter.so.6 => /opt/sinusbot/libavfilter.so.6 (0x00007f73a8bca000)
    libavformat.so.57 => /opt/sinusbot/libavformat.so.57 (0x00007f73a87c9000)
    libavcodec.so.57 => /opt/sinusbot/libavcodec.so.57 (0x00007f73a7e64000)
    libavutil.so.55 => /opt/sinusbot/libavutil.so.55 (0x00007f73a7bf0000)
    libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f73a79ec000)
    libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f73a76eb000)
    libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f73a74ce000)
    libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f73a71c3000)
    libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f73a6fad000)
    libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f73a6c02000)
    libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f73a69e7000)
    librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f73a67df000)
    /lib64/ld-linux-x86-64.so.2 (0x00007f73a913c000)
- Time (local): 29.04.2020 02:11:20 CEST +02:00:00
- Time (remote): 29.04.2020 02:13:32 CEST +02:00:00
- Time (difference): 132 secs (Time diff greater than 30 secs!)
- TeamSpeak3 Version: 3.3.2
- youtube-dl Version: unknown
Config
ExternalFileBase = ""
LicenseKey = "EaJQ3oGYrOcUW9Uehq7C1RbTvKA7VNaP+4WVTSWwqwo="
  DevMode = false
[TTS]
  Enabled = false
Log
2020-04-29T02:13:58+02:00 Storing configuration.
2020-04-29T02:13:45+02:00 eof from voice
2020-04-29T02:13:45+02:00 closing channels
2020-04-29T02:13:44+02:00 Closed.
2020-04-29T02:13:44+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2020-04-29T02:13:44+02:00 TS>/opt/sinusbot/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64: symbol lookup error: /opt/sinusbot/TeamSpeak3-Client-linux_amd64/libQt5XcbQpa.so.5: undefined symbol: FT_Get_Font_Format
2020-04-29T02:13:44+02:00 TS>QXcbIntegration: Cannot create platform OpenGL context, neither GLX nor EGL are enabled
2020-04-29T02:13:44+02:00 TS>Failed to create secure directory (/run/user/0/pulse): Permission denied
2020-04-29T02:13:44+02:00 TS>QStandardPaths: wrong ownership on runtime directory /run/user/0, 0 instead of 1000
2020-04-29T02:13:44+02:00 TS>qt.qpa.xkeyboard: no keyboard layouts with latin keys present
2020-04-29T02:13:44+02:00 TS>QCoreApplication::applicationDirPath: Please instantiate the QApplication object first
2020-04-29T02:13:44+02:00 TS>/opt/sinusbot/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libdbus-1.so.3: no version information available (required by /opt/sinusbot/TeamSpeak3-Client-linux_amd64/libQt5WebEngineCore.so.5)
2020-04-29T02:13:44+02:00 TS |INFO    |Addons        |   |Checking for addon updates...
2020-04-29T02:13:44+02:00 TS |ERROR   |RevocationListCache|   |Failed to import revocation list from cache
2020-04-29T02:13:44+02:00 TS |INFO    |ClientUI      |   |Unable to create an Open GL context.
