My SinusBot starts loading, then stops and doesn't start
Patches
Hello. I'll try to make this as straight as posibble.
I installed the bot via the script. Reinstalled it a couple of times to see if the problem is solved after all but it just kept doing it.
The little power button on the right corner changes to green, the blue loading bar is slowly loading after a second it just disappears and the power button turns back to orange.
I really don't know what else should I do. I hope someone will help.
So here is the diagSinusbot code
[CODE]
- Load Average: 0.00 0.00 0.00
- Uptime: 0 days, 0 hours, 30 minutes, 3 seconds
- OS Updates: 16 (updates available!)
- OS APT Last Update: 23.07.2019 03:11:16 CEST +02:00:00
- Shell Locale: en_US.UTF-8
    CPU(s):                1
    Thread(s) per core:    1
    Core(s) per socket:    1
    Socket(s):             1
    Model name:            Common KVM processor
    CPU MHz:               2666.760
    Hypervisor vendor:     KVM
    Virtualization type:   full
- RAM: 205.55 MB/1000.28 MB in use (20%)
- DISK: 1.78 GB/9.81 GB in use (18%)
   - libglib: 2.42.1-1+deb8u1
- Status: running (PIDs: 3109 3106, User: grey59Bot)
- Binary Info: MD5 Hash: d770dee2259d159aa78550962d3251e3, Perms: 755, User: grey59Bot
   - YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2019.07.16)
    linux-vdso.so.1 (0x00007fff6fd21000)
    libswresample.so.2 => /opt/sinusbot/libswresample.so.2 (0x00007fe900b03000)
    libavfilter.so.6 => /opt/sinusbot/libavfilter.so.6 (0x00007fe9007ab000)
    libavformat.so.57 => /opt/sinusbot/libavformat.so.57 (0x00007fe9003aa000)
    libavcodec.so.57 => /opt/sinusbot/libavcodec.so.57 (0x00007fe8ffa45000)
    libavutil.so.55 => /opt/sinusbot/libavutil.so.55 (0x00007fe8ff7d1000)
    libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007fe8ff5cd000)
    libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007fe8ff2cc000)
    libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007fe8ff0af000)
    libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007fe8feda4000)
    libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007fe8feb8e000)
    libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007fe8fe7e3000)
    libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007fe8fe5c8000)
    librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007fe8fe3c0000)
    /lib64/ld-linux-x86-64.so.2 (0x00007fe900d1d000)
- Time (local): 23.07.2019 03:29:59 CEST +02:00:00
- Timezone: Europe/Budapest
- TeamSpeak3 Version: 3.3.0
- youtube-dl Version: 2019.07.16
And here is the Instance Log:
[CODE]
2019-07-23T03:33:15+02:00 closing channels
2019-07-23T03:33:14+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2019-07-23T03:33:14+02:00 Closed.
2019-07-23T03:33:14+02:00 TS>terminating with uncaught exception of type boost::exception_detail::clone_impl<boost::exception_detail::error_info_injector<boost::uuids::entropy_error> >: getrandom
2019-07-23T03:33:14+02:00 TS>QXcbIntegration: Cannot create platform OpenGL context, neither GLX nor EGL are enabled
2019-07-23T03:33:14+02:00 TS>QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-grey59Bot'
2019-07-23T03:33:14+02:00 TS>qt.qpa.xkeyboard: no keyboard layouts with latin keys present
2019-07-23T03:33:14+02:00 TS>QCoreApplication::applicationDirPath: Please instantiate the QApplication object first
2019-07-23T03:33:14+02:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libdbus-1.so.3: no version information available (required by /opt/sinusbot/teamspeak3-client/libQt5WebEngineCore.so.5)
2019-07-23T03:33:14+02:00 Starting instance ts3server://54.36.75.226?port=2919&nickname=SinusBot&password=&channel=&channelpassword=
2019-07-23T03:33:14+02:00 Could not insert into News-Tableno such table: News
2019-07-23T03:33:14+02:00 Could not delete from Newsno such table: News
2019-07-23T03:33:14+02:00 Could not insert into Profiles-Tableno such table: Profiles
2019-07-23T03:33:14+02:00 Could not delete from Profilesno such table: Profiles
2019-07-23T03:33:14+02:00 Could not insert into FileTransfer-Tableno such table: FileTransfer
2019-07-23T03:33:14+02:00 Could not delete from FileTransferno such table: FileTransfer
2019-07-23T03:33:14+02:00 Could not insert into Application-Tableno such table: Application
2019-07-23T03:33:14+02:00 Could not delete from Applicationno such table: Application
2019-07-23T03:33:14+02:00 Could not create Notifications-Tabletable Notifications already exists
2019-07-23T03:33:14+02:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
2019-07-23T03:33:14+02:00 Could not create Chat-Tabletable Chat already exists
2019-07-23T03:33:14+02:00 About to run.
