DomsimirDuo
With the sinusbot user. Command ./sinusbot
That means, if you downgrade your TS3, will it work?TS 3.3 requires at least a Kernel with version 3.17 or higher.
TS 3.2.5 with 1.0.0-beta.2 would work, I don't recommend it, though. Kernel 3.17 is already pretty old.That
This one tells you that the kernel version is unsupported.terminating with uncaught exception of type boost::exception_detail::clone_impl<boost::exception_detail::error_info_injector<boost::uuids::entropy_error> >: getrandom
He wanted to downgrade the version, by mei gave him my Log in. He try to fix the problem for me ^^
And there we have a another black sheep in the wide market of hosting resellersHis server hosting does not have higher kernel version for some reason.
^^ I told him to contact support if they can do anything about it, so I hopeAnd there we have a another black sheep in the wide market of hosting resellers
You should just switch your provider then, scetchy as f*ck imho...