2020-04-29T02:13:44+02:00 TS |ERROR   |SoundBckndIntf|   |/opt/sinusbot/TeamSpeak3-Client-linux_amd64/soundbackends/libpulseaudio_linux_amd64.so error: INIT_PA_IMPL
2020-04-29T02:13:44+02:00 TS |ERROR   |PulseAudio    |   |pa_context_connect failed -
2020-04-29T02:13:44+02:00 TS |ERROR   |PulseAudio    |   |failed to connect to pulse audio server -
2020-04-29T02:13:44+02:00 TS |INFO    |              |   |Using hardware aes
2020-04-29T02:13:44+02:00 TS |INFO    |              |   |SystemInformation: Linux 4.9.0-0.bpo.12-amd64 #1 SMP Debian 4.9.210-1~deb8u1 (2020-02-21) x86_64 Binary: 64bit
2020-04-29T02:13:44+02:00 TS |INFO    |              |   |TeamSpeak Client 3.3.2 (2019-08-25 21:13:34)
2020-04-29T02:13:44+02:00 TS>DUMP defined! Dumpdir is: /opt/sinusbot/data/ts3/704f0c4a-2a1e-41c8-849b-4996c1bfe407/4cc9938e-2c3e-4426-bcbf-db5b5b4480a6/crashdumps
2020-04-29T02:13:44+02:00 TS>Crashdump ENABLED,  directory is: /opt/sinusbot/data/ts3/704f0c4a-2a1e-41c8-849b-4996c1bfe407/4cc9938e-2c3e-4426-bcbf-db5b5b4480a6/crashdumps
2020-04-29T02:13:44+02:00 Starting instance ts3server://46.38.237.239?port=9987&nickname=Test&password=&channel=&channelpassword=
2020-04-29T02:13:44+02:00 Could not insert into News-Tableno such table: News
2020-04-29T02:13:44+02:00 Could not delete from Newsno such table: News
2020-04-29T02:13:44+02:00 Could not insert into Profiles-Tableno such table: Profiles
2020-04-29T02:13:44+02:00 Could not delete from Profilesno such table: Profiles
2020-04-29T02:13:44+02:00 Could not insert into FileTransfer-Tableno such table: FileTransfer
2020-04-29T02:13:44+02:00 Could not delete from FileTransferno such table: FileTransfer
2020-04-29T02:13:44+02:00 Could not create Notifications-Tabletable Notifications already exists
2020-04-29T02:13:44+02:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
2020-04-29T02:13:44+02:00 Could not create Chat-Tabletable Chat already exists
2020-04-29T02:13:44+02:00 About to run.
2020-04-29T02:13:44+02:00 Prespawn.
2020-04-29T02:13:28+02:00 imported module: command
2020-04-29T02:13:28+02:00 resolving module command
2020-04-29T02:13:28+02:00 script command loaded
2020-04-29T02:13:28+02:00 module registered as command
2020-04-29T02:13:28+02:00 registered callback for event chat
2020-04-29T02:13:28+02:00 Initialization complete
2020-04-29T02:13:28+02:00 script sinusbot-commands loaded
2020-04-29T02:13:28+02:00 registered callback for event load
2020-04-29T02:13:28+02:00 [sinusbot-commands:86:12] Loaded SinusBot Commands v1.0.0 by Jonas Bögle ([USER=1213]@irgendwr[/USER]).
2020-04-29T02:13:28+02:00 executing script command
2020-04-29T02:13:28+02:00 executing script sinusbot-commands
fabm3n
Tier II
Tier I
fyi Debian 8 is EOL in 2 months.
Teamspeak needs a minimum version of a dependency which is not available in Debian 8.
Flammenfuchs_YT
Failed...