Also, this is what it says when I type in "service sinusbot service"
Jul 23 03:33:14 vps sinusbot[3106]: 2019/07/23 03:33:14 8102b3a8 afc04d0a DEBUG  TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libdbus-1...neCore.so.5)
Jul 23 03:33:14 vps sinusbot[3106]: 2019/07/23 03:33:14 8102b3a8 afc04d0a DEBUG  TS>QCoreApplication::applicationDirPath: Please instantiate the QApplication object first
Jul 23 03:33:14 vps sinusbot[3106]: 2019/07/23 03:33:14 8102b3a8 afc04d0a DEBUG  TS>qt.qpa.xkeyboard: no keyboard layouts with latin keys present
Jul 23 03:33:14 vps sinusbot[3106]: 2019/07/23 03:33:14 8102b3a8 afc04d0a DEBUG  TS>QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-grey59Bot'
Jul 23 03:33:14 vps sinusbot[3106]: 2019/07/23 03:33:14 8102b3a8 afc04d0a DEBUG  TS>QXcbIntegration: Cannot create platform OpenGL context, neither GLX nor EGL are enabled
Jul 23 03:33:14 vps sinusbot[3106]: 2019/07/23 03:33:14 8102b3a8 afc04d0a DEBUG  TS>terminating with uncaught exception of type boost::exception_detail::clone_impl<boost:...>: getrandom
Jul 23 03:33:14 vps sinusbot[3106]: 2019/07/23 03:33:14 8102b3a8 afc04d0a DEBUG  Closed.
Jul 23 03:33:14 vps sinusbot[3106]: 2019/07/23 03:33:14 8102b3a8 afc04d0a INFO   TSClient quit. LogLevel has been increased, please try to connect again to see more details.
Jul 23 03:33:15 vps sinusbot[3106]: 2019/07/23 03:33:15 8102b3a8 afc04d0a DEBUG  closing channels
Jul 23 03:33:40 vps sinusbot[3106]: 2019/07/23 03:33:40 8102b3a8 afc04d0a DEBUG  Storing configuration.
Patches
So, and how do I downgrade my TS or update my kernel? I'm sorry I'm not into this stuff I just want the bot for me and my friends to have some fun with. None of us is an expert in this
Patches
I tried to downgrade my TeamSpeak Client to 3.2.3 and after it the web interface didn't even load up. I'm really confused.
DrWarpMan
If you would read the post, that @TwentyFour mentioned, you would read that you have to downgrade to TS 3.2.5 with and downgrade Sinusbot also to 1.0.0-beta.2
DrWarpMan
What is the optional teamspeak server/client version for sinusbot?
Optimal is the most new / latest version which at this time is 3.3.0, with Sinusbot version 1.0.0-beta.3 and higher.
(Requires kernel version 3.17 or higher)
Downgrade TS = short term solution
Upgrade your kernel = long term
Most like you just ask your VPS provider, depending on which kind of virtualisation it's running... you're running debian 8 still ... or simply reinstall with Debian 10.
You could try updating, but I have no idea if that's a good idea doing so across more than one version.
