lost my interface login info pls help
SeaLad
Hello guys today after about 2 weeks that i wasent on my pc i lost my password (i did create it befor 2 weeks )
pls help me to reset it
And also how do i stream music from youtube to the bot?
#TS 3
At the moment you cant recover your password. You need to reinstall the bot!
To stream music from Youtube you can either go to the Upload page and post your Youtube link there or you can use the chat commands !yt <url> and !ytdl <url>. The first command will play the video without saving it, the second one will play the video and save the file so you can play it again later. Also you need to have youtube-dl installed and configured.
If you run the bot on Linux you should use the installer script found here (https://forum.sinusbot.com/resources/sinusbot-installer-script.58/) as it will install and configure everything by its own!