New Diag-Script Output:
 - Operating System: Debian GNU/Linux 10.3 (n/a)
 - Load Average: 0.46 0.41 0.34
 - Uptime: 3 days, 9 hours, 44 minutes, 31 seconds
 - OS APT Last Update: 17.05.2020 00:42:46 CEST +02:00:00
    CPU(s):                8
    Socket(s):             1
    CPU MHz:               2294.608
 - RAM: 10.86 GB/62.92 GB in use (17%)
 - DISK: 239.77 GB/1.96 TB in use (11%)
   - libglib: 2.58.3-2+deb10u2
 - Status: running (PIDs: 3082 3081, User: sinusbot)
 - Binary Info: MD5 Hash: 224b687db910b732fe5a7cfec4f6c78e, Perms: 755, User: si        nusbot
   - TS3Path = /opt/sinusbot/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64        (Version 3.5.3)
 - Installed scripts: advertising.js; alonemode.js; bookmark.js; command.js; fol        lowme.js; norecording.js; rememberChannel.js; sinusbot-commands.js; welcome.js
    linux-vdso.so.1 (0x00007ffe99fa6000)
    libswresample.so.2 => /opt/sinusbot/libswresample.so.2 (0x00007f1b65f82000)
    libavfilter.so.6 => /opt/sinusbot/libavfilter.so.6 (0x00007f1b65c2a000)
    libavformat.so.57 => /opt/sinusbot/libavformat.so.57 (0x00007f1b65829000)
    libavcodec.so.57 => /opt/sinusbot/libavcodec.so.57 (0x00007f1b64ec4000)
    libavutil.so.55 => /opt/sinusbot/libavutil.so.55 (0x00007f1b64c50000)
    libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f1b64c41000)
    libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f1b64abc000)
    libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f1b64a9b000        )
    libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f1b649170        00)
    libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f1b648fd000)
    libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f1b6473c000)
    libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f1b6451e000)
    librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f1b64512000)
    /lib64/ld-linux-x86-64.so.2 (0x00007f1b6619e000)
 - HTTPS check with IPv4 mode: SUCCESS [Connection established to www.sinusbot.c        om, CODE #200]
 - Time (local): 17.05.2020 00:57:19 CEST +02:00:00
 - Time (remote): 17.05.2020 00:57:31 CEST +02:00:00
 - Time (difference): 12 secs (Time diff between 10 and 30 secs! Critical!)
 - TeamSpeak3 Version: 3.5.3
New Log Output:
2020-05-17T01:01:44+02:00 eof from voice
2020-05-17T01:01:44+02:00 closing channels
2020-05-17T01:01:43+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2020-05-17T01:01:43+02:00 Closed.
2020-05-17T01:01:43+02:00 TS>/opt/sinusbot/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64: symbol lookup error: /opt/sinusbot/TeamSpeak3-Client-linux_amd64/libQt5XcbQpa.so.5: undefined symbol: FT_Get_Font_Format
2020-05-17T01:01:43+02:00 TS>QXcbIntegration: Cannot create platform OpenGL context, neither GLX nor EGL are enabled
2020-05-17T01:01:43+02:00 TS>Failed to create secure directory (/run/user/0/pulse): Permission denied
2020-05-17T01:01:43+02:00 TS>QStandardPaths: wrong ownership on runtime directory /run/user/0, 0 instead of 1000
2020-05-17T01:01:43+02:00 TS>qt.qpa.xkeyboard: no keyboard layouts with latin keys present
2020-05-17T01:01:43+02:00 TS>QCoreApplication::applicationDirPath: Please instantiate the QApplication object first
2020-05-17T01:01:43+02:00 TS>/opt/sinusbot/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libdbus-1.so.3: no version information available (required by /opt/sinusbot/TeamSpeak3-Client-linux_amd64/libQt5WebEngineCore.so.5)
2020-05-17T01:01:43+02:00 TS |INFO    |Addons        |   |Checking for addon updates...
2020-05-17T01:01:43+02:00 TS |ERROR   |RevocationListCache|   |Failed to import revocation list from cache
2020-05-17T01:01:43+02:00 TS |INFO    |ClientUI      |   |Unable to create an Open GL context.
