Solved Migrating my audio files
imbalord
Hey guys, I was just wondering whether I could migrate all of my audio files to the new WINDOWS version of Sinusbot. I've been using the older one for quite some time now and the data folder is about 10gb.
This is what I've tried so far: I've installed the newest version of Sinusbot 0.9.13 and copied my entire data folder into the new installation. However, the new version will not launch after I've done that.
Am I missing something?
It should work the way you did it. Run the new version from a commandline with the -debug parameter added, maybe that'll give you more info on what's wrong.
imbalord
yes the debug parameter helped. it was simply stuck at updating database to v6. that took quite a while. ^^
thx mate.