I guess you mean "optimal" 🤣
Patches
Ok so, I tried installing Debian 9 (with the sinusbot script) and it got stuck when it tried to detect the latest version of TeamSpeak. So I tried to install Ubuntu 18.04 on it and it went very well, the TS Client got installed and everything the web is up and running but... Here is the catch.
2019-07-23T22:43:42+02:00 closing channels
2019-07-23T22:43:41+02:00 Closed.
2019-07-23T22:43:41+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2019-07-23T22:43:41+02:00 Starting instance ts3server://54.36.75.226?port=2919&nickname=yxcvv%20vbxs&password=&channel=&channelpassword=
2019-07-23T22:43:41+02:00 About to run.
2019-07-23T22:43:41+02:00 Prespawn.
2019-07-23T20:13:40+02:00 Storing configuration.
2019-07-23T20:13:31+02:00 BOT-CONFIG [admin] NAME HOST PORT CHANPW CHAN ANNOUNCE DESCRIPTION ANNOUNCESTR TTSURL CC OK
2019-07-23T20:13:14+02:00 KILL [admin] OK
2019-07-23T20:13:11+02:00 closing channels
2019-07-23T20:13:10+02:00 script command loaded
2019-07-23T20:13:10+02:00 module registered as command
2019-07-23T20:13:10+02:00 registered callback for event chat
2019-07-23T20:13:10+02:00 serialized function: true
2019-07-23T20:13:10+02:00 executing script command
2019-07-23T20:13:10+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2019-07-23T20:13:10+02:00 Starting instance ts3server://?port=9987&nickname=yxcvv%20vbxs&password=&channel=&channelpassword=
Again, here is the diagSinusbot code:
 - Operating System: Ubuntu 18.04.2 LTS
 - Kernel: Linux 4.15.0-20-generic x86_64
 - Load Average: 0.28 0.10 0.02
 - Uptime: 0 days, 2 hours, 37 minutes, 58 seconds
 - OS Updates: 12 (updates available!)
 - OS APT Last Update: 23.07.2019 19:57:25 CEST +02:00:00
 - Shell Locale: (not set)
    CPU(s):              1
    Socket(s):           1
    CPU MHz:             2666.760
 - RAM: 210.50 MB/985.39 MB in use (21%)
 - DISK: 2.05 GB/9.80 GB in use (20%)
 - Status: running (PIDs: 318 317, User: grey59Bot)
   - LogLevel = 0
    linux-vdso.so.1 (0x00007ffcdf3c7000)
    libswresample.so.2 => /opt/sinusbot/libswresample.so.2 (0x00007fc9c9e0d000)
    libavfilter.so.6 => /opt/sinusbot/libavfilter.so.6 (0x00007fc9c9ab5000)
    libavformat.so.57 => /opt/sinusbot/libavformat.so.57 (0x00007fc9c96b4000)
    libavcodec.so.57 => /opt/sinusbot/libavcodec.so.57 (0x00007fc9c8d4f000)
    libavutil.so.55 => /opt/sinusbot/libavutil.so.55 (0x00007fc9c8adb000)
    libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007fc9c88d7000)
    libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007fc9c8539000)
    libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007fc9c831a000)
    libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007fc9c7f91000)
    libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007fc9c7d79000)
    libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007fc9c7988000)
    libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007fc9c776b000)
    librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007fc9c7563000)
    /lib64/ld-linux-x86-64.so.2 (0x00007fc9ca027000)
 - Time (local): 23.07.2019 22:46:42 CEST +02:00:00
I just can't seem to run it!!! I'm really trying to install it but I don't know what to do.
Debian 10 is not an option because my host has Debian 8, 9.
Debian 9 or Ubuntu 18.04 should be fine as well...
Firstly set LogLevel = 10 in your config, and not to 0. Otherwise we cannot see the occuring errors.
Secondly ensure TS-Client 3.3.0 dependencies are met. This is the most common mistake to prevent bot from connecting.
(sudo) apt install libpci3 libxslt1.1 libxkbcommon0
Patches
Ok, somehow the bot just started and connected. I literally didn't do anything. I guess it is solved now. But the help is really appreciated!