2020-05-17T01:01:43+02:00 TS |ERROR   |SoundBckndIntf|   |/opt/sinusbot/TeamSpeak3-Client-linux_amd64/soundbackends/libpulseaudio_linux_amd64.so error: INIT_PA_IMPL
2020-05-17T01:01:43+02:00 TS |ERROR   |PulseAudio    |   |pa_context_connect failed -
2020-05-17T01:01:43+02:00 TS |ERROR   |PulseAudio    |   |failed to connect to pulse audio server -
2020-05-17T01:01:43+02:00 TS |INFO    |              |   |Using hardware aes
2020-05-17T01:01:43+02:00 TS |INFO    |              |   |SystemInformation: Linux 4.9.0-0.bpo.12-amd64 #1 SMP Debian 4.9.210-1~deb8u1 (2020-02-21) x86_64 Binary: 64bit
2020-05-17T01:01:43+02:00 TS |INFO    |              |   |TeamSpeak Client 3.5.3 (2020-05-06 09:07:50)
2020-05-17T01:01:43+02:00 TS>DUMP defined! Dumpdir is: /opt/sinusbot/data/ts3/4e87f5c0-7e49-436c-b5d7-51365e948912/fce19cb4-de11-4ea7-9de4-9b85b0ec9207/crashdumps
2020-05-17T01:01:43+02:00 TS>Crashdump ENABLED,  directory is: /opt/sinusbot/data/ts3/4e87f5c0-7e49-436c-b5d7-51365e948912/fce19cb4-de11-4ea7-9de4-9b85b0ec9207/crashdumps
2020-05-17T01:01:43+02:00 Starting instance ts3server://flammencraft.de?port=9987&nickname=FlammenCraft.de%20-%20Netzwerk&password=&channel=&channelpassword=
2020-05-17T01:01:43+02:00 Could not insert into News-Tableno such table: News
2020-05-17T01:01:43+02:00 Could not delete from Newsno such table: News
2020-05-17T01:01:43+02:00 Could not insert into Profiles-Tableno such table: Profiles
2020-05-17T01:01:43+02:00 Could not delete from Profilesno such table: Profiles
2020-05-17T01:01:43+02:00 Could not insert into FileTransfer-Tableno such table: FileTransfer
2020-05-17T01:01:43+02:00 Could not delete from FileTransferno such table: FileTransfer
2020-05-17T01:01:43+02:00 Could not create Notifications-Tabletable Notifications already exists
2020-05-17T01:01:43+02:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
2020-05-17T01:01:43+02:00 Could not create Chat-Tabletable Chat already exists
2020-05-17T01:01:43+02:00 About to run.
2020-05-17T01:01:43+02:00 Prespawn.
2020-05-17T01:01:32+02:00 imported module: command
2020-05-17T01:01:32+02:00 resolving module command
2020-05-17T01:01:32+02:00 script command loaded
2020-05-17T01:01:32+02:00 module registered as command
2020-05-17T01:01:32+02:00 registered callback for event chat
2020-05-17T01:01:32+02:00 Initialization complete
2020-05-17T01:01:32+02:00 script sinusbot-commands loaded
2020-05-17T01:01:32+02:00 registered callback for event load
2020-05-17T01:01:32+02:00 [sinusbot-commands:86:12] Loaded SinusBot Commands v1.0.0 by Jonas Bögle (@irgendwr).
2020-05-17T01:01:32+02:00 executing script command
2020-05-17T01:01:32+02:00 executing script sinusbot-commands
Himsel
I'm not sure... seems like there are dependencies missing. Did you follow these instructions step by step? click
fabm3n
Tier II
Tier I
script doesnt work.
What do you mean with "not working" ?
Can you please send us the output of ldconfig -p | grep libdbus?
Then you can try to install libdbus-1-3
After that please do ldconfig -p | grep libdbus again and send the output here too.
Thanks.
fabm3n
Tier II
Tier I
Codename buster wird auch nicht erkannt wie am (n/a) zu erkennen. Also Apt-get update schmeißt garantiert auch fehler.
Das Diag script hat aber nichts mit dem Install script zu tun ;)
Und vor allem nicht mit apt-get update :D
Himsel
Das diag Script gibt bloß doch den befehl lsb_release und wenn das den Codename nicht erkennt ist das nicht richtig. Und das hängt sehr wohl mit Apt-get zusammen
Flammenfuchs_YT
Habe apt-get update und apt-get upgrade, nun erkennt es den Codenamen, neues Script schicke ich heute Abend, am Handy kann ich nicht wirklich kopieren
fabm3n
Tier II
Tier I
Hast du "ldconfig -p | grep libdbus" gemacht wie ich oben beschrieben habe?
fabm3n
Tier II
Tier I
Also scheint es installiert zu sein.
Kannst du mal apt list --installed "libdbus*" machen?
